Logik l22ldvb21
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Logik l22ldvb21
    Hello forum,I have a logik 22'' LCD,it has developed a fault,where the standby does light up switches/lights up briefly then switches off back to standby,just reading up could it be more of a firmware fault ? Help please
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Logik l22ldvb21
    Have you measured any voltages on the power supply connectors. Do you have pictures of the circuit boards mounted on the chassis. If you can post those details it would help others help you.
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      Re: Logik l22ldvb21
      • LEEDASH
        • Dec 2012
        • 481
        • Bedfordshire
        Re: Logik l22ldvb21
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Re: Logik l22ldvb21
          Yep I have the same board here, bad firmware on mine so chances are same on yours bro. Crappy junk.
          • LEEDASH
            • Dec 2012
            • 481
            • Bedfordshire
            Re: Logik l22ldvb21
            No fix then bud,
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Re: Logik l22ldvb21
              Unless you find the FW for the board and panel no
              • LEEDASH
                • Dec 2012
                • 481
                • Bedfordshire
                Re: Logik l22ldvb21
                How can you update any firmware if it dont switch on ?
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Re: Logik l22ldvb21
                  You need to reflash the SPI memory Ic outside of the Tv using an SPI analyser. Just get a new board mate as its difficult to do.
                  • daveytee999
                    Logik L22FED12A TV - comes on but switches off after few secs
                    by daveytee999
                    I have a cheap Logik TV with DVD unit integrated. It comes on when you press the power button and the Logik logo comes up on screen but then after a few seconds the TV goes back to standby.
                    Not used to troubleshooting TVs - my background is PCs/Networks/Routers but this looks like it's not a power issue (surely the TV wouldn't power up)
                    It's not a backlight issue cos the backlight comes on when Logik logo appears.
                    Have had the TV apart and done basic testing (although just proved that there is mains power and some secondary low voltage coming out).
                    Not sure...
                    10-06-2021, 09:18 AM
                  • alltvrepairs
                    Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                    by alltvrepairs
                    I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                    I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                    Any one met this problem in the past?...
                    10-08-2025, 07:34 AM
                  • MrCreosote
                    2 Belkin KVM switches have dim VGA output
                    by MrCreosote
                    When compared to a direct VGA connection, these 2 switches both output a darker image. The switches are:
                    4-port Omniview Pro2 f1dz104t
                    8-port Omniview either f1da108t OR f1dz108t (look and function same, OSD may be only difference.)
                    The 4 is dimmer, the 8 is massively dimmer - both with same AC adapter and cabling.
                    AD ADAPTER:
                    There were issues with previous AC adapter, it failed during lightning strike that blew up TV and other stuff and tripped a 15 amp breaker in the main panel which also had a whole house Cutler Hammer surge...
                    08-15-2023, 08:26 PM
                  • _max_
                    Hisense H60N5705 automatically switches off
                    by _max_
                    Hisense H60N5705 installed in a conference room, turns off automatically a few minutes after being switched on.
                    Problem occurred suddenly, during a video conference. Switched on again by the remote control, it continued to work for a while and then switched off again.
                    Power cable and HDMI cable checked.
                    No changes by connecting the TV to another source but, even if it is left on the OSD menu, it stays on for a few minutes and then switches off.
                    So they took the TV (a 60' which is not easy to handle) to the lab and asked me to check it.
                    03-07-2025, 06:14 AM
                  • stephan11
                    Dell Latitude 5310 2in1 motherboard. After installation, the orange LED only lights up briefly
                    by stephan11
                    I don't know if I'm in the right place with my problem. I bought a new Dell Latitude 5310 2in1 motherboard. After installation, the orange LED only lights up briefly. can anyone help me here?
                    greeting
                    Stephen​
                    07-01-2024, 02:30 PM
