SAMSUNG UE50EH6300, double image
  • finntricky
    • Jan 2014
    • 449
    Hi guys, got this in with a double image problem, but its only on the bottom half of the screen, the top of the screen has a perfect picture,
    checked and cleaned/ reseated t-con cables, but still same prob.
  • Diah
    • Feb 2013
    • 6363
    Re: SAMSUNG UE50EH6300, double image
    however you cleaned and rset them, the problem still at ribbon cable or the socket of them. can notice in first picture there are line much go its cause of T_CON
      Does it change if you flex the panel?
        Gonna place my bets on a bad panel issue that may be repairable.
        • Diah
          • Feb 2013
          • 6363
          LOL tom66... you guys from UK always placing expensive bets on panel. this is not the only post i read from UK bets of panel LOL
            I've heard of hacks to fix some of these double image issues, but believe it doesn't work on the EH series...only the D series. EH uses different panels. Virtually all of the time, an issue like this is down to the panel in some way. It's almost never anything else.
            • finntricky
              • Jan 2014
              • 449
              come on then tom66, lets have some ideas m8, cant find a t-con at the moment so cant try that idea, whats the hacks with the D series ? you never know.
              • chrismurphy
                • May 2014
                • 251
                • australia
                I am afraid that its not a t-con issue 99% bad panel
                  Panel problem.
                  • thoma
                    • Sep 2012
                    • 268
                    http://alpengeist-tvrepair.blogspot.de/
                      Originally posted by thoma
                      Good info, thanks.
                      • finntricky
                        • Jan 2014
                        • 449
                        so today i had a play, and im going to says bad screen, checked all the tabs with no effect, and then removed t-con to screen cables one at a time, and these are the results.as you can see, got a negative image but not double, changed sides and then got white screen with lines.
                          Did Tom win the bet?
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Panel problem end of.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              All the other posts you commented on saying its not the panel. Were all the panel so please listen to people who have an idea yes good to have some hope but learn to know what to look out for.
                              Thats coming from me-a 16 Y/O......No offence.
                              • finntricky
                                • Jan 2014
                                • 449
                                OH YES
                                but im not an happy bunny
                                • Cornito
                                  Samsung UE55RU8000 reboot and then double image after heating up
                                  by Cornito
                                  Hello team,
                                  I'm back with another tv and another problem.
                                  I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
                                  First, reboot issue, I use tape Method to find out the right side that cases the issue.
                                  Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
                                  Then double image reduce in height and move to the top.
                                  The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
                                  When I...
                                  03-31-2024, 01:37 PM
                                  09-07-2024, 05:50 AM
                                • howardc64
                                  TCL 49S405 double image
                                  by howardc64
                                  LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                                  This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                                  06-23-2025, 03:20 PM
                                • shlomim412
                                  samsung ua55es6800 - no image
                                  by shlomim412
                                  hi
                                  having problem with samsung ua55es6800
                                  tv had backlight on, sound working - responds to the remote control but no image.
                                  check tcon board - had 12v in but no other voltages present.
                                  when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                                  when leaving only left side connected - again no voltages and no image.
                                  put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                                  kept trying to block less pins on the left ribbon cable...
                                  05-15-2024, 05:00 AM
                                  09-06-2024, 11:40 PM
