BN44-00264A board reinstall question - black strip is off too
  • jemco
    • Jan 2016
    • 3
    It looks like I improperly removed my BN44-00264A board.
    I also removed the black strip to the right edge of the board.
    I was supposed to pull the BN44-00264A board out of the black strip, but I took the black strip off too.
    The black strip has a number of blocks that reach into the steel back wall and clip onto these wire like things.
    Looks like this powers the lighting on the Samsung TV. Just a guess.
    Well when I put the black strip back on, the clips don't clip, they just push the wires down a bit. They move.
    Can someone please help me with instructions on how to reinstall the black strip?
    I'm thinking I need to get to the other side of the steel wall to push them back on one at a time, but I don't know how to do that or even if it is necessary.
    By the way, I repaired my BN44-00264A by replacing two transistors (QI820, 821) and a capacitor (CI892 cap was probably not bad though) and the fuse FM802S.
    I am optimistic that the board is fixed, but I need some help please to put the black strip back on.
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: BN44-00264A board reinstall question - black strip is off too
    Yes,that black strip is whats holding the light tubes in place on the other side of that metal wall. They are now loose on that end so careful handling of tv is recommended.
    You will need to disassemble the panel to get to the light tubes to reinsert them into the black strip.
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • johnboy1313
      • Nov 2012
      • 1959
      Those wires you mention are the ends of the bulbs inside the panel. Be careful that you don't break them.
      • jemco
        • Jan 2016
        • 3
        Hello martino and johnboy1313!
        Thank you for the replies!
        Is there any procedure you might be able to show me for how to disassemble the panel to get to the light tubes?
        Even if you only have a rough guide to tell me from your memory, that would help greatly.
        Thank you anyway.
        Joe
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Look up how to take Lcd panel apart it shows you. I did that once and its not fun lol
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • ttmi100x
            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
            by ttmi100x
            Greetings everyone,
            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
            Upon closer inspection...
            07-31-2024, 06:36 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
