HELP please! LC-60LE810UN Flashing codes/Reset/Replaced LED strip
  • Mattwnh
    • Feb 2016
    • 4
    Hi Folks
    New to the site.
    Been doing allot of reading. My eyes hurt, ben crawling on the floor and body hurts too. lol
    Anyhow.
    I had the 1-2 error code. I took the panel apart. Tested all the LED strips ( did the 9-9v batterys in series for the 30 led sterips and 14-9v batteries for the 49 led strips)
    I found the bad 30 led strip (as many stated it was the top right corner).
    I powered the tv up and was able to get to the service area and the lamp error was 5. I reset that fine back to zero.
    Now my problem is now that I have reset that I plug the power bacxk in I get the 2-5 (2 slow 5 fast) code. I can't get the TV tow power the LEDs up again. I have tried just about every combination of holds and power button along with holds and plugging in the TV.
    Any Ideasof why I had/was able to illuminate the LEDs before and now can't do anything? Anyone have any suggestions? Has this happened to you? What did you do?
    I Disconected the lcd unit+ No Difference
    Disconected Main Board=No Difference
    Leads me to believe the POWER/LED DRIVE Unit bad ?
    on the POWER/LED DRIVE Unit (if I did this right, tried many different sequences, plugging it in. then reading in stand by) on the Gray wire I put my positive prove on the UR13.2 and my Neg prob to chasis ground I get 7.4v) I tried leaving my pos prob there and black pro to Black wire of UR13.2 got )
    Tried Pos Prob To StandBY and Ground (same, multiple sequences of on, power o etc) neg to a ground, ) power.
    Am I Testing the board Wrong?
    Again. Willing to start over with testing, Just need to know where to begin.
    Thanks!
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: HELP please! LC-60LE810UN Flashing codes/Reset/Replaced LED strip
    how did you repair the faulty led strip
    • Mattwnh
      • Feb 2016
      • 4
      Replaced whole strip (the 30 LED Part # K4459TP) bought used strip from ebay tested strip before installing in panel and also had tv working in service mode with the used strip purched from ebay in the panel.
      Again, Did the error lamp reset and repowered the TV and got new code of 2 slow 5 fast. Now can't get anything to fire.
      Seems strange I could get the TV to fire the LEDS before. No hardware was ever changed, no values were ever changed in the service mode (except just a count) definately stumpted
      • CapLeaker
        Leaking Member
        • 7962
        We need to have some high resolution straight shot pictures of the main and power supply boards, both sides.
        Try turning on the TV and see what you get on the PSon and BLon pins.
        • R_J
          • 9514
          There is this bulletin
          • Mattwnh
            • Feb 2016
            • 4
            Solved!
            I guess I was brain dead! lol
            For the life of me the I got into service mode, changed the lamp erroor reset and the TV threw code 2-5 . I swear I didn't touch anything else, never wnt back around to the back side of the TV, so this is why it had me absolutely baffeled, but it must been just makeing jst enought of a contact the first power on after I installed the replacement LED strip.
            Anyhow, here is the culprit. Somehow I must have caught my hand on the Ribbon cable runninng from the main to the PS, you would never see it unless you unplug it and flip it over to see that the ribbon is infact true and flush to end und of the plastic connector.
            So please moderator if you could please close this thread. Thanks guys for the quick immediate responses!
            • STKR123
              Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
              by STKR123
              As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
              I wonder if re-flashing the BIOS might be of any use here.
              As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
              There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
              11-03-2024, 06:58 AM
            • edugimeno
              Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
              by edugimeno
              Hi There!
              I'm trying to help my friend who owns a restaurant be just bought.
              He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
              It's stuck using, I guess, the 2 sided tape that comes with the strip
              The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
              09-05-2024, 09:34 AM
            • learnmore
              Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
              by learnmore
              Hello Community!
              CASE DETAILS
              Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
              13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
              Tried inserting firmware on USB and left it in for a few hours, but no change
              03-03-2024, 09:49 AM
            • adelage
              220v Led strip flickering
              by adelage
              Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
              I know that the best solution would be to get a voltage...
              11-03-2024, 09:49 AM
            • benareeno
              Adjustable dc power supply and tcl led strip
              by benareeno
              I wonder if i shorted the whole strip...where to put pos and neg to just light up a single diode...or the entire strip. The strip lit for a second...so maybe i fried it? What say you?
              I have an adjustable dc power supply and was trying around 9 volts.
              I have a pic of a single diode...where to put pos and neg terminals to light it up?
              Pic of middle of strip..is this where i light the entire strip?
              And pic of end...or does this light the entire strip?
              Where to put pos and neg for single diode..multiple diodes and the entire...
              07-11-2021, 02:31 PM
