Buying main boards for differnt TVs and swapping EPROM?
  • mattpd
    • Oct 2012
    • 302
    How likely is it to work if I buy a main board that is physically identical to my broken one but from a TV of a different size, and I swap over the original EPROMS onto the new board?
    It's more of a general question, but I am thinking of doing it with a 50" LG LCD TV using a 32" main board.
  • Diah
    • Feb 2013
    • 6544
    Re: Buying main boards for differnt TVs and swapping EPROM?
    physically identical not enough, the most important pin out, and the dump of eeproms to reprogrammed before built in.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      Looking the same is not enough. they need to be electrically the same too. Say you find the same board exactly. say both are Vestel OEM, but ROM and brand from a different MFG, The ROMs would need to be programmed before install or bad things will happen.
      Follow the white rabbit.
      • mattpd
        • Oct 2012
        • 302
        The ROM chips couldn't just be swapped over? I would think it would work unless they are married to the board in some way.
        • Diah
          • Feb 2013
          • 6544
          you are talking on eeprom, not ROM, ROM yes, but the eeprom shuld be reprogrammed before built in
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            I guess you never replaced a failed EEPROM on a board before... You can "live flash", its not recommended though. And yeah, I agree, you should remove the Eeprom and program before swapping boards.
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              I would assume that would work.... Though different revisions of the board may be have diferences making them incompatable. I have yet to see that on a TV though, so YMMV.
              • Diah
                • Feb 2013
                • 6544
                90% on TV i faced trouble with EEPROM solved by reflow and write over program. Live write.
                back to this topic i would love to see some one succeed so i can change my mind. or go back to studying more.
                • michael dranfield
                  • Jan 2016
                  • 232
                  • England
                  On modern sets the software files are so large data is stored on nand flash before been transfered to the main micro and usually spi eeprom so in theory it would be possible to transfer the chips from one board to another but usually the main micro is in a bag package so it would have to be re balled first so you could easily spend more time doing all this than the set is worth of you could buy the right board for .
                  • ZnsaneRyder
                    • Oct 2015
                    • 88
                    • Merica
                    Would you really truly need to swap the eeprom? If the TV's are similar other than size, I hope it would still work. As long as the screen ran fine, I would not care what size the mainboard "thinks" the TV is.
                    I am wanting to try this with some LG LED V's, they always kill mainboards, now I have a good one from a TV with a broken screen, so I am willing to try this in another LG TV, all the mainboards look identical.
                    • Diah
                      • Feb 2013
                      • 6544
                      lets take more deep in this sector, most firmware based Linux, except android or apple, for example i did it many time on TOSHIBA TV, with command WOAP.bin all firmware will be formatted, but the first sector keep its boot. and cannot erase it to write other bit for boot. in short talk each eeprom had its boot sector which communicated with DDR and other stuff.
                      • Moreno83
                        • Jun 2014
                        • 2008
                        • The Netherlands
                        Cant he just replace the boards and change settings in the service menu of the TV? Change panel type for example...
                        • Diah
                          • Feb 2013
                          • 6544
                          lets first TV BOOT UP then go to service menu
                          • Moreno83
                            • Jun 2014
                            • 2008
                            • The Netherlands
                            Haha ok true! But it might work....
                            • Diah
                              • Feb 2013
                              • 6544
                              ab 2012 most LCD LED back light, had more critic points, change main broad and PSU as both need handle vcom digital as well dim 1 and dim2 , beside all this it consider the Panel ID/ Type such as A,C,K some brands very hard to exchange Panel too, cause new panel will not power on after replace unless its brand written in eeprom. this is all related to ECO. not to buy new one.
                              • cheeky2
                                by cheeky2
                                05-25-2024, 03:27 AM
                              • Dani_2024
                                by Dani_2024
                                10-28-2024, 05:06 PM
                              • ygorsan
                                by ygorsan
                                🧩 Problem Summary:
                                • I
                                07-28-2025, 08:34 AM
                              • Asraf Atb
                                by Asraf Atb
                                01-27-2025, 05:02 PM
                              • Genghis_Khan
                                ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
                                by Genghis_Khan
                                I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
                                Issue summary:
                                Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
                                However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
                                11-11-2025, 11:51 AM
