Toshiba 37av500u screen flickering
  • woodman45
    • Aug 2015
    • 87
    • U.S.A
    Hello as the title says I have a Toshiba 37av500u where the screen is flickering and what I mean is the screen lights up dimly and goes off in a one second interval and continuous until you unplug the power cord.
    The power button will not stop the flickering or blinking whatever you want to call it.i took the back panel off and did a visual inspection no bulging or blown caps.also can see the backlight going on and off.
    I have not checked anything yet with the multi meter,I have searched and seen maybe the master or slave inverter may cause this issue but figured I would ask for help here before proceeding on any testing.
  • woodman45
    • Aug 2015
    • 87
    • U.S.A
    Re: Toshiba 37av500u screen flickering
    Another pic
    • woodman45
      • Aug 2015
      • 87
      • U.S.A
      Is there anywhere I can start testing.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        24v ok ?
        • woodman45
          • Aug 2015
          • 87
          • U.S.A
          Where do I check for the 24v?
          I'm a beginner I know how to use multi meter and test caps but I don't know exactly which board to start test.
          I thank you for any assistance and do want to learn instead of throwing parts at it.
          • woodman45
            • Aug 2015
            • 87
            • U.S.A
            Just to update I took a close look at power supply and tested all the 24v 12v & 5v pins on the board.the readings were very close or right on the money.such as all the 24v readings were 23.96 & 5v pins were 5.03 on my meter.
            So would it be safe to assume the problems lies within the master or slave inverter boards?
            If so is there any way to test them?
            Thanks for any help or suggestions as I would greatly appreciate them.
            I will include a couple pics of the power supply.
            • woodman45
              • Aug 2015
              • 87
              • U.S.A
              Here's a pic of the power supply
              • woodman45
                • Aug 2015
                • 87
                • U.S.A
                Another close up of power supply
                • multimeter
                  • Jan 2011
                  • 739
                  • united kingdom
                  try re-soldering all the inverter transformers..
                  fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                  please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                  • woodman45
                    • Aug 2015
                    • 87
                    • U.S.A
                    Thanks for the reply. I will give it shot and post my results back in the next few days.
                    • woodman45
                      • Aug 2015
                      • 87
                      • U.S.A
                      I resoldered all the transformers on the inverters and it's still doing the same.
                      • woodman45
                        • Aug 2015
                        • 87
                        • U.S.A
                        I replaced the master and slave inverters and still the same problem.does anyone have any suggestions or a service manual?
                        Im wondering if it could be a problem with power supply board?
                        • Ado02
                          Lenovo Thinkpad X1 Gen 10 - Flickering Screen
                          by Ado02
                          We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
                          The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
                          12-16-2024, 02:33 PM
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                          09-06-2024, 05:27 AM
                        • sigmeyer
                          Toshiba 50UL4B63DG faulty screen?
                          by sigmeyer
                          I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
                          08-30-2025, 08:13 AM
                        • reformatt
                          by reformatt
                          07-31-2025, 08:37 PM
