I've got a Vizio E421VA Tv in the shop and the customer says the volume goes up and down by itself. He uses Cox cable and I can't get it to repeat the problem. Has anybody seen this problem before? Bad Ir Sensor maybe or bad key controller? All the functions on the remote work fine and respond to all menu options fine. Thx
Vizio E421Va sound going up and down by itself
Re: Vizio E421Va sound going up and down by itself
If bad IR or Keypad I would expect it to either jam with volume going up OR down, not both.
You should see the volume OSD if it's a problem with either input anyway, did he confirm this? Did he say it happens with everything or just cable?
If the sound changes but no OSD shows up it's more likely a signal source or amplifier problem. Maybe the problem is his cable receiver.
First thing that springs to mind is there may be some slow oscillation in whatever circuit controls the gain in some part of the audio stage, somewhere in TV or cable box. Sounds strange though.
May have to check it out on-site..."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHorn
Assuming...7 Photos -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
by ggil44Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
by LEECH666Good day ladies and gentleman!
I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
I think the PSU buzzing comes from one of the coils near the bridge rectifier but... -
- Loading...
