Sharp TV LC32LE243M dead
  • kushal
    • Sep 2013
    • 11
    • nepal
    HELLO BRO
    I have sharp lc32le243m tv. Plug in ac cable tv only show red blinking light only. nothing short in board how to solve this problem. how to flash tv and where i download this tv framware and schematic.
    thanksss
  • vlado66
    • Apr 2015
    • 10
    • SLOVENSKO
    Re: Sharp TV LC32LE243M dead
    • kushal
      • Sep 2013
      • 11
      • nepal
      thanks bro.
      • Trofazni
        • Dec 2016
        • 71
        • Serbia
        I have problem with this model, it's lc-32le240e,
        It is able to power on and stay on, but no picture, and won't power down on button, buttons are touch buttons.
        i flashed firmware, not with this file but with one i found, and now the picture is red solid, with constant bilnking red/green indefinetly, as was before flashing firmware.
        Can you tell me what in wich ic should i program this .bin file that is attached, hoping to make tv functional again... I have no remote control for it, just to mention, but i will oreder one...
        All voltages on psu are ok, backlight up and running...
        Any ideas?
        • bajdik
          Sharp LC-40LE830E white blinking after wallplug is off
          by bajdik
          Hello, on Sharp LC-40LE830E is everything OK. Working great. If I put the 230 V off and on again, it just blinking white standby LED. I can power on only via VOL- and CH+ and POWER button on TV. After that, I can power off and power on again without problem (by buttons or remote control) until the 230 V is connected. If i put the plug off and on again, just white standby LED blinking. TV needs three button starting again.. On the first look, the backlight looks great, no darker or lighter spots. Any idea what is wrong?
          07-21-2023, 09:05 AM
        • Audeze
          Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
          by Audeze
          I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
          Does...
          10-06-2024, 08:54 PM
        • cm0002
          Sharp LC-55N7000U 1 long 5 short blinking, no display
          by cm0002
          I've got a Sharp LC-55N7000U. It has a standbuy LED when plugged in, but powering it on causes it to blink 1 LONG and 5 FAST. Theres no display and no backlight.
          Nothing I checked has that blink pattern for Sharp TVs and there's only one multi-button on the TV itself so that service menu trick involving the input button doesn't work either. Its a post-Hisense buyout TV so that probably makes sense lol
          I've tried disconnecting the panel sides from the TCON alternating sides, but no change in behaviour even when the whole TCON is disconnected,...
          06-19-2023, 06:21 PM
        • mecha1166
          QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
          by mecha1166
          I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
          03-28-2024, 08:31 AM
        • borstar_micke
          Dead Sharp Aquos LC-32LE430E
          by borstar_micke
          My 12y old daughters tv (that she got after her grandpa, has sentimental value to her) was just dead without stby light a couple of weeks ago.
          I´ve repaired a couple of computer monitors, classic blown capacitor replacements, a 55" Sammy led with t-connboard replacement and a 42" Panasonic edge led where I replaced the led-strip.
          Not a master with the multimeter, which is cheap and 10-15year old btw...
          So please make it basic...
          To the issue at hand.
          As stated, the tv is totally dead with no standby light....
          03-23-2023, 09:14 AM
