Panasonic TH-42PH9UK Power board failure
  • 429moore
    • Feb 2016
    • 3
    Yesterday my Panasonic Plasma display TH-42PH9UK died. Wouldn't show any power indication or standby lights.
    Found Power board (TNPA3911) has two blown T8HA input fuses. 8A 250V
    Also found the following defective components.
    Q406 - Transistor shorted
    R410 - Thermal fuse open
    D411 - Diode open each direction
    I see many repair kits available that include the fuses & Q406, R410. Problem is I cant find D411. The diode has red markings with T2D66 and I'm not sure how to cross reference.
    Does anyone have recommendations on where to obtain a service manual? Most online PDF downloads appear to be malicious.
    Regards
    Bob
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Panasonic TH-42PH9UK Power board failure
    There's a diode--That Doesnt read right--as you would expect--on many Panasonic PSU's...
    Its in fact a Diac--which is like two Zeners back to back...
    Try just with the other parts--I doubt that diac has suffered...
    TELEFIX
    • 429moore
      • Feb 2016
      • 3
      Ah now that would make sense! I will order the repair kit and hopefully all will be good! I really appreciate the feedback.
      Thank You
      Bob
      • npielawski
        MacBook Pro late 2016 (820-00239) with multiple failure modes.
        by npielawski
        I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
        I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
        10-15-2025, 01:53 AM
      • BigPete
        Panasonic Heatpump Dryer Repair
        by BigPete
        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
        Unfortunately the whole machine has to come apart to fix it.
        I have...
        11-01-2025, 06:40 PM
      • Andre Gilbert
        by Andre Gilbert
        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
        11-20-2024, 08:52 PM
      • AquaMan Ua
        by AquaMan Ua
        05-17-2025, 09:40 AM
      • puccovelli
        Dell 9310 Memory or RAM (Random-Access Memory) failure (2,4)
        by puccovelli
        Hi all, I hope this is the right place to post.
        I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
        I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
        1] Could someone confirm what the component that has blow actually is (and where I could get another from).
        2] Whether this component is likely to cause the RAM failure issue, and if replacing...
        10-11-2025, 06:30 AM
