Panasonic TH-42PH9UK Power board failure
  • 429moore
    • Feb 2016
    • 3
    Yesterday my Panasonic Plasma display TH-42PH9UK died. Wouldn't show any power indication or standby lights.
    Found Power board (TNPA3911) has two blown T8HA input fuses. 8A 250V
    Also found the following defective components.
    Q406 - Transistor shorted
    R410 - Thermal fuse open
    D411 - Diode open each direction
    I see many repair kits available that include the fuses & Q406, R410. Problem is I cant find D411. The diode has red markings with T2D66 and I'm not sure how to cross reference.
    Does anyone have recommendations on where to obtain a service manual? Most online PDF downloads appear to be malicious.
    Regards
    Bob
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Panasonic TH-42PH9UK Power board failure
    There's a diode--That Doesnt read right--as you would expect--on many Panasonic PSU's...
    Its in fact a Diac--which is like two Zeners back to back...
    Try just with the other parts--I doubt that diac has suffered...
    TELEFIX
    • 429moore
      • Feb 2016
      • 3
      Ah now that would make sense! I will order the repair kit and hopefully all will be good! I really appreciate the feedback.
      Thank You
      Bob
      • Andre Gilbert
        by Andre Gilbert
        Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
        Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
        11-20-2024, 08:52 PM
      • AquaMan Ua
        by AquaMan Ua
        05-17-2025, 09:40 AM
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        The TV does not turn on, the standby indicator is on. All voltages are present.
        Emms is dead. Not readable, not detected.
        Replaced emmc.
        But with another dump there is no launch
        Terminal log
        UART
        AC_ON
        RPMB key is not yet programmed
        HASH1_VERSION=0x00000000 64bit
        E-B
        FDE enabled
        layout pattern onebin by SAR7,0...
        06-01-2025, 02:11 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • ctroxtell
        Carrier HK50AA063 display controller common failure help
        by ctroxtell
        I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
        02-05-2025, 05:31 PM
