Toshiba 50L1350UC No Backlight
  • rikrikrik13
    • May 2013
    • 44
    Hi, I got this Toshiba TV without backlight.
    Flashlight test : Yes I can see the image
    Voltage test on L1+ : turn on tv, backlight flash for 1/2 second, voltage goes to 90v then 76v
    Tried to disconnect PWN : No more backlight flash, voltage won't go higher then 76v on L1+
    What you guys think? bad led or something else?
    Re: Toshiba 50L1350UC No Backlight
    You can start with this:
    https://www.badcaps.net/forum/showthread.php?t=39740
    • rikrikrik13
      • May 2013
      • 44
      hi, I don't know what kind of picture you need. I can post a picture of the blank screen if you want :p
      Just kidding, here's a picture of the power supply taken from the internet
      • rikrikrik13
        • May 2013
        • 44
        I know this is a common issue, that's why I asked without pictures. All the voltage seems fine.
        I saw somewhere a way to fix that if we bridge some terminal, but I can't remember
        • nickmatine1
          • Mar 2017
          • 8
          • usa
          did you fixed your tv?
          i have same issue
          • YvD-Electronics
            Request BIOS files to flash Toshiba C55-A-1TX laptop
            by YvD-Electronics
            I need the BIOS (bin files) to re-flash the BIOS chips on a toshiba laptop.
            Why I am pretty sure I need this to repair?
            1) Power supplies seem OK.
            2) Battery has been replaced, is charging well ... also not the CMOS battery CR2032, also not OK without RAM, or 1 or the 2 RAM modules (RAMS are OK).
            3) Laptop does really rare (seems random things) with the 3 leds (power, net, ...)
            4) In the past, when trying to restart 100 times via power button, it was sometimes succeeding, now no more.
            08-09-2024, 10:05 PM
          • Sevenqi
            Toshiba 50L420U/49L310U Flash Toshoba logo then no backlight
            by Sevenqi
            Toshiba 50L420U/49L310U TV, press power button, it shows Toshiba Logo then backlight off.
            Tested the backlight stripes with backlight tester, all 3 sections seem to be good.
            The problem is the power supply PK101W1100I , 2 backlight feedback resistors open in my case, the value mark 101, they are both 100 Ohm.
            I replaced the 2 resistors with same value fixed the problem....
            08-31-2020, 01:05 AM
          • thetonywarren
            TCL 43S435 NO BACKLIGHT ISSUE, LEDS TEST OK
            by thetonywarren
            I have a TCL 43S435 with no backlights. I contacted ShopJimmy and they said power supply. I got replacement power supply, but still doesnt work. I have confirmed that there is an image with flashlight test. I have also verified that the led strips work when I probe them with LED tester. Any ideas would be helpful. I am also geting a double blink on the status led when trying to turn it on......Nothing on the power supply looks suspect, and caps look ok. Where should I start to test......Thanks!...
            04-23-2025, 10:48 AM
          • ekozeko333
            [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
            by ekozeko333
            I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
            🔥 The Problem Started After Suspected ESD/PD Fault
            I experienced a power issue or ESD event through a USB-C charger
            After that, the NX20P5090 power switch was visibly burned and was replaced
            Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
            🧠 What I’ve Done So Far
            Flashed...
            06-21-2025, 02:48 AM
            09-06-2024, 05:27 AM
