Lg 32lh30-ua
  • Syryll
    • Jul 2012
    • 32
    Lg 32lh30-ua
    Having issues getting this set to start and run after changing the backlight brightness. I was having issues with it not "cold" starting after a power outage, but I was always able to get it to start after the second power on attempt. When I turn the set on, it attempts to turn the backlight on (I get 1/4 second or so of backlight) and then it shuts down.
    PSU voltages read as follows:
    24v: 21.88v
    12v: 10.86v
    5v: 5.12v
    Under "first start" condition, 12 and 24v only read at around 1.5v and I have to restart the TV to get the voltages to come up to the respective 10.86 and 21.88v.
  • michael dranfield
    • Jan 2016
    • 232
    • England
    Re: Lg 32lh30-ua
    You need to check the voltage across the main reservoir capacitor it should rise to about 385v when the set fires up , if it does not the PFC circuit is not working and it is more likely to be surface mounted resistors fallen in value , I dont have the cct ref but they are easy to find on the back of the board there will be 3 0r 4 all in series from the reservoir capacitor to the PFC control chip, they will be something like 600 Odd K ohms from memory and there value is critical to the working of the set.
    • Syryll
      • Jul 2012
      • 32
      Re: Lg 32lh30-ua
      I actually did test those two caps. They both read 220v. I'll check that out when I make it home.
      Thanks!
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Re: Lg 32lh30-ua
        Try heating the Psu with a hair drier see if the Tv comes on faster my bet is a bad startup cap.
        • SoulFreeze
          Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
          by SoulFreeze
          Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
          After repairing the above issue, I realized the following remaining problem,
          Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
          The computer recognizes headphones are connected and displays a popup in windows
          Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
          06-21-2025, 09:53 AM
        • Nagyesz
          Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
          by Nagyesz
          I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
          All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
          How can I extend its lifespan? Could reflow help?
          It has ryzen 5 5500h, rtx 2050, no soldered ram.
          Example of the artifacts:
          03-01-2025, 11:11 AM
        • pwnjuice
          Bitlocker issues
          by pwnjuice
          Customers laptop had a Motherboard go bad and replaced it. they want to try to get data but. I am having bitlocker issues. I will list below
          Issue 1: When connect the drive to my computer to decrypt it I get this message. "there are no supported protectors on this drive the drive cannot be unlocked"
          Issue 2: When I run powershell as admin and try manage-bde -protectors -get e: I get this message. " ERROR: An attempt to access a required resource was denied. I also get the same error when I try manage-bde -status e: When I try the same with terminal with
          01-06-2025, 05:33 PM
        • Skgod
          Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu
          by Skgod
          Hey I am having Asus Rog strix g15 g513ih hn0865 and it's having display issues while running on igpu. Works fine when I open any game or whatsapp windows application. The issues are :
          Black screen, freeze
          The weird thing is that when as long as the laptop is running on igpu the problem keeps happening. But as soon as I open any game or whatsapp windows application, the laptop works completely fine.
          When the screen freeze or black screen I used to move the display lid up and down and it usually works like that.
          So can anyone tell me what would be the possible cause?...
          10-16-2024, 08:11 PM
        • duwane
          A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
          by duwane
          Hi All.
          Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
          The issue:
          Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
          10-26-2022, 07:02 AM
