Murphy 19" tv/dvd/pc/hdmi] HDMI Problem?
  • PhaseCoder
    • Nov 2013
    • 62
    • Uk
    I was given a 19" LCD Murphy TV and told the HDMI doesn't work, everything else works perfect, I'm currently typing this onit via my laptop.
    When I plug my amazon fire stick in, it goes from no HDMI signal, picks it up but screen is black, but tells you top corner screen size etc.
    If I unplug the amazon stick from the mains and then plug back in, it will show the amazon screen for about 3 seconds then go back to a black screen.
    Am I able to fix this? if so were do I start? I'm quiet good with electrics etc.
    I have searched online, searched and searched but nothing seems to match my problem .
    thanks in advance
  • PhaseCoder
    • Nov 2013
    • 62
    • Uk
    Re: Murphy 19" tv/dvd/pc/hdmi] HDMI Problem?
    anyone?
    in short
    1) turn tv to hdmi(shows no signal sign)
    2)plug amazon fire stick in(above signal sign goes) but screen stays black
    3)unplug amazon stick, put it back in tv displays the amazon screen for 10 seconds
    4)goes back to black screen
    • budwich
      • Jul 2015
      • 3097
      sounds like a hdcp issue. are there any firmware updates for the TV. Of course, you tried another cable. You have tried setting the resolution to 720p (or whatever lower res on that side of the pond) on the fire. Have you tried the fire on a known working set... what resolution was it "defaulting" to? what resolutions does a murphy support?
      • PhaseCoder
        • Nov 2013
        • 62
        • Uk
        Yea i tried other cables etc, the amazon fire stick works perfect on another tv, and thats what it auto sets at 720p???
        • PhaseCoder
          • Nov 2013
          • 62
          • Uk
          also when i say goes back to black screen, it doesnt go to the screen that displays "no signal" so its picking it up but just leaving a blank screen?
          • budwich
            • Jul 2015
            • 3097
            what resolutions are supported on the murphy?
            • PhaseCoder
              • Nov 2013
              • 62
              • Uk
              its only a 19
              1366 x 768
              and 720p
              • budwich
                • Jul 2015
                • 3097
                OK . What outputs does your pc support? Are you able to select a 720p one and make it work. Related to this res question, what hdcp spec is supported by the murphy?
                • PhaseCoder
                  • Nov 2013
                  • 62
                  • Uk
                  im using the laptop through the other output not the HDMI
                  • aliougm
                    Marantz SR4003 AVR HDMI board issue, seeking for help
                    by aliougm
                    I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
                    Connection as below:
                    Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
                    If I bypassed AVR then HDTV screen color be good.
                    I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
                    3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
                    I replaced all...
                    04-30-2022, 12:21 PM
                  • japlytic
                    Certain DisplayPort-HDMI cables can disable HDMI CEC communication
                    by japlytic
                    With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
                    An examination of the HDMI CEC wiring...
                    07-10-2022, 09:48 PM
                  • spleenharvester
                    Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
                    by spleenharvester
                    I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
                    I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
                    03-12-2025, 03:42 PM
                  • RossMoodley1967
                    LG LCD TV HDMI PORT FAULTY
                    by RossMoodley1967
                    LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
                    02-28-2024, 08:38 AM
                  • RatherLoopy
                    Pioneer VSX-44 receiver HDMI dropouts
                    by RatherLoopy
                    I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                    I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                    And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                    05-26-2023, 03:54 PM
