Another LC-80LE632U 2-5 thread
  • budwich
    • Jul 2015
    • 3097
    Re: Another LC-80LE632U 2-5 thread
    I would see if you can get into the service menu to check the error counters to see if they point at anything. Still appears to be a backlight issue... maybe "poor board work"... :-)
    • budwich
      • Jul 2015
      • 3097
      just adding that you might have to "zero" the error counters to cause the set to operate correctly. This has to be done from the service menu or they are not reset otherwise.
      • kimarcher_gy
        • Sep 2016
        • 34
        • Guyana
        #63
        I am not getting to go into the Service Menu I just get a flash of the backlight.
        I left it disconnected overnight and when I switched it on today I got a view of the Menu long enough to tune all the cable channels then after that the backlight went off but if I switch the TV off then back on I just get a flash of the Menu or Channel. I made a video of this event but the file is around 190mb so I did not upload same.
        I did a re-check of the voltages at connector PD without backlight and a steady Power light and got the following results in the attached jpeg file.
        • kimarcher_gy
          • Sep 2016
          • 34
          • Guyana
          #64
          Please see attached Jpeg with the voltages on all pins.
          • budwich
            • Jul 2015
            • 3097
            if I understand the readings (limited experience), the system is erroring.... but I don't see anything else. :-( maybe someone else will have an idea. might want to post pictures of some of your "board work" just in case people can spot something.
            Further, from your last statement, I take this that IF you leave it unplugged overnight, that you were able to get something done (scanning of channels). IF this (menuing) can be achieved again (regularly... one day wait), then again you should try and get into the service menu and look at the error counters to see which may be pointing to an issue although it still might be backlighting related.
            Still further, my understanding from reading some of the service manual of "similar sets" that there is a boot up process that turns off the "lamp error detection" so that the set will "run" without causing a lamp error related shut down.... if you use this and it still shut down, there is a significant issue.
            • kimarcher_gy
              • Sep 2016
              • 34
              • Guyana
              #66
              Please see attached picture files of board work on installation of IR2E67M chip.
              • kimarcher_gy
                • Sep 2016
                • 34
                • Guyana
                #67
                Please see attached picture file of TV screen just before the backlight came off .
                • budwich
                  • Jul 2015
                  • 3097
                  some of your pictures appear to show "foreign lines" running from one pin to another. Ensure there is no "contamination" between pins as the high voltages may "leak" thru to areas they shouldn't be.
                  Might be a main board problem if the "power strike" caused a weakening of a component (eg. capacitor). Might look for a replacement board somewhere.
                  • kimarcher_gy
                    • Sep 2016
                    • 34
                    • Guyana
                    #69
                    There are some left over Fibers from a Cotton Cloth that I was cleaning the pins with.I used Isopropyl Alcohol to get off excess soldering flux .
                    • kimarcher_gy
                      • Sep 2016
                      • 34
                      • Guyana
                      #70
                      Please see attached picture file with some data on the IR2E67U chip.
                      • kimarcher_gy
                        • Sep 2016
                        • 34
                        • Guyana
                        #71
                        That should be IR2E67M.
                        • kimarcher_gy
                          • Sep 2016
                          • 34
                          • Guyana
                          #72
                          Hello all, "Happy New Year".
                          The present state of the TV is as follows:-[1] I have installed the original Power Supply Board after replacing the Backlight Driver IC .[2] I have replaced the Main Board with the original Board after reflowing the Power supply connector soldering joints, [3] I replaced the T-CON Board with the original board and replaced the two flat ribbon cables with new ones due discolored ends and corrosion.
                          Presently I am getting Video and Audio and images on screen without backlight . and if I unplug the Power cord it goes back to 1S-1F Blink error.
                          The Back light is not coming on even if I leave the TV off overnight I came to the conclusion that the Rainy weather is making the TV Circuit Boards operate sluggish so I placed two lights behind the TV to keep the boards warm.
                          I am getting +127 VDC on all the pins of the LED positive wires and 1.8 VDC across the Collector and Emitter of all the Main Driver Transistors (KCY4217 or C4217 )
                          Please see attached voltage chart with present voltages in this condition.
                          The E-Bay T-CON Board that was removed was working satisfactory .
                          The E-Bay Main Board removed ,was not getting Video or Audio because I did not get to complete the auto tune cycle with it but I believe it's serviceable.
                          • budwich
                            • Jul 2015
                            • 3097
                            although the voltage on the led drivers is important, it isn't necessarily the sole "thing". The system is actually relying on current and if you are exceeding the current spec (likely because of a "poor led") then it may be shutting down. The ERROR line is still high. As suggested, you should be able to "force" the backlights.
                            • kimarcher_gy
                              • Sep 2016
                              • 34
                              • Guyana
                              #74
                              I have done some reverse engineering to draw a part of the Power Supply Schematic for P/N: RUNTKB096WJQZ. It's a work in progress but from this diagram you could do a modification to fool IC7002 about the current hopefully. The alternative is to change all the LED, s with new ones which is very expensive as recommended by a Technician on Fixya.com. I have removed the whole panel with the Back light LED's and tested them and they are all displaying with the same brilliance.
                              • Robottom
                                • Jun 2017
                                • 41
                                Hi folks, I am new to the forum and haven't figured out how to start a new thread or if I'm even allowed to do that yet. Anyway, I'm hoping someone can give me a little help with what I think is a similar problem to what's being discussed in this thread.
                                I have a Sharp LC-80LE642U that just started giving me the 1s - 1l blink code, nothing visible on the screen. I have it off the wall and back stripped off laying face down on a bed in our spare room. I am pretty familiar with electronics, but far from an expert.
                                I'm trying to figure out if I can force the power supply to stay on so that I can see it is powering the backlight LEDs. I saw a UTube video (https://www.youtube.com/watch?v=fBWX34wTULw) where he disconnects the cable from the main board and used jumpers and switches to simulate the inputs from the main board to fool the power board. Unfortunately I do not have the same power board and the pins he was jumping are not all available on my board. I have RUNTKB096WJQZ which does not have any pin marked PWM1. The reason I want to do this is to make sure that the power board is actually good before tearing apart the LCD panel. This is a BIG HEAVY and EXPENSIVE TV, so I'm trying very hard to test the easy repair stuff before going any further.
                                I guess, what I really want to ask is if there is a way to positively test each of the boards to be sure they're good before doing anything else. I'd like to start with the power board.
                                I did see in this thread someone recommended disconnecting the ribbon cables going from the TCon board to the panel, but I wasn't sure if that would help me test the power board and light up the LEDs.
                                Anyway, I have tested voltage from the power board out of pins 1, 3 and 5 on connector L1, which I believe is power + to the LED strips, and got ~130 VDC for a short period after plugging the TV in while holding Input and Vol - simultaneously. I am pretty sure that's good, but not 100% confident that means the problem is one or more of the LED strips. As, above, this is a big honking piece of equipment and I really don't want to go there if I don't have to.
                                Any help with board testing especially power board would be appreciated. If I have to open the panel, I'm pretty sure I can manage testing the LED strips even though that wouldn't eliminate any of the boards as part of the problem. I am assuming that if I go that far and all the LEDs light up, one of the boards must be bad, but then ... which one?
                                Thank all of you in advance for any help.
                                Best Regards,
                                Tom
                                • kimarcher_gy
                                  • Sep 2016
                                  • 34
                                  • Guyana
                                  #76
                                  Hello ,Robottom.
                                  You could follow the Link to get a Service Manual for your model;- https://www.manualslib.com/manual/11...?page=5#manual
                                  The Service Manual does not have a diagram for the Power Supply Board,however is has the same part number as the one in the Service Manual for the LC-80LE632U TV.
                                  You could test the fifteen LED rows from the connector the information of pin out is written on the board. There are thirty LED in series in each row.
                                  • kimarcher_gy
                                    • Sep 2016
                                    • 34
                                    • Guyana
                                    #77
                                    I have made a correction to the Diagram of the LED power supply where the two connectors L1 and L2 were labelled incorrect .This diagram covers only four rows of LED's out of fifteen all of which connect to different pins of the IC in a simular way .I have purchased another new Board with the same Part Number quoted in the Service Manual ..I will do a resistance test before to check for leakages of current to chassis simular to the test below.
                                    I will be re-testing the LED's by leaving the Connector L1 plugged in and applyng 147 Volts Positive from the LED tester Red lead to pins 1 which connect to all the fifteen rows of LED anodes and testing the Cathode side with the connector L2 disconnected and selecting each of the pins that goes to the first Cathode of each row. The information is marked at the side of the connector . I would be monitoring the Current of the Positive lead of the tester for leaks to ground.
                                    • kimarcher_gy
                                      • Sep 2016
                                      • 34
                                      • Guyana
                                      #78
                                      Hello members I must say to you that I have come to the realization that some or all Led Lamps loose their brilliance after a couple of years .I have been using a 13 watt 1200 Lumens LED lamp for a couple of years and it is presently about half it's original luminance .so I decided to change all the Back-lighting Leds for the 80 inch Sharp in a couple of days . I am purchasing a Power Supply Board and a complete set of LED's from a damage Screen 80 inch Sharp TV.
                                      I tried modifying the Sharp Power Supply board to fool the IC 7201 that the LED's are drawing a lower current by reducing al the sensing resistor by a half of it's value but the 3.3 Volt regulator a very small six pin IC went defective and I cant get the number to replace same .
                                      • kimarcher_gy
                                        • Sep 2016
                                        • 34
                                        • Guyana
                                        #79
                                        I am seeking some guidance for my next move .
                                        After changing the LED, s and the Power Supply Board with ones from a cracked screen TV I got the TV to work for about three days. The next day it refused to come on so I did normal reset by pressing V+,V- and CH- and I got it to work with ΒΌ of the screen missing on the left side. but after a few minutes it would go to a 2-3 code . I don't want to start ripping out the left side board ribbon cables until I am certain there is no other fix for this. Please see the attached when it was working good and the present condition .My two spare T-CON boards are not working but I am getting 500 ohms from the 12 v pins to ground. I am using the T-CON Board from the cracked screen TV mention above.
                                        The Power Supply board is an older type as listed in the Service ,Manual for the LC-80LE632U.
                                        • budwich
                                          • Jul 2015
                                          • 3097
                                          that problem IS NOT an issue that can be solved by removing the side tabs so don't go there. you have an issue at the bottom of the set. IF you disconnect the left side (from the front) tcon to panel cables, what happens to the screen display? Check the tabs along the bottom along with the edge boards.
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                            I am comparing them to a brand new one that I installed
                                            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                            I going to let it run for several days before I remount back on the wall next to the...
                                            09-05-2024, 06:48 PM
                                          • netgearnetgear
                                            TCL 43S423 TCON OR PANEL FAULTY???
                                            by netgearnetgear
                                            Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
                                            08-20-2025, 06:04 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
