Bush bpdp42hd3 plasma no picture but TV stays on.
  • gizmouk
    • Sep 2014
    • 19
    • United Kingdom
    I've got a Bush bpdp42hd3 42" plasma. When I turn it on the relay clicks on and there are small white pixels at the bottom of the screen for a second and that's it. The green light on the TV stays on. I've tried switching sources to find out if there is any sound coming through and there isn't.
    So I opened up the TV and visually I can see nothing. I tested the usual points, VScan, VA_TP, VS_TP, Ve, PS_on etc. When the TV is switched on the voltages are correct but then the voltages drop to near zero.
    I've unplugged the boards and still the same. So I decided to do the Logic Board test where you short the pins. I read to short the PS_ON and GND to the Main board and it should click. Then remove the cable to the main and short pins 3&4. I tried this and I got nothing.
    So as a test I thought what would happen if I short pins 1&2. I turned on the tv and the screen came on all pixelated with a white pixelated band running across the top. The screen was changing but the screen was very pixelated. Then I could smell burning. It was coming from the Y buffer board the 2nd chip from the top. I quickly turned off the TV. I left it for a while and connected everything back up and turned the TV back on. There was no more smell of burning and its the same problem as the beginning. You can turn the TV on and the green light on the front of the TV is on but no picture. The green light on the logic board flashes for 5 seconds then off again and repeats.
    Sorry I've written a lot. I'm a bit lost now as to what the problem is. Is it the Logic board or the Main board as the readings on the X and Y are good until the power drops.
    Any help would be very much appreciated. Thank you.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Bush bpdp42hd3 plasma no picture but TV stays on.
    Rebadged Samsung D450 probably shorted Y and Xmain, please upload images of the Tv.
    • gizmouk
      • Sep 2014
      • 19
      • United Kingdom
      Thanks for replying. It won't let me upload from my mobile so will upload them tonight when i'm on the computer.
      • sordids999
        • May 2013
        • 2161
        https://www.badcaps.net/forum/showth...ight=bpdp42hd3
        • gizmouk
          • Sep 2014
          • 19
          • United Kingdom
          Very interesting read, thank you. The TV only gives 2 clicks then no picture. From reading the post and thinking of what happened when i ran the test pattern test, smell of burning and not a clean picture. I think the Y-buffer is worth replacing. I did buy some IC's a while back but have lost them some how! Anyhow I'll do a check on the buffer and see how much they are to buy.
          Thanks.
          • gizmouk
            • Sep 2014
            • 19
            • United Kingdom
            Just a few quick snaps of the inside. I really should have taken a photo when I ran the test pattern check but I found a similar photo online of a tv. My TV had the lines going horizontal and as mentioned before a white band running across near the top.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Post was a fail, delete.
              • Alastair E
                Chief Womble
                • Mar 2013
                • 1963
                • U.K.
                Err--You had smoke coming out of a buffer-chip....
                So, The buffer needs replacing--Along with other stuff too maybe....
                It'll Never work with a burned buffer-chip stop trying to Make it work--Until the buffer board is replaced with good one, or you'll kill a whole lot more--if you already havent!....
                TELEFIX
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Shit I totally misread that haha Yeah I think your buffer might need some work as well as the Y and Xmain
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    My Ipad is messing up tonight and thread isnt loading properly. Please delete.
                    • KYBOSH
                      Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                      by KYBOSH
                      Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                      No picture but you hear the TV static (white noise) playing loud and clear.
                      The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                      But it seems they didn't get too far and just left it.
                      When I first took a look I was amazed at how pristine the inside looked.
                      Its as if the TV had been in a time capsule.
                      Caps looked like they were just pulled off the self.
                      Copper coils had no sign of corrosion on...
                      02-01-2023, 11:10 PM
                    • KYBOSH
                      Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                      by KYBOSH
                      Saved this beast from the landfill this weekend.
                      Manfactured July 2013 in Mexico.
                      I love working on plasma TVs.
                      Its been a while but I was lucky enough to find 2 this week.
                      The TV powers on and stays on but no picture. Havent checked for sound yet.
                      No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                      Will start troubleshooting tonight.
                      10-17-2024, 01:17 PM
                    • Tr0ll
                      by Tr0ll
                      Original T-con:
                      First replacement T-con:
                      10-07-2023, 07:48 PM
                    • JJAAMM
                      by JJAAMM
                      Problem
                      07-06-2023, 06:01 AM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
