does this ring a bell with anyone?
  • jimbofz
    • Apr 2013
    • 539
    • uk
    Im aware there are hundreds if methods to enter s menus on tvs.
    i finally found access to TEVION LCD42031D factory mode
    either source or menu then 2580 . or red,grn,blue yellow
    but the curious thing is you have to set the volume to 15 first ,
    now ive never come across this and am wondering if anyone else has?
    a lot you have to set vol to minimum or select ballance in sound menu then enter the four numbers
    the problem i have is,
    i cant move foreward from the first factory menu to complete the setup
    any changes in factory menu store ok ,but i need to move to next menu for other settings .so if the vol to 15 rings a bell please let me know .
    the info so far was from a russian site apparently this chassis was sold under the brand name MYSTERY
    main board no:mhdv 4201 chassis zc01-01b
  • jimbofz
    • Apr 2013
    • 539
    • uk
    Re: does this ring a bell with anyone?
    any ideas or comments ? please
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • RRice25541
      Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
      by RRice25541
      So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
      the color is all outa wack, like the settings have been corupted,
      I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
      so
      The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
      when i bring up the menu and type the pass codes to access either mode the menu disappears...
      05-13-2022, 10:44 PM
    • HP32Sii
      Philips 50PUS6262/12 (chassis TMP17.7E LA) no picture
      by HP32Sii
      This is my first post on this forum, and my first attempted repair of a modern flat-screen LCD-TV (though I have repaired a few LCD-monitors, all with Elco-problems (high ESR). I have repaired my fair share of TV-sets and VCRs in the past ('90s) and was fairly familiar with the different Philips chassis (KT-3M, K12, K2, K3, K7 are some that come to mind). So I have a fair bit of experience on old sets. Obviously, modern TV sets are quite a different cup of tea.... no HOT or flyback-transformer inside, for starters....
      The set came into my possession by accident,...
      02-26-2023, 10:00 AM
    • Retro140
      Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
      by Retro140
      So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
      To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
      06-18-2023, 06:13 PM
    • Ierwin
      Philips 58PUS7805 Menu working but no/weird picture from video sources
      by Ierwin
      I got a 58pus7805 that shows some weird behavior.
      The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
      However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
      I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
      I managed to install the latest official firmware by holding the control button while plugging...
      03-10-2024, 12:50 PM
