troubleshooting TV SMPS sequence
  • ilikesteel
    replied
    Re: troubleshooting TV SMPS sequence
    update
    guys,
    just a little recap, I should have included this.
    separate 5V stndby on a small board. that's working. remote turns on the relay on the stndby 5V supply and that allows the 120vac to be applied to the main SMPS.
    main SMPS shows 20V on the +24 rail and 2V on the +12 rail. I removed the PS connection, Conn3 which has all the outputs going back to the scaler board. so there is no load on the main SMPS. I still get the same results.
    when I first received the TV and knew the stndby 5V was working, I arbitrarily
    swapped out the 6 capacitors in the two output sections, 3=1000uf 16V for the +12 and 3 =1000uf 35V in the +24 rail. they were Panasonic FR series caps.
    That's where we are right now. I made the above tests as indicated. so far from the replies and my testing, doesn't seem to anything jumping out as a bad component. I would like to save this from an early grave. I've included a pic of the 1W 5V stndby board and SMPS. my original post was" RCA L37WD12 Won't Power Up". I got so far with that one and the replies stopped coming. then badcaps was out for a week changing to a new server.
    I thought I'd re-post a little differently because I wanted to find the logical sequence in troubleshooting a SMPS. If I can learn the sequence I may be able to make more checks before posting a problem. I got as far as checking the main cap for voltage. I did have 360V at the main cap. I was clueless after that, then I posted this post about troubleshooting sequence for a smps.
    Thanks for everyone's patience. I won't try and fire this one back up until I've had some more input from any of you. there's no other forum like this one, not one.
    Thanks,
    ilikesteel
  • R_J
    replied
    why put a 1k resistor to ground? I thought you had problems with the +12 volt supply not working and the +24 was working but only +20 volts?
    Does the power supply still work?
    It can't be any simpler. T1 has 2 secondaries, 12-14 is for the +24volts. 10-11 is for the +12 volts, These supply a/c (20-30 khz) to ds3 and ds5 which rectifies the a/c to dc and goes through ls1b and is filtered by cs32 and cs7. the dc also flows through ls6 and is further filtered by cs8 which gives you +12 volts.
    Try and measure the ac coming from the transformer, 12-14 should be close to +20vac
    10-11 should be around 10vac depending on the meter etc.
  • ilikesteel
    replied
    My apologies. here's a close up of the underside of the PS for the parts we're talking about. sorry!
    ilikesteel
  • ilikesteel
    replied
    update
    CapLeaker, Barton, R J,
    ran into a dilemma trying to put a 1K resistor from junction of RS22 and RS23 to GND.
    first I re-soldered the DS3 and DS5 diodes back on the board. I re-soldered the transformer, caps, and coil connections on both supplies.
    when I went to identify the resistors RS22 and RS23 on the underside of the board, RS22 appears not to be on the board. it looks like a blank space where it should be.
    RS23 is a 6800 ohm resistor. the marking on it indicates that (682). it truly measures 6.8K across the resistor.
    RS22 should be a 15,000 ohm resistor (153). there are no resistors in that area marked 153. Also, on the schematic, RS24 should be a 15K ohm resistor, but it's not. It's marked 18 followed by a 0 or a C.
    there's a blank for RS22 and also for DS23 which the cathode should be connected to RS22 as shown in the schematic.
    I haven't tried applying power to the supply. I thought I should check first with you guys to see what the next step should be.
    Thanks,
    ilikesteel
  • CapLeaker
    replied
    Resolder the transformer T1 and the inductors, diodes, capacitors on the 12V and the 24V. When you get it back together, if still doesn't work, I'd be putting an oscilloscope to it.
  • ilikesteel
    replied
    Dick Barton,
    will try that tomorrow. I need to reinstall DS3 and DS5 back on the board.
    thanks,
    ilikesteel
  • dick_barton
    replied
    Assuming the +5V standby is working and you have you unplugged the power supply from the rest of the circuits, put a link to ground from the "On/Off" pin (junction of RS22/RS23) via say a 1K ohm resistor to bring the other supplies up.
    If they come up and the +24V is working but not the +12V then I would have a good look at what has already been mentioned and check DS3 & DS5 and associated caps CS32, CS7, CS8
    Edit
    Diodes are best checked out of circuit.
  • ilikesteel
    replied
    Dick Barton, R J, CapLeaker,
    What's the next logical step? it seems like the readings I've made are within spec, but I'm still in the doghouse. the latest results were done at the diode/2K range.
    Thanks,
    ilikesteel
  • dick_barton
    replied
    Hello ilikesteel,
    The parallel combination of 1.5K resistors on the 12V line would give you a reading of .75K so that reading is close to what you would expect.
    (I assume you mean .700K ohms and not ohms.)
    If so the 5 resistors in parallel which on the schematic are 3K would give you 0.600K ohms (600 ohms) so the readings you have given above would be correct.
  • ilikesteel
    replied
    UPDATE
    Dick Barton,
    measured across one of the 1.5K resistors and I got a reading of .700 ohms on 2K diode scale.
    measured across one of the 33K resistors and got a reading of .576 ohms ohm on the 2K diode scale.
    Both diodes are out of the circuit with the above measurements.
    Thanks so much, I hope we can isolate this bugger.
    ilikesteel
  • dick_barton
    replied
    There are 2 off 1K5 resistors in parallel on the 12V line at its output point so I would expect you to read 0.75K (750 ohms). There are also 5 off 3K resistors in parallel with the 24V output so I would expect you to read 0.6K (600 ohms)
    Regards
  • ilikesteel
    replied
    Update
    CapLeaker-R J,
    double checked 24V to GND, on 2k scale, .290.
    double checked +12V to GND, open on 2K scale, 7.40 on 20K scale.
    DS3 and DS5 are MBR 20100FCT's.
    checked both out of circuit:
    forward direction =.360 on both diodes in each unit.
    reverse direction open circuit on both diodes in each unit.
    LS1B =.2 on the 200 ohm scale
    LS4 = .2 on the 200 ohm scale
    LS6 = .2 on the 200 ohm scale
    T1 transformer secondary checks.
    12-14 = .2 on 200 ohm scale
    10-11 = .2 on 200 ohm scale
    with both diodes disconnected from the circuit, I still get the same readings on the +24V to GND (.290) and the +12 to GND. (7.40 on 20K scale)
    not feeling too good about this.
    thanks very much guys,
    ilikesteel
  • R_J
    replied
    Have you checked the coils Ls1b, Ls4a, Ls6. If the diodes are ok you could have an open coil. also check the continuity of the transformer winding 10 - 11 , it should be low around a 1 ohm, compare to the winding 12 - 14 they should be close to the same resistance.
    12v to ground around 7 k seems high it should be at least measuring the two parallel resistors (rs10,rs11), 1.5k each = 750 ohms aprox.
    when checking the diodes you should be using the diode test on the meter (the diodes are dual diodes) so ds3 has 2 diodes ds5 also has 2 diodes.
    The 24volts is working so a slight charge in the caps could throw off the 24volt readings.
  • CapLeaker
    replied
    sorry... didn't see you updated the thread. Well you get readings both ways on the diode, so next step is to measure them both ways out of circuit.
    What I find weird right now that you almost measure a short on the 24V line now? Can you verify this?
    What are the numbers on the diodes on the 12V and the 24V secondaries? A 0.2V drop is low, but for a Schottky Diode it is normal.
  • ilikesteel
    replied
    "bump"
  • ilikesteel
    replied
    UPDATE.
    R J, CapLeaker,
    DS3 and DS5 both showed same results.
    meter NEG probe on cathode, POS on Anode = .292 on 2K scale
    meter NEG probe on Anode and POS on cathode = .702 on 2K scale
    for the hell of it I also checked DS2 and DS4.
    DS2 and DS4 showed .574 with NEG on Anode and POS on Cathode.
    NEG on cathode and POS on Anode is the same as DS3 and DS5 = ,292.
    the NEG on anode and POS on cathode were different between the sets of diodes.
    the +24V to GND showed .292 on the 2K scale.
    the +12V to GND showed no reading on 2K scale.
    the +12V to GND showed 7.38 on the 20K scale.
    any help with those readings.
    thanks,
    ilikesteel
  • ilikesteel
    replied
    OK R J and CapLeaker, I will make the tests tomorrow and report back. I appreciate the help and guidance.
    ilikesteel
  • R_J
    replied
    You should be able to compare the resistance readings in the 12 volt circuit with the ones in the 24 volt circuit as they use the same diodes. both circuits are almost identical except for the cap. voltages, and resistor values.
    with power off, check the resistance between ground and +12, it should be about 700 ohms give or take. if its low like 10 ohms, you have something shorted.
  • CapLeaker
    replied
    before you take them off, what reading do you get with your DMM in Ohms on the 12V and on the 24V output (TV off of course)? Well voltage measurement? We know already that the 12V is putting out 2V. Sure you can measure the 2 diodes in circuit with your DMM in diode mode. Lets see what you get.
  • ilikesteel
    replied
    Thanks RJ and CapLeaker,
    in the initial rca L37WD12 post I mentioned I had already replaced all 6 caps in both output sections as a first line action, thinking the problem may be there.
    3 1000uf 16V and 3 1000uf 25V were replaced with Panasonic FR series caps. got the same output results.
    can I check voltages around those diodes, would there be any thing meaningful in a voltage measurement? those are the shottkey rectifier barrier diodes. can I measure them in circuit and get anything meaningful or do I need to remove them from the PS?
    Thanks a bunch. I hope to fix this sucker!
    ilikesteel
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • madan1
    Troubleshooting half-bridge smps
    by madan1
    Hello everyone, I'm trying to fix what seems to be a half-bridge smps.
    The switching controller is sg2525a, which I have replaced with a brand new sg3525a. The low and high mosfets are 1c27ac 6n50. The mosfet driver is IRS2301S.
    Both mosfets were tested outside circuit with a component tester and seem to be fine.
    With oscilloscope I see ~65khz switching signal on both low and high outputs of the controller, but on the output of the mosfet driver there is switchig signal only on the low output (flat line on the high output).
    So I guess the mosfet driver is faulty?
    01-23-2025, 06:05 AM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • dkneyle
    Onkyo DX-V500 Laser Disc Player - weird SMPS fault
    by dkneyle
    This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
    Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
    02-01-2022, 02:08 AM
  • ShadowAi
    ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
    by ShadowAi
    Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
    Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
    After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
    03-15-2024, 10:46 AM
