troubleshooting TV SMPS sequence
    replied
    Re: troubleshooting TV SMPS sequence
    There must be a wire that is connected to that 12V output.If you look at the diagram you will see Inductor LS6 with '2' label on the right and you see that +12V, that +12V has to go out from the power supply board through a connector some where on the board which then goes out to load outside the power supply to feed the load, we need to disconnect that 12V wire that feeds the load.
  • ilikesteel
    replied
    Budm,CapLeaker
    Please explain to me using the schematic what you want me to remove after L6. looks like only resistors and capacitors are left in circuit. Caps are all new, Panasonic FR series caps. do I just remove the next resistor closest to the L6? sorry I'm confused.
    ilikesteel
    replied
    Well, what I have you done is to isolate the second Pi filter from the circuit to see if the Voltage will go back up and it does so now we need to find what is loading down the 12V section, what ever it is it is after the inductor LS6.
    What you need to disconnect next is the 12V output wire that goes to what ever the load is first then put LS6 inductor back in place and power it up again to see if you will have DCV on cap CS8.
  • ilikesteel
    replied
    Budm, CapLeaker,
    Ok, we got some real results now!
    removed copper coil L6. did a resistance measurement of it out of circuit. It measures .1 on the 200 ohm scale.
    then fired up PS, fully connected minus L6 and got +16.70V across CS32. I didn't mess with CS55 at all .....yet.
    resistors RS14 is marked 3302 = 33K (measured 2.20K on 20K scale)
    resistor RS19 is marked 1602 = 16K (measured 2.250K on 20K scale)
    tell me we're closer than ever!
    Thanks,
    ilikesteel
  • CapLeaker
    replied
    I am not sure what to think anymore soon. We covered almost everything in between.
    Switching over to Win10 isn't helping much either... AAAAARRRRGGHH!
  • ilikesteel
    replied
    Budm, CapLeaker,
    Do want me to power on and check voltage after removing CS55. Not quite sure what you want me to do. I will remove L6 and then fire it up and check across + and - of cap CS32. if I have to remove CS55 what do you need to me check with CS55out of the circuit?
    sorry... I'm a little confused.
    ilikesteel
  • ilikesteel
    replied
    Budm, CapLeaker.
    ok, I'll try to get to a s a p.
    thanks,
    ilikesteel
    replied
    The whole thing does not make sense to me yet, since the 24V and the 12V are generated by the same transformer, the outputs are regulated by monitoring the output Voltage of both 12V and the 24V as you can see in the diagram, the resistor RS14 for the 24V and RS19 for the 12V.
    Can you remove inductor LS6 from the board and see if you will get 12Vdc between the two legs of CS32 (1000uF 16V)? if still no Voltage, then remove CS55. We have already verified that the inductor LS4A, LS1B, DS3, DS5 are OK. I am beginning to think there is something bad in the winding between pin 10, and pin 11 of T1.
  • ilikesteel
    replied
    CapLeaker, Budm,
    attached are pics of the tv boards. I did sectional pics of PS.
    TV is RCA L37WD12. the very small board at the top right is the 1W 5V STNDBY voltage board.
    I reattached the PS to the TV, connected all cables. I did not mount PS to chassis.
    The main cap still shows 359V-360V with set fully powered on.
    I checked the voltage at the common cathodes of DS3 and DS5 for +12 rail, and also at DS2 and DS4 for the +24V rail.
    The readings were the same as when I first checked the TV.
    +24V rail showed +19.0 - 21.9V
    +12V rail showed +1.5 - 2.1V.
    any help with readings right at the diode junctions?
    Thank you all again.
    ilikesteel
  • CapLeaker
    replied
    That's what I thought, without seeing it... must be some sort of a filter.
    replied
    B4 is just the Ferrite Bead inductor, same for B1.
  • CapLeaker
    replied
    The voltage measured at the common cathode on DS3 and DS5 is DC and you should get close to the voltage what the rail is supposed to be. On some PSU's they are exact bang on, on others they may be little off.
    Matter effect, if you look at the schematic, they are paralleled to each other. You could take one diode out, and it still would work, with diminished current capability of course. Your DMM may not be able to look at the AC as the frequency is too high. It is like 60khz or 120khz, vs a 60Hz regular 120V AC.
    Got no idea what B4 is. That C5 with the R29 in series is a "RC snubber circuit".
    O.k. I am getting really curious now. I'd like to have a high resolution picture of each board, straight shot and the whole thing together. Also again the model number of the TV.
  • ilikesteel
    replied
    CapLeaker,
    I don't have an ESR meter. wish I did have one. remember, when the PS is reading the low voltage out on both rails there is no load on the PS and it's not installed in chassis. when I do get the +21V and the +2, everything is hooked up and connected as normal, except it's not mounted in the chassis.
    I'm not familiar with a fuse in the transformer. I tried measuring the voltage at the transformer secondary, Budm mentioned that my meter probably would not read the voltage because of the higher frequency. where can I read the secondary voltage, after the DS3 and DS5 diodes? what should the voltage be at that point?
    on the schematic there is a 101 1KV cap C5 across the primary winding. also, there is a component marked B4 connected to one end of that cap. what is B4?
    can I measure voltage at the cathodes of DS3 and DS5??
    Thanks,
    ilikesteel
  • CapLeaker
    replied
    I do remember a situation quite a while back here on badcaps. Something wasn't adding up in the secondary, because the PSU wasn't installed in the TV. Apparently the PSU needed a GND bridge, which was made by installing the PSU back into the TV.
    The TDA16888 is working, otherwise you don't have 360V on the main filter capacitor. I thought with that kind of low voltage almost next to zero on the secondary, the PFC should be off, but no it is still running.
    It is just really weird. There is juice in the primary, but nothing coming out in the secondary. The only thing between is the transformer, inductors, diodes and the capacitors.
    So if the secondary isn't shorted but the voltage is that low or nothing, I wonder if the thermal fuse went open inside the transformer. If that is open, no power will go through.
    But still, it just doesn't make any sense having before 20V on one rail and 2V on the other, no it is just 1 or 2 V on both rails. When you measure on the secondary, you can't use the main filter cap GND. You would have to use the GND on the secondary.
    By any chance... what is the ESR of the primary capacitor (if you have an ESR meter)?
  • ilikesteel
    replied
    CapLeaker,
    I'm more confused than you can expect. perhaps the low readings were because there was no load on the +12 and +24. do the voltages on TDA 16888 show anything?
    I did check pin 7 to the neg of the main cap and yes, there was continuity (short). I chose to add the pig tail to make it a little more safe to do the measurements. the pins on TDA 16888 are very close and I did not want to slip off a pin or touch another adjacent pin at the same time. I did the measurements from the bottom of the board.
    are you confident the TDA 16888 is working? tell me where to look and poke and I'll do it. thermal fuse? I'll check the schematic again. I'm open for suggestions!
    thanks,
    ilikesteel
  • CapLeaker
    replied
    Well, something has changed. Now you report that both (12V and 24V) rails are low, like 1 and 2V. If you measure between the main filter cap negative and pin 7 on the TDA16888, you should see a short. There should be no difference measuring having the negative probe of the DMM on either place for measuring around in the primary.
    I don't get it: You get 360V on the main cap and now almost nothing is coming out the other end on both rails on the secondary. I wonder if the transformer has a thermal fuse that blew?
  • ilikesteel
    replied
    CapLeaker,
    main cap 360V. ran a pig tail from neg side of main cap and clipped to NEG lead of meter to make the voltage measurements on TDA 16888. do you think I would get a different reading on TDA16888 if everything was connected as normal?
    Thanks!!
    ilikesteel
  • CapLeaker
    replied
    how many volts do you have on the main filter cap now?
  • ilikesteel
    replied
    CapLeaker, Vinceroger69,
    Vinceroger69, great video of soldering techniques.
    CapLeaker,
    Checked components around IC10, none of the readings jumped off the board as being questionable. I rechecked the resistor I installed for R36, 510K, it's still intact and gives a reading of .500 on 1M scale.
    I jumped PS to turn on from 5VSB to Pin 7 PO/POFF, no cables attached.
    +12 and +24 were both very low. like 1-2v on each. however, that was with no load.
    I did manage to check voltages on TDA 16888. I'm not sure how to interpret the values I received. here they are. no load on PS.
    PIN
    ____
    1. PFC -IAC 1.5v
    2. Vref .00-.60v (oscillating)
    3. PFC CC .20-.50v (oscillating)
    6. PFC CL .01v
    8. Vcc 8.2-9.9 (oscillating)
    Pins 11-16 0v
    17. PFC FB 4.67v
    18. PFC VC .04-.18v
    19. PFC VS 1.2-1.5
    20. AUX VS .30v
    Thanks again,
    ilikesteel
  • ilikesteel
    replied
    CapLeaker,
    ok I'll check components around opto isolater. I'll also dbl check that the 510K resistor I installed at R36 is still intact and not OPEN. Perhaps, I'll check voltages on TDA 16888 too and the PS power on with the PS board by itself, no connections to scaler, using 1K resistor between 5VSM and Pin & of PS, Pon/Poff.
    Thanks,
    ilikesteel
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • madan1
    Troubleshooting half-bridge smps
    by madan1
    Hello everyone, I'm trying to fix what seems to be a half-bridge smps.
    The switching controller is sg2525a, which I have replaced with a brand new sg3525a. The low and high mosfets are 1c27ac 6n50. The mosfet driver is IRS2301S.
    Both mosfets were tested outside circuit with a component tester and seem to be fine.
    With oscilloscope I see ~65khz switching signal on both low and high outputs of the controller, but on the output of the mosfet driver there is switchig signal only on the low output (flat line on the high output).
    So I guess the mosfet driver is faulty?
    01-23-2025, 06:05 AM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • dkneyle
    Onkyo DX-V500 Laser Disc Player - weird SMPS fault
    by dkneyle
    This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
    Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
    02-01-2022, 02:08 AM
  • ShadowAi
    ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
    by ShadowAi
    Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
    Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
    After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
    03-15-2024, 10:46 AM
