17PW26-4 Odd Failure But Simple Fix
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Got this 40" Toshiba Lcd Tv its a 40BV700B which is a rebadged Vestel Tv. The fault was turns on works fine for a min then Lcd fades to white and backlight flickers badly normally about a minuet or 2 after it begins to get warm. I originally suspected we had a failed Lcd Panel as ive seen the particular Panel (LTA400HM07) fail lots of times in weird ways but the Tv stays on wont turn off afterwards, wont respond to remote or buttons meaning the processor has shutdown and turned Tcon off.
    The fault was actually the Psu, the switching section Polly cap on this Psu is C878 (grey box behind main transformer) which is a 23nf 600v type had failed. Physically bulged and measured 0nf on my cap meter. After replacing it with a 23nf 1000v type Tv works fine, been running it for hours. If I had a scope I would have checked the output of this thing but I dont, although I suspect it would be bad. Either way that cap was causing the Tv to do some goofy things.
    Hope this helps anyone who gets a 17PW26 casuing the Tv to act goofy check that Polly cap !
    Re: 17PW26-4 Odd Failure But Simple Fix
    Can we see the pictures of the board, both sides?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Doh ! I sealed this one up but, I have another to re-cap tomorrow Bud so will get you images then. I will also replace the polly cap on it too.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Top side of Pcb. Output caps all changed as well as polly cap.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Bottom side of Pcb.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Polly cap old vs new 223nj 630v.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Another 2 I did a while ago bit better image quality. Both polly caps replaced (not in this image) again as well as output caps apart from that these are good Psu's
              • Sus256
                HISENSE 65E7KQ PRO - no boot
                by Sus256
                Hi all!
                HISENSE 65E7KQ PRO
                RSAG7.820.13512 - chassis
                MT9618BAATAB - cpu
                RSAG7.820.12059 - power
                HD650Y3U77 - panel
                KLM8G1GETF - emmc
                The TV does not turn on, the standby indicator is on. All voltages are present.
                Emms is dead. Not readable, not detected.
                Replaced emmc.
                But with another dump there is no launch
                Terminal log
                UART
                AC_ON
                RPMB key is not yet programmed
                HASH1_VERSION=0x00000000 64bit
                E-B
                FDE enabled
                layout pattern onebin by SAR7,0...
                06-01-2025, 02:11 AM
              • ctroxtell
                Carrier HK50AA063 display controller common failure help
                by ctroxtell
                I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
                02-05-2025, 05:31 PM
              • howardc64
                Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                by howardc64
                Problem
                Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                Model & Board Pics
                Conflicting Spec
                Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                https://www.shopjimmy.com/vizio-gj-2k1...
                10-10-2024, 01:16 PM
                Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                by sam_sam_sam
                I was working on this CNC machine today found no keyboard functioning no control relay powering on
                The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                Found shorted diodes on main controller relays there are 3 of them that...
                01-07-2023, 05:43 PM
              • freakaftr8
                Asus a15 FA507RE-A15.R73050T failure
                by freakaftr8
                So this laptop seems to have some kind of failure. I bought it second hand and originally the previous owner said that they went to turn it on and it was presented with a quick flash of the power light the keyboard lit up and then the keyboard shut off and the power light went off as well but the battery indicator was white and after about 5 to 7 Seconds flashes orange really quick then shuts off and goes back to White. If the power button is pressed again the keyboard lights up really quick and then repeats. When I got it I could press the power button multiple times the keyboard light would...
                03-28-2024, 10:58 PM
