Panasonic TC-P50G15 flickering and randomly turning off
  • ejyoung
    • Jan 2016
    • 5
    Our 50" Panasonic G15 has started flickering - it will go completely black sometimes, other times there will be white lines across the screen with some flashes of green.
    It is happening daily but at some point it starts working fine for a much longer period than when it acts up.
    Also, sometimes it randomly turns off. This is pretty infrequent but is still happening. I've looked for the red light flashing but it doesn't flash at all when it turns off.
    Any ideas on what might be wrong? I'd love to be able to fix this and keep the TV if possible if it makes sense from a cost perspective.
    Here's what it looks like: https://www.youtube.com/watch?v=zv13LtQFU6M
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Panasonic TC-P50G15 flickering and randomly turning off
    Possibly A board fault...
    Does it happen on all inputs?
    TELEFIX
    • ejyoung
      • Jan 2016
      • 5
      I only have one input to the TV currently as everything goes through the receiver. I can try plugging something in to another input for testing purposes.
      I was looking at parts for this TV and it seems the A board is hard to come by. Hopefully it isn't that!
      • davph
        • Apr 2014
        • 23
        • uk
        Check the screws on SC or SN pcb are tight.
        • ejyoung
          • Jan 2016
          • 5
          Is there a reason something like this would come loose when it has been mounted for over a year?
          • ejyoung
            • Jan 2016
            • 5
            I plugged my Apple TV into a different HDMI input on the TV. When it started doing this on normal TV I tried switching over. It generally seemed better on this HDMI input so I put the out from the receiver into this HDMI input. No issues since doing this. So it seems either our HDMI1 input is bad now or our cable. Very happy it is working at least. Thanks for the suggestion.
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              On some (a lot of) models, They were cheapened to the point of using poor screws mounted into pressed sheet steel instead of proper mounting-lugs and with no lock-washers or locktite and do work loose through use, causing arcing on the earth-mounts and destruction of SS and SC boards, Its important to check these, as these boards are expensive and short supply.
              TELEFIX
              • BigPete
                Panasonic Heatpump Dryer Repair
                by BigPete
                I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                Unfortunately the whole machine has to come apart to fix it.
                I have...
                11-01-2025, 06:40 PM
              • Amraks
                Panasonic SA-MAX770 (not turning on)
                by Amraks
                Hey all its been awhile since I have needed to post here.
                Panasonic - SA-MAX770: Symptoms not turning on
                Power Supply
                C1403 has 330v
                IC1402 Looks perfectly fine no blown out holes.
                C1601 has 3.3v
                CN1851 Has its 3.3v but no 15v all I am getting is on the 14v rail is 0.400v
                Not sure where I should be looking next for this any help would be appreciated...
                10-04-2022, 12:12 AM
              • Andre Gilbert
                by Andre Gilbert
                11-20-2024, 08:52 PM
              • 0AiVeN0
                Panasonic TX-L42E5E flickering LED
                by 0AiVeN0
                Good day guys,
                I am trying to repair this older model of LCD TV Panasonic TX-L42E5E for my family. This older type is known for its single edge LED strip technology.
                First of all, it worked for many years and then TV just goes to stand by suddenly. No RED light blinks, just turned off and I can repeatlly trying to turn on, nothing, sometimes its start but a few seconds turn off again.
                So I inspected componencts, found nothing (like capacitors etc.) decided to replace edge LED then. After replacing LED TV started to work and can be switched on with no problem,...
                04-03-2021, 11:31 AM
              • kurtspirit
                Macbook Pro Mi-2010 flickering randomly
                by kurtspirit
                I have a mid 2010 Macbook Pro in hand that had kernel GPU issues. I changed the famous capacitor which is generally lacking and the failure seems to be fixed.
                My problem: I have random mouse and backlight flashes that stop if I disable automatic graphics card choice and as a bonus, I have the keyboard backlight that flashes randomly...
                Do you have any idea what could be problematic? I don't see any connection between the keyboard and the GPU but hey, you never know.
                Thank you
                04-14-2022, 01:54 AM
