Macbook Pro Mi-2010 flickering randomly
  • kurtspirit
    • Feb 2019
    • 112
    • France
    I have a mid 2010 Macbook Pro in hand that had kernel GPU issues. I changed the famous capacitor which is generally lacking and the failure seems to be fixed.
    My problem: I have random mouse and backlight flashes that stop if I disable automatic graphics card choice and as a bonus, I have the keyboard backlight that flashes randomly...
    Do you have any idea what could be problematic? I don't see any connection between the keyboard and the GPU but hey, you never know.
    Thank you
  • zaler808
    Macbook Pro 15" Late 2013 A1398 Turn off randomly but after workload it shows black screen with fans spinning
    by zaler808
    Hi guys, this my first post but i want to be brief about it, i recently got a MBP L2013, the problem was that after some use the macbook shutted down randomly, at first i suspected to be the battery, and after connecting it with the charger i noticed that i didn´t shut, but after an hour or so it shutdown, after that i started searching a solution to my problem, but my brother tried to help me to find the problem and it that process to replicate the problem he reproduced a 4k video in multiple tabs and not much time after the macbook shutdown to never power again, what i noticed was that the...
    05-23-2024, 05:17 PM
  • envym
    by envym
    Hi everyone!
    06-27-2025, 08:54 AM
  • Flasman90
    Macbook Pro DFU Restore Issues
    by Flasman90
    I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
    - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
    - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
    08-30-2025, 10:27 AM
  • tobeend
    Bypass mdm macbook m2 ventura
    by tobeend
    1. RESET MACOS WITH IPSW
    a. Power off MacBook, press and hold the power button to enter Recovery
    b. Open Disk Utility, remove Macintosh HD
    c. Reboot, connect to the network to Activate Mac.
    d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
    d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
    e. Release the other keys, but keep holding the Power key for another 10 seconds
    f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
    05-26-2023, 07:18 AM
  • dbuergi
    MacBook Pro A1708 pink screen and flickering
    by dbuergi
    a friend brought me his A1708. Apple store told him that the screen needs to be replaced for 400 € but they didn't even open it to check anything.
    Since this model is not known for flexgate issues is there anything else i can check or is this also a faulty display flex?
    Btw external screen works fine.
    03-09-2025, 12:35 PM
