Panasonic SA-MAX770 (not turning on)
  • Amraks
    • Nov 2011
    • 725
    Hey all its been awhile since I have needed to post here.
    Panasonic - SA-MAX770: Symptoms not turning on
    Power Supply
    C1403 has 330v
    IC1402 Looks perfectly fine no blown out holes.
    C1601 has 3.3v
    CN1851 Has its 3.3v but no 15v all I am getting is on the 14v rail is 0.400v
    Not sure where I should be looking next for this any help would be appreciated
  • rddube
    Aspiring Expert
    • Jun 2013
    • 954
    Re: Panasonic SA-MAX770 (not turning on)
    If you keep power off, what resistance to ground do you get on the 15V rail pin of CN1851?
    Disconnect CN8001 and check the resistance reading again on CN1851 15V rail.
    I had a similar issue on a different model (Cambridge Audio) and it turned out to be a small mylar cap that had shorted on the 15v rail deep down inside. I used a thermal camera to see what was heating up and bang, there it was.
    • Amraks
      • Nov 2011
      • 725
      resistance to ground looks good nothing shorted out there.
      measuring voltage at Vsen on pin 2 of ic1501
      Is 1.5v could R1501 to R1504 be bad.
      I believe this is meant to be 3.5v
      • R_J
        • Jun 2012
        • 9607
        Do you have VC1 on pin1 of ic1501? What is your voltage on CN1851, pin4 (PCONT)?
        • Amraks
          • Nov 2011
          • 725
          Pin 1 has no voltage.
          correct me if I am wrong but isn't PCONT just going to ground?
          Also I have been using wrong ground to measure Vsen using the right ground i get 3.3v
          • R_J
            • Jun 2012
            • 9607
            PCONT is the Power CONTrol pin, it is used to turn ON the power supply. If there is no VCC on ic1501, the sense pin means nothing, the ic is not operating at this point.
            PCONT goes to (P1) on page 71, then to (P1) on page 72 and then to PCONT on the base of QR1601 which turns on Q1405 optocoupler, which then turns on Q1402 which supplies the vcc to ic1501
            • Amraks
              • Nov 2011
              • 725
              Ok there is no power on VCC of IC1501.
              Confirmed using ZA1101 heatsink as the ground.
              And there is no voltage on Pcont.
              • Amraks
                • Nov 2011
                • 725
                with everything disconnected I have measured the mainboards pcont.
                it is measuring short to ground.
                I have checked IC8007 pin5(en) to ground and its reading short to ground.
                • Amraks
                  • Nov 2011
                  • 725
                  found the shorts.
                  So have a short on IC8005
                  injected some voltage to find him.
                  Then injected some voltage to the SW pin 10 of that IC8005 as there was a short on that line which lead me to a short IC8003 removed all these off the board.
                  then found the sw pin short on IC8003 so I injected voltage and found that ic4803 was getting hot.
                  removed IC4803 and short was gone.
                  Now IC4803 was not on the schematics we have here I have found that version and I will upload here with this post.
                  shorted IC's by order.
                  1. IC8005 - TI45 54140
                  2. IC8003 - QVB? OVB? OYB? QYB? (this is a +3.3V DC/DC CONVERTER not sure where I can get this any help would be good. I am thinking it could be the tlv62065)
                  3 IC4803 - Yamaha YDA174
                  • Amraks
                    • Nov 2011
                    • 725
                    Thank you RJ for getting me this far.
                    • R_J
                      • Jun 2012
                      • 9607
                      So is it only IC4803 that is bad and the other ic's are ok with IC4803 removed? IC8003 seems to be a TLV62065DSGR, use a magnifier to make sure of the number but it is likely QVB
                      IC8005 is likely a TPS54140
                      • Amraks
                        • Nov 2011
                        • 725
                        I took them all off in order so no way of knowing if they were bad, is it possible for them Frist lines to be short to ground and be still be fine with ic4803 removed.
                        I think I'll replace all just to be sure than wait another two weeks for chips to get here.
                        Not sure what could of caused this fault.
                        I need to read up on the Yamaha chip
                        You could see some discolouration around the edge of the chip looks like it got very hot at one stage.
                        Excuse me if this post is not formatted properly I am typing this on a phone today.
                        • Amraks
                          • Nov 2011
                          • 725
                          probably a bit late of a reply but this was solved by replacing all listed chips.
                          • Nagy Daniel
                            Lowest possible resistance on laptop motherboard rail - Guide Table request
                            by Nagy Daniel
                            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                            So, I generated a table with AI so I can...
                            03-04-2025, 08:24 AM
                          • jaroslav.psenicka
                            Lenovo Yoga 13 Panasonic, no video, fan OK, missing voltage rail (?)
                            by jaroslav.psenicka
                            I have a Lenovo Yoga 13 Panasonic here, when powered
                            • both fans spins (the sconds starts with a bit of a delay), no image neither on HDMI nor the display
                            • most voltage rails seem OK (see image below, red labels)
                            • resistnace to ground mostly seem OK as well (blue labels)
                            the only suspicious is the 0.0V rail (2nd from left, top row)
                            • the resistance to ground is rather low (1.9ohm)
                            • when injecting the voltage (1V), it consumes around 200mA, seems OK to me (?)
                            also tried new BIOS, no change
                            I can't find a schematics for the board - can some of you gurus look at the voltages?...
                            05-02-2024, 05:59 AM
                          • Victor Moreira Silva
                            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                            by Victor Moreira Silva
                            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                            Well, my decice specs are the following:
                            Model: Acer Nitro 5 AN517-54-55T5
                            CPU: Intel Core i5-11400H
                            GPU: NVIDIA GeForce GTX 1650
                            Motherboard: GH51G LA-L181P Rev:1c
                            The symptom:
                            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                            05-26-2025, 10:49 AM
                          • BigPete
                            Panasonic Heatpump Dryer Repair
                            by BigPete
                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                            Unfortunately the whole machine has to come apart to fix it.
                            I have...
                            Yesterday, 06:40 PM
                          • lefetylorant
                            Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
                            by lefetylorant
                            Hello Everyone,
                            Long story short, I got this unit for very cheap.
                            I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
                            I've performed some measurements:
                            - 20V rail perfectly...
                            09-14-2023, 05:05 AM
