Panasonic Plasma TH-P50GT30A - 7 blinks
  • tw2005
    • Oct 2011
    • 6458
    hallelujah, Back in the land of the cities where I can get some Pannys to fix.
    TH-P50GT30A - 7 blinks. Been advertised for a while, price was a bit high, anyway got it down a bit.
    person had it from new, already had 1 SC replaced 7 blinks, failed again, same blinks.
    Even had the original failed board(bonus)
    Original SC was TNPA5335BG (TXNSC11GGKBTH), these were superceeded with TNPA5335(TXNSC11GGKB50). Of course different regions can have different part numbers but the board number and two suffix work out.
    Having looked at both the difference with the revised board was that they removed the soldered lands topside and had bare copper for the bolts to mate with. But the same screws were used.
    taking it apart , 3 were not tight and the usual marks underneath.
    It's looking like 3 x RJP30H2 and 3 x 30F131 shorted on the second board.
    on the origninal, I had a quick poke around and looked like just 1 30F131 and the Q661 RJP63G4 gone. Found nothing else obvious .
    So as luck would have it, the Q661 on the other was good and I had 1 30F131 still ok on that board.
    Swap over, power up 8 blinks nothing popped.
    Hello, I've been here before ( https://www.badcaps.net/forum/showth...ht=th-p50st30a) , failed Q102 on SS , RCJ330N25
    Replaced that and up and running.
    16500hrs, no wonder it's done 2 boards
    I'll add photos when it's available.
    Nice picture with the filter on the glass for glare.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic Plasma TH-P50GT30A - 7 blinks
    Just pooped itself again, somehing popped. 7 blink will get to it and report.
    • tw2005
      • Oct 2011
      • 6458
      finally, chinese parts arrived from UTsource.
      Board #1: I did a very quick and dirty replacing just Q621 30F131 and Q661 RJP63G4, lasted not long and popped after 2 runs as reported in post #2..
      So this time I've replaced the whole bank Q621,622,623 and Q661. It's running again and I'll keep this board in it for testing.
      Board #2, which is the revised replacement board. had the common 3 x 30F131 Q401,402,403 + 3 x RJP30H2 Q421,422,423.
      Fired up ok, but will retest this after Board#1 has had a good run.
      • tw2005
        • Oct 2011
        • 6458
        my GT has died again, 6 blink. was fine running for a few hours, was turned off and I just went to fire it up again, no pop but a funny low buzz like a shorted panel, bad buffer maybe?
        • tw2005
          • Oct 2011
          • 6458
          same parts failed Q621,622,623 and Q661. Obviously I've missed something, time to put the other board in while I try and nut this out.
          • tw2005
            • Oct 2011
            • 6458
            This is how it went last time, worked fine for the night, turned off, next day went pop at startup.
            • michael dranfield
              • Jan 2016
              • 232
              • England
              I find that things that go pop when cold and work when they are hot is usually down to a dried out electrolytic capacitor , you want to see the difference it makes to the ESR when you cool a worn out cap with a tin of freezer.
              • tw2005
                • Oct 2011
                • 6458
                Not sure, it could be blowing at shutdown
                  I doubt this is caused by an electrolytic going bad. More likely if it's giving 6 blinks it's an ER circuit problem, so check the gate driver for the ER circuit. If that's bad that could cause this failure.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    What about a bad Y cap ? I had an Lg42Pg6000 blowing the fets which were 30F131 and it was due to a failed Y cap that I think was in parallel with fets and GND. It was odd as it worked for a while then boom ! The Y cap had leakage across it so and I guess was causing a short between the fets and GND causing them to pop ? Just a suggestion to check them if there are any on this board.
                    • flocko
                      • Nov 2012
                      • 1121
                      • uk
                      TW this is not like you? you fail to say but are you are changing IC 501/502 Q 501/531 change them whenever you rebuild these board also check all gate resistors and the little CO8N25 unable to give board number as mind has gone blank. Also make sure the tabs are soldered on correctly. if the tabs are not on right the other IGBTs take to much load and blow, just like our trade unions one out all out Good Luck Flocko
                      • tw2005
                        • Oct 2011
                        • 6458
                        I'm having trouble tying in what is blowing , and what the kits have and what Tom is suggesting and your suggestions.
                        Q661 and Q621,622,623 are going out to lunch together. Q401,402,403,421,422,423 are ok,
                        IC502 drives Q531,Q441,442
                        IC501 drives Q501,401,402,403
                        all resistors checkout
                        with the C08N25 (Q600) is there any sign it's bad or what? Not shorted, maybe I should pull it out I do have 2 new ones just in case.
                        • tw2005
                          • Oct 2011
                          • 6458
                          schematics etc
                          • tw2005
                            • Oct 2011
                            • 6458
                            It's now in SC heaven, Q661 & co fail again. Suspect maybe BD8655FV Ic921 , driver for q661. Other board in and running.
                            • tw2005
                              • Oct 2011
                              • 6458
                              Back to this damn board. reached a dead end and the only clues are Q661, Q621-623 failing. Pretty much checked everything, including PC685.
                              Anyway, all I could come up with guessing were Q818,819,820, IC921 BD8655 IGBT driver or something missed around Q621-623.
                              Found nothing spectacular about those tiny FETs, IC921 I have not found any kits or anyone replacing that yet. Was considering borrowing one off another working board.
                              Anyway < I went back to the opto and probed it in diode and got a reading of 1.6 in both directions, thought that was sus, grab a few other boards and got different results say 1.6 and 0.7.
                              Pulled it off and no reading either direction, another I had had no reading and 1.4. I'm probing the diode side.
                              So I reached the conclusion the opto was dead, pilfered off a dead board, now getting 1.4 & 1.6, replaced the usual suspects rjp63G4 & 30F131 that kept blowing and it's back online.
                              too soon to say it's fixed but maybe the opto was flaky and finally quit. i hope so because I really want this board fixed as a spare.
                              I guess if I get more than a day out of this things will be looking good as both attempts that failed, worked ok and then failed at startup after a good run. 6 blinks.
                              • tw2005
                                • Oct 2011
                                • 6458
                                it's still working
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  it's still working
                                  Lol thats like me when i test something waiting for the next pop of parts but fingers crossed you have fixed it a long soak test with a few power on/off cycles should prove its ok.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Shhhh, it'll hear us.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      looking good, still has a pulse. I think we got ourselves a live one.
                                      • gdawg
                                        • Sep 2012
                                        • 170
                                        WOW, persistence does pay off. I would have trashed it but now I know better. Thanks for the info.
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • nick31
                                          Panasonic Plasma ST50 TC-P55ST50 P55ST50 8 blinks
                                          by nick31
                                          My Oct 2012 panny plasma quit working yesterday.
                                          It was on when it happened. It let out a bit of burned plastic/circuit board smell. I was not able to find any burned parts though.
                                          Now it produces 8 blinks. According to the repair manual, that points to SS/SS2 board(s).
                                          I completed the steps in the guide: unplugged SS33, the TV turned on with a black screen, no blinking codes. Then I checked the continuity between pins 1 and 2 of the connectors SS52, SS54-SS57. The continuity is ok in all of them. Guide suggests to replace SS/SS2 boards so I placed an order...
                                          04-21-2021, 09:56 AM
                                        • stecos
                                          Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                                          by stecos
                                          Hi everyone!
                                          I happened several times, in the search for help from the web, to consult this very interesting forum.
                                          So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
                                          Having said that I come to the gist of my post on the forum as the title suggests.
                                          For my passion for technology I'm now collecting several...
                                          11-28-2022, 11:39 AM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
