Sony KDL-52v5100 55" LCD Issues
  • nstlfrk
    • Apr 2014
    • 166
    So this TV when you turn it on has lines showing up. Now sometimes when I turn it off and back on multiple times they go away. They also are not on immediately when I turn it on it takes about 5 to 10 seconds for them to fade in.
    Can any of you give me any ideas n what to check or look into?
    Thanks in advance
  • nstlfrk
    • Apr 2014
    • 166
    Re: Sony KDL-52v5100 55" LCD Issues
    Anyone?
    • Terryfictv
      • Mar 2011
      • 124
      Bad Panel connects.No permanent easy/common fix.
      YouTube DIYers show temporary "fixes".
      JMHO, Terry
      • nstlfrk
        • Apr 2014
        • 166
        Oh as in the Tabs coming apart? I was hoping for a TCON issue but did see a lot of bad panels out there
        • sk3vr6
          • Oct 2016
          • Usa
          did you fix this? I have the same set. and I am looking for parts.
            https://www.badcaps.net/forum/showth...ht=tab+bonding
            • nstlfrk
              • Apr 2014
              • 166
              Screen was bad I scrapped the TV
              • HarryZ
                Sony XBR-49X800G networking issues
                by HarryZ
                Aloha. First post here, hope I can find someone to assist me.
                I have a Sony XBR49X800G with streaming issues. The issue mostly occurs watching sporting events (basketball and football). The picture will sometimes get pixelated, sometimes freeze for a few seconds while the audio continues, sometimes it's jerky. In other words, you get a headache watching the TV.
                My ISP provides 500 Mb service and I have verified that I have at least 500 Mb on ethernet, and something over 300Mb on WiFi. I installed Analiti on the TV (it's an Android TV) and I get ~ 70 Mb on both WiFi...
                01-26-2024, 04:49 PM
              • Carlos#2003%
                Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                by Carlos#2003%
                Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                02-15-2024, 07:52 PM
              • PontyPCs
                Sony Android TVs eMMC Issues
                by PontyPCs
                Hi people.
                I have been trying to get my head round these issues with the eMMC putting the TV in to a boot loop condition, or completely dead, when a dump of the Boot 1, Boot 2 and USERDATA partitions have been made, the MLC lifetime counter has been reset, using the original eMMC with the RPMB partition intact and the eMMC is flashed with the original dump, Netflix and a few other Apps don't work. i assume all the DHCP keys and factory programmed RPMB access Key will be contained within the original dump, and as we are re-flashing the original eMMC i would expect every thing to work....
                12-10-2023, 10:43 AM
              • ptcriserx3
                Sony trinitron crt bowed and side color issues
                by ptcriserx3
                Hi
                Ive got a vintage 2001 sony trinitron flat tube tv
                The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
                See many images attached...
                Just windering if this is not fixable or something i can correct without getting too invloved
                Im trying to sell the tv
                06-17-2023, 07:27 PM
              • dkneyle
                Sony KDL-46HX850 Can't upgrade/update firmware
                by dkneyle
                Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                09-25-2024, 10:44 PM
