Solder Tool for EEProm removal/replacement
  • jstiene
    • Feb 2013
    • 148
    Hello.
    I have many years of basic soldering experience but have not replaced surface mount IC's such as an EEProm on a main board. I was wondering if anyone has a recommendation for what soldering iron/tool would be the most successful and any other tips,etc. I have two traditional soldering irons with different wattages, but believe I need to use a different one for this application. Also, if there are any links to how to do this without lifting the traces, I would appreciate that as well.
    Thanks in advance for any suggestions and/or advice..
    Joe
    • 31150
    Re: Solder Tool for EEProm removal/replacement
    a hot air station is best,
    but for an 8pin chip you can use an iron
    flow lots of fresh solder over each side, and put VERY gentle pressure under it wih a knife or something and heat each side in turn to lift it.
    then cleanup the board with braid.
    if this is in a laptop you will have to use an iron anyway because the solder in most of those is almost pure tin and very hard to melt with air.
    • jstiene
      • Feb 2013
      • 148
      Hello. Is there a hot air station that someone might recommend in terms of brand,etc? Is it fairly easy to replace failed eeproms?
      Thanks!
      Joe
      • freakaftr8
        • Oct 2012
        • 3743
        I have a aoyue 968a+. It's a great unit and never let's me down. I have performed many many IC replacements with this unit. It's a hot air resoldering station so it comes with the hot air unit plus the soldering iron built-in with an array of different tips for miniature soldering to large-scale soldering
        • diif
          • Feb 2014
          • 6978
          • England
          Yes, it makes previously difficult soldering jobs easy like eeproms etc.
          I bought a cheap one off ebay, although i know the JBC is well regarded.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            This is a good video to watch it can be done with a soldering iron but i have lifted traces so does take practice
            https://www.youtube.com/watch?v=Sghh8BK5zIw
            • Alastair E
              Chief Womble
              • Mar 2013
              • 1963
              • U.K.
              I changed an EEPROM on a Plasma Control-Board yesterday.
              --It was one of those wide chips with only two rows of pins. I was able to flood one side with solder and keep molten all down the one side and carefully lift it slightly, then dry off all the solder with braid.
              Did much the same with the other side and the chip was off.
              Cleaned up the pads and straight on with the new one.
              --All with just an iron, braid and 0.5mm Leaded solder.
              TELEFIX
              • lookimback
                • Aug 2013
                • 1489
                I have a hot air station, but a lot of cheap boards delaminate real easily. I've become quite a fan of low-melt alloys such as Chip Quik for all IC removal. Chip Quik costs too much though. I bought a pound of this stuff. It works great.
                Edit: Real good idea to have a fume extractor running.
                ------------signature starts here------------
                • Comm
                  • Nov 2014
                  • 8
                  Wow, great thinking outside the box, that ChipQuik is so expensive, I'll have to try a pound of that stuff, Thanks
                  • lookimback
                    • Aug 2013
                    • 1489
                    It's definitely worth the cost. Have to use Flux with it btw. A solder sucker works good to clean most of it up after you get the IC off, then you don't waste as much wick. Another tip: Put a little silicon lube in your solder sucker(if you use one) and it'll work way better and last longer.
                    • acedogblast
                      by acedogblast
                      11-02-2024, 05:13 PM
                    • rex98
                      HP DMI Tool
                      by rex98
                      HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                      DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                      The DMI Tool given here are for personal use only.
                      DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                      You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                      from it, and that you please credit the author...
                      07-02-2025, 05:51 AM
                    • ktmmotocross
                      Bios memory SPD removal tool
                      by ktmmotocross
                      Hello.
                      I came across Bios memory SPD removal tool 1.6, that can remove SPD from bios to disable onboard memory, but i dont know how i load bios to it.
                      anybody try this app ?
                      03-10-2024, 08:16 AM
                    • SidneyCanadas
                      93C46 and 93C56 EEPROM
                      by SidneyCanadas
                      I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
                      https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
                      Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
                      06-14-2023, 01:16 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
