samsung ps43d450 slight pink/purple blotch on certain bakgrounds?
  • PhaseCoder
    • Nov 2013
    • 62
    • Uk
    basicaly title sums it up,I haavve a ps43d450 plasma and on light backgrounds "Sometimes" see like a large thumb print of purple/pink in center of the screen, not always noticable.
    is there any fix? or a proper name for this? so i can search, hope someone understands what i am trying to describe thanks.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: samsung ps43d450 slight pink/purple blotch on certain bakgrounds?
    Turn Vs up by 5v and possibly other sustain voltages up by a few volts.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      If that fails you might possibly need a firmware update, what happens if the firmware over time is suppose to adjust the sustain/drive waveforms that drive the panel this is because as the panel ages you get distortions if it drives it like it does from new. Normally the firmware in these over works and pixels get lazy which causes pink banding.
      • PhaseCoder
        • Nov 2013
        • 62
        • Uk
        Thanks for the fast reply, im not total noob when comes to things like this, but can you point me to in the right direction for the procedure of turning the vs up? or give me some tips.
        Also my nana had the tv from neww andcan gurentee it chance never had a firmware update, were do i get new firmware?
        thanks
        • PhaseCoder
          • Nov 2013
          • 62
          • Uk
          it seem like ill try the firmware before diving in and taking it apart.
          • sordids999
            • May 2013
            • 2161
            adjust VS using the picture i have uploaded and i have circled where the VS adjustment is i would advise marking it before adjustment
            • PhaseCoder
              • Nov 2013
              • 62
              • Uk
              Do i need power on? as i just been reading and they say to have power on that seems aa bit iffy to me as thats the power board?
              would you recommend a firmware update first?
              • PhaseCoder
                • Nov 2013
                • 62
                • Uk
                this is the patch,shows everytime on the self troubleshoot
                • sordids999
                  • May 2013
                  • 2161
                  try the firmware update if you want first and yes adjust the VS while the tv is on just be careful when adjusting the pot and you dont slip with your screw driver adjust the pot then see if the pink banding gets better
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Also there is no limit to what you can turn Vs upto, you can put it at its max and the Tv will be fine image may be too bright and washed out though but won't cause any damage.
                    • PhaseCoder
                      • Nov 2013
                      • 62
                      • Uk
                      ok guys i turned the vs up and got rid the purple blotch, i have now noticed a slight green tint in the center of the screen only seen only white or very light backgroounds? can anyone exxplain or direct me to sorting this?
                      I have tried many picture settings, ie: chaing the tint more to the red etc to no avail
                      thanks
                      • PhaseCoder
                        • Nov 2013
                        • 62
                        • Uk
                        anyone able to assist please?
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Whats Vscan at ? Normally turning Vs and Vsc up will sort this Ive done a few of these.
                          • PhaseCoder
                            • Nov 2013
                            • 62
                            • Uk
                            iv looked and cant see vsc, i found vs and that sorted the purple blotch.
                            I would assume it was on the pcb near vs but i looked everywere and cant see it?
                            thanks
                            • PhaseCoder
                              • Nov 2013
                              • 62
                              • Uk
                              on the pcb i see vs above va? no vsc?
                              • Alastair E
                                Chief Womble
                                • Mar 2013
                                • 1963
                                • U.K.
                                VSc is on The Y-SUS board to the Left of the PSU (Vs) board....
                                Dont increase the Va, this will not help and can stress the COF chips along the bottom -and are part of-the plasma panel.
                                What you are trying to compensate for is aging of the plasma-panel itself, and depending on how bad can be covered up for a while--or not depending on age.
                                Turn set off by remote--press (in quick succession) Info, Menu, Mute, Power, and look for the Panel Time On.
                                --Guessing in the order of 10-15,000 hours.....
                                Shame, these D series never lasted well like the older A/Q series. Ive got a 42Q97 at 27,000 hours, with no panel issues at all--Even when at -2 degrees C!.....
                                TELEFIX
                                • PhaseCoder
                                  • Nov 2013
                                  • 62
                                  • Uk
                                  ohh yea the TV has 265hr onit due to me sleeping with it on etc, other than what started developing the TV has been perfect and still is, other people don't even notice the problem, i know its there so cant help but see it every time lol
                                  • comptek
                                    • Aug 2013
                                    • 606
                                    i just did one of these vscan is on the ysus board turn it up a bit and then let run for hours so its hot to check it doesnt come back, then do a cold start like following morning see if the fault happens again
                                    vscan adjustment is below the yellow transformer on the left hand board looking from the back its inbetween a couple of caps, also inspect boards for dry joints. mine had a few which doesnt help,
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      These Tv's give Plasma a bad name unreliable trash from Samsung
                                      • PhaseCoder
                                        • Nov 2013
                                        • 62
                                        • Uk
                                        You say turn it up, clockwise our anti-clockwise? im guesing clockwise like the vs?
                                        • Vlad713
                                          LG 55NANO913NA Purple / Pink Line / Spot
                                          by Vlad713
                                          I am struggling with an issue on my LG TV, as mentioned in the title - please see the attached photos.
                                          The display / panel has been replaced in March 2023, under warranty - right before expiring after 2 years of use - due to a bunch of dead pixels.
                                          Then in a few months the purple / pink line started showing up, however the LG service said that this is not covered by any warranty, anymore, since the original one has expired.
                                          Recently I have just asked a repair firm to have a look and they have said that the panel needs to be replaced,...
                                          01-11-2024, 04:14 AM
                                          Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) boardview and Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) schematic. Our users have donated over 1 million...
                                          09-07-2024, 12:40 AM
                                          Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
                                          09-06-2024, 09:30 PM
                                        • jimjoe123
                                          LCD TV Green/Pink screen problem
                                          by jimjoe123
                                          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                          Then each time...
                                          02-23-2020, 01:29 AM
                                        • kca
                                          Lg 60pz550
                                          by kca
                                          Hello all ~
                                          I picked up this 60" LG the other day and it has the following signs / issues:
                                          1) Displaying a primarily pink and green screen that alters its look on occasion and particularly can change if the set is turned on and off (see picture set below).
                                          NOTE: All of the pictures uploaded upside down, and I could not correct it. So, please view them as such. You can see the base stand at the top of the photos.
                                          Pic #1 ~ How it looked when I first picked it up.
                                          Pic #2 ~ The first time it changed shape, of its own accord, after...
                                          07-15-2019, 11:20 AM
