Samsung PS43D450 - No Picture Has Sound.
  • ph3d
    • Jan 2016
    • 19
    • scotland
    Bit of background - Was watching the T.V when it just lost picture still had sound - Can see the power light on the T.V flash when I press the buttons on the remote - Turning it on the power light comes on then flashes around 5/6 times and then goes off I think this is possibly indicating no source/signal but not sure.. Can stick one in if needed.
    No flicker or anything just panel stays dark when powering up.
    I am new to this so went out and grabbed a multimeter and hit youtube to watch some videos on troubleshooting.
    I followed the troubleshooting guide here - https://www.youtube.com/watch?v=1Rc9awtZ5_E
    My Vs when I power on reads 207 as expected but rapidly falls off and stops at 10 Va does the same reads 57 then drops off to 0.
    If I disconnect the controller board or the cable to the Y-Sus board then its still the same - the voltage just drops off straight away after power on it reads the correct 207 voltage for less than a second.
    If i disconnect the cable from the bottom right board in the video (board with vga/usb etc) to the one in the middle where I measure Vs and Va then I get no Vs or Va on voltage and the TV doesnt power on if i hotplug this cable in the TV then powers on and same symptom occurs
    Being a noob I am not sure what to do next.
    I followed a thread on here with the same problem also
    https://www.badcaps.net/forum/showthread.php?t=22449
    but this was never resolved and I think my problem may be a little different as my vs voltage never stabilized with both cables disconnected from the main centre board (not sure the name for this) my T.V would no power on and with only the y-sus disconnected there was no difference.
    Any help appreciated on what I should try and replace or look at next?
    Cheers
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung PS43D450 - No Picture Has Sound.
    Checked Vs on signal ?
    • ph3d
      • Jan 2016
      • 19
      • scotland
      No mate I cant seem to see that I must be going blind - Will it be on the same board as Vs and Va
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        On these Tv's Vs and Va need to be loaded down for the Psu to keep them rails up if not they collapse. Also if the sustain boards are shorted Vs and Va collapse (safety shutdown) you got images at all ? Vs on will be labelled normally comes off the cntrl board to Psu.
        • ph3d
          • Jan 2016
          • 19
          • scotland
          Will check that in a moment - Nah no image at all not even the samsung logo on power on or menus
          • sordids999
            • May 2013
            • 2155
            i think thats your power supply check VS VA on the power supply first with a multi meter black to tv chassis then red on the test points
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              No I meant images of the boards, also follow what Sordids said.
              • sordids999
                • May 2013
                • 2155
                may also help more
                • ph3d
                  • Jan 2016
                  • 19
                  • scotland
                  Yeah I have checked VS and VA as stated in the first post I get 207 volts on power on then it falls to 10 for VS in about 1 second and VA gets 57 as it should and falls to 0 within a few seconds
                  Where is VS ON so I can test that?
                  Also the video you posted is the video I posted in my first post also.
                  Cheers
                  • ph3d
                    • Jan 2016
                    • 19
                    • scotland
                    Images of the board are what sordids posted and there are images on the other thread I have linked above also still cant find vs on can you see where on the above board I should be checking?
                    • sordids999
                      • May 2013
                      • 2155
                      opps and opps i must read more before posting
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        I bet that your Ymain is probably shorted. Do you know how to check for S/C ?
                        • ph3d
                          • Jan 2016
                          • 19
                          • scotland
                          I am going to go ahead and say no.. unless you mean continuity? Even then I have an idea of what it is but I would just need advice on what points to check?
                          Edit: if the Y-main was the problem would VS and VA not be ok with it disconnected
                          • sordids999
                            • May 2013
                            • 2155
                            if i remember rightly before if the x-main blows it can also take out the ysus plus i would also check to see if your buffer board is ok
                            test this way https://www.youtube.com/watch?v=51SZsfH60EY
                            so have you followed the video and tested the same way ?
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Thats correct one sustain board can kill the other, they chain the ERC (enegry recovery circuit) so if one transsistor on the Ysus fails it will creat a short on the ones for the same ciruit on the Xmain which kills then too.
                              • ph3d
                                • Jan 2016
                                • 19
                                • scotland
                                I have done the tests as posted in the first video
                                I have not done any of the buffer board tests or even looked at it yet will see what I can do and have a look over that I just watched the video and will need to check nothing is blown on there and possibly remove and test for S/C's
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  You dont need to remove the devices to check for S/C.
                                  • ph3d
                                    • Jan 2016
                                    • 19
                                    • scotland
                                    Yeah just had a look there - I take it I dont need power either lol.. sorry I am clueless when it comes this - just having a smoke break and watching the buffer board S/C test again before I get back to it.
                                    Anywhere else I should be testing for S/C's?
                                    • PhaseCoder
                                      • Nov 2013
                                      • 62
                                      • Uk
                                      this may help?
                                      https://www.badcaps.net/forum/showth...light=ps43d450
                                      • sordids999
                                        • May 2013
                                        • 2155
                                        https://www.youtube.com/watch?v=ovnw8BrsQnY
                                        watch and follow this
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
