LG, Model 47LG50, not coming ON
  • tictac
    • Nov 2014
    • 26
    SYMPTOMS: At standby the front LED is solid red. When turned ON, it flashes brighter red twice, then goes out. From the inside of the TV, I can see the light change to blue but it is barely visible on the front of the TV. There is no picture and no sound.
    TESTS DONE: Visually all the boards look normal, no burnt marks, no fat caps, no smoke. All cable connections were re-seated but made no difference.
    With power unplugged, using "diode test" on a meter, all diodes and bridge rectifier tested OK. Although the Dual-Diode packages showed continuity between the outer terminals (I assumed that was normal). None of the MOSFET gate-drain legs showed shorted. Two fuses tested OK also.
    With the TV turned ON, the measured voltages were as follows:
    AC on bridge rectifier=124 VAC
    DC on bridge rectifier=122 VDC (should this not be higher?)
    5V output at connectors=5 VDC
    12V output at connectors=0 VDC
    16.5V output at connectors=0 VDC
    24V output at connectors=3 VDC
    Attached is a photo of the PS Board. Could someone please advise me on how to proceed. If it's a power supply problem I'm fine with replacing parts, but I'm not sure how to find the bad part. Thank you in advance.
    Re: LG, Model 47LG50, not coming ON
    'DC on bridge rectifier=122 VDC (should this not be higher?)'
    Is that what you are getting measured between the two legs of the main filter cap?
    We need the dcv readings of each pin of the connector with the name of each pin so we can see what your are missing.
    • tictac
      • Nov 2014
      • 26
      Previously, I measured the 122 VDC directly on the PLUS & MINUS terminals of a bridge rectifier. Today, I measured the two large caps near the bridge rectifier and they were 384 VDC each. Following are the DC voltages on the 3 connectors on the PS board as you requested.
      P201 (to main board)
      LABEL DC Voltage
      16.5 0
      GND 0
      12V 0.01
      GND 0
      5V 5.11
      5V 5.11
      GND 0
      GND 0
      ACD 0
      ON/OFF 2.8
      PMW-DIM 1.16
      N.C. 0
      P205 (to inverter on right side)
      ON/OFF 3.02
      BRI 1.61
      GND 0
      GND 0
      GND 0
      GND 0
      GND 0
      24V 0.37
      24V 0.37
      24V 0.37
      24V 0.37
      24V 0.37
      P204 (to inverter on left)
      ERROR 0
      PWM-DIM 1.35
      ON/OFF 3.02
      BRI 1.61
      GND 0
      GND 0
      GND 0
      GND 0
      GND 0
      24v 0.37
      24v 0.37
      24v 0.37
      24v 0.37
      24v 0.37
      Thanks for your quick reply, Budm.
      • tictac
        • Nov 2014
        • 26
        Budm,
        The voltage readings in the previous post are poorly formatted. On each line the connector label is followed by a space and then the DC Voltage. When you get a chance, could you please give me an idea of what to check next.
        Thank you.
        • tictac
          • Nov 2014
          • 26
          BudM,
          I have posted the voltage readings. When you get time, could you please let me know what I could check next. Thank you.
            OK, the power supply is getting the correct command signals and the PFC Voltage booster is working because you are getting the 384VDC on the filter cap but the switched 12V/24V power supply section is not coming on, that will be the section to check next.
            One signal Voltage that I ma not sure is the 'ACD 0' AC detect, I do not know if 0V is normal or not.
            http://www.shopjimmy.com/lg-eay40505...upply-unit.htm
            • tictac
              • Nov 2014
              • 26
              There are a number of dual diodes with their cathodes connected to large heat sinks. If I measure the anodes, with ground as a reference, should I be getting AC or pulsating DC?
                At this point we need the good clear pictures of the whole bottom side of the power supply board.
                • tictac
                  • Nov 2014
                  • 26
                  Here they are. I may be able to get better closeups tomorrow in the daylight if you need.
                    Thanks, they are a little too much glares from the flash, I may also need you to take the closed up pictures in section so I can stitch them together to able to see the traces in details.
                      https://www.badcaps.net/forum/attach...9&d=1453766077
                      What are the P/N as printed on those two ICs with 16 pins (or may be 20 pins)?
                      • tictac
                        • Nov 2014
                        • 26
                        I will get good closeup pictures in the daylight tomorrow morning.
                        The IC part numbers are on the attached picture.
                          NPC1396 is the SMPS IC for the 12V/24V power supply, we need to find out if it is getting the Voltage between VCC pin and GND pin to run.
                          • tictac
                            • Nov 2014
                            • 26
                            With the TV plugged in and turned OFF, VCC-pin12 is at 2.69V. With the TV turned ON, VCC-pin12 is at 14.32V. These are measured with pin 10 as the reference.
                            A new observation: Just after measuring these voltages, the back lights came on for about 15-20 seconds and then went off again. I had no time to measure any other voltages while the lights were ON. I tapped the power supply everywhere, thinking there may be a bad connection some place, but I couldn't get the back lights to come on again.
                            Attached are 6 new pictures of the board.
                              So the IC gets enough DCV to run (VCC ON Threshold level min is 12.3V, Typ is 13.4V, Max 14.3V).
                              I would resolder the legs of the power transformers T101, T102, MOSFET Q110, Q111, Caps C114, C125.
                              • tictac
                                • Nov 2014
                                • 26
                                I re-soldered the components you suggested and the TV turned on as normal. Both, picture and sound, are good. I will leave it on to test run for 4-5 hours just to be sure that was the problem. Thank you for your advice and time.
                                  Please also make sure all the boards mounting screws are tight since the GNDs to the chassis are done through the board mounting screws and the GND pads on the circuit boards..
                                  • tictac
                                    • Nov 2014
                                    • 26
                                    OK. It's been working fine for a number of hours now, so I believe we fixed it.
                                    Thanks again. I'll leave a donation.
                                    • theyankeemoto
                                      • Dec 2016
                                      • 3
                                      • usa
                                      Hi guys, I have the exact same problem with my 47lg50 tv.
                                      I replace the power supply board with one off eBay that I thought would most likely be the problem, but didn't fix it. Could it be the backlights inverters ?
                                        Read post 3 and later and then tell us what Voltages you have like what the OP had provided..
                                        • Ross Kohler
                                          Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
                                          by Ross Kohler
                                          I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
                                          - There's no sign of any attempt to power on when pushing the power button.
                                          - No PSON signal is reaching the 24-pin ATX connector.
                                          - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
                                          - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
                                          - If I pull the Super IO S_SLPS#_R pin...
                                          04-16-2024, 09:36 AM
                                        • pkslowk
                                          Debug Card Error Code and Solution
                                          by pkslowk
                                          Sr. Motherboard Debug Error Code Solution
                                          1 Intel 845 E9 Bios Related Problem
                                          2 Intel 845 D4 CPU Socket Related problem
                                          3 Intel 845 37 Bios Related Problem
                                          4 Intel 845 7C Bios Related Problem
                                          5 Intel 945GCPE 34 Bios Related Problem
                                          6 Gigabyte 845 2 Ram Related Problem
                                          7 IBM Server A6 A7 Ram Mismatch Problem
                                          8 Asus 845 29 CPU Related Problem
                                          9 Lenovo I946 97 C-Mos Jumper related
                                          10 Gigabyte 845 A0 CPU Related Problem
                                          11 Asrock G31M-VS D7 Bios Related Problem
                                          12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                                          01-28-2021, 12:51 PM
                                        • Roman555
                                          Asus H77 LGA1155 mainboard stopped working with Ivy Bridge CPUs
                                          by Roman555
                                          Bad symptoms when Ivy Bridge CPU (3rd-gen 22nm) is installed:
                                          • Won't boot OS (just blank screen or stucks at asus logo, monitor is turned on) with hangs at debug (post) code A3;
                                          • USB stick with MS-DOS can be loaded via F8 boot menu;
                                          • Other OSes won't load - hangs or goes reboot;
                                          • Postponed for several seconds reaction to Alt-Ctrl-Del, Reset and Power buttons;
                                          • An operating system starts loading but won't finish if it's left only 1 CPU core in BIOS settings;
                                          What I've already done and it hasn't helped:
                                          • Cleared CMOS many times;
                                          • Flashed different versions of BIOS in a CH341 programmer;
                                          • Updated
                                          01-18-2024, 06:26 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • Byte_76
                                          Gainward GTX 295 SLI Bridge
                                          by Byte_76
                                          I have a Gainward GTX 295 with two PCB's which has a broken SLI bridge ribbon cable. As a result, the card is entirely useless and I'd really like to fix it if possible.
                                          I've searched eBay and AlieExpress but haven't been able to find the part.
                                          I believe this same SLI bridge cable is used on the Nvidia 9800 GX2 and the GTX 295 which both have two PCB's.
                                          Can anyone help me on where to get a replacement SLI bridge cable please?
                                          05-10-2024, 03:07 AM
