Can't find LG main board... help
  • Umbrella Corp
    • Dec 2015
    • 26
    A member of this forum was kind enough to help me troubleshoot the problem with my LG 60PZ550.
    The part I need is: ebt61533403 (the main board) but I can't find one supplier in the US that still has this part.
    Can anyone offer any suggestions? Thank you in advance.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Can't find LG main board... help
    You've been looking it up wrong its the EAX number your after.
    • Umbrella Corp
      • Dec 2015
      • 26
      ReeceyBurger123,
      Sorry to bother you again, but I actually have been looking it up under both numbers and have found dozens of places that are out of stock.
      The only reason I put the ebt number was because the people at My Shop TV told me to.
      Here's what I wrote and their reply.
      Dear My Shop TVs,
      Attached are two pictures of a main board I’m trying to locate. The part number is EAX63546403(1)
      Unfortunately we don't have this part in stock, but when trying to look for this board use the part number ebt61533403
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Hmm I cant seem to find any either :L
        • Umbrella Corp
          • Dec 2015
          • 26
          Yeah. I found one in Canada that's used and it will be $175 just to get it here. I may go for it, but I have some other emails and calls out.
          Thanks again. I figure I just have some hunting to do.
          • Umbrella Corp
            • Dec 2015
            • 26
            Success at last!
            I was encouraged via pm by member jgrise to try the oven method to reflow the board and IT WORKED! I now have a working television again thanks to reeceyburger123 troubleshooting it and jgrise encouraging me to try the method and fix it.
            BTW, per JG's advice I used 385 degrees for 10 minutes (putting it in the cold oven and starting the 10 minutes when it reached the full temp.)
            It did melt the SPDIF shut on the board (which I thought was hilarious.) I never use it anyway so I could have cared less.
            You guys saved me a lot of time and money. Thank you.
            And thank you, Badcaps.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Wow fair enough sorry didnt see your previous post. Also I hate oven reflows lol but well done ! It wont be a permanent fix but will work for a while. Enjoy the Tv buddy
              • Umbrella Corp
                • Dec 2015
                • 26
                Yes, you were instrumental in getting it fixed. And buying a new board would have been easier, but I was at a dead end, (or spend $175) which they are not worth.
                Thanks again. We'll be enjoying it tonight. And the kids' tv will go back on the back porch.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  No worries buddy, let us know if you ever need help again
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                  • JDC
                    (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                    by JDC
                    ONN 100012588
                    Issue: No Power, Then Rebooting After Main Board Change
                    Short answer: replace main board and power board
                    Technical answer: replace main board and Q306 & Q307 on power board.
                    Long answer:
                    TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                    07-15-2022, 07:39 AM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • cheeky2
                    by cheeky2
                    05-25-2024, 03:27 AM
                  • Asraf Atb
                    by Asraf Atb
                    01-27-2025, 05:02 PM
