Samsung PN58A55081F sparkling pixels
  • rodzghost
    • Dec 2015
    I inherited a Samsung PN58A55081 Plasma TV, and it has colored pixels sparkling all over the screen. I did a little research and think it may due to bad caps on the power supply.
    Here are some pics:
    EDIT: Sorry, I posted the wrong links for the pics. Here the correct links:
    [IMG][/IMG]
    I've never done any sort of TV repair, but I have worked on computers and other types of electronics. I do have a few questions before attempting to fix this.
    First, I read that a 10 W wire-wound resistor is sufficient for discharging the power supply caps. Would I just plug the pins of the resistor into the connector for the board? And does polarity matter, as in can it be plugged in either way?
    Also, does anyone know which capacitors this particular power supply uses?
  • braz508
    • Dec 2015
    • 8
    Re: Samsung PN58A55081F sparkling pixels
    pictures are not loading for me.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Unlikely caps on the PSU will cause Mal-Discharge, --which is what you're describing, if all the output Voltages are correct.--Have you checked Vs and Va...??
      Probably the panel itself has aged, How many hours on it? Worth checking all the supply and Y-SUS voltages, such as VSC, -Vy Vs and Va etc.
      Maybe a very careful adjustment of Yfr and Yrr will help, or a slight reduction in Vs voltage...
      TELEFIX
      • rodzghost
        • Dec 2015
        Are the voltages all marked on the PCB's? I haven't cracked open the TV yet. I can check them with my meter once I take it down.
        The TV is from 2008 and has a lot of hours on it.
        How would I go about adjusting Yfr, Yrr,Vs?
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          All voltages marked on Panel Label.
          7-8 year old panel will prolly be very worn, which is what I suspect by looking at the pictures, those almost stripes of M.D. down the screen, caused by manufacturing tolerances of the glass and the cells....
          Patches of M.D on Old Samsung panels seems to be fairly common in sets made later than the xxQ96/7HD series, which is odd as Ive not seen any defective panels in this older (Q96) series....
          TELEFIX
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • cheeky2
            Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
            by cheeky2
            This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
            I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
            Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
            06-15-2025, 05:12 AM
            03-31-2024, 02:12 PM
          • alltvrepairs
            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
            by alltvrepairs
            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
            Any one met this problem in the past?...
            10-08-2025, 07:34 AM
          • Cookybaby
            Samsung UN60ES6500FXZA Power Supply Issue
            by Cookybaby
            Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
            I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
            Make: Samsung
            Model: UN60ES6500FXZA
            Power Supply P/N: BN44-00525A
            Symptoms: The TV was...
            08-20-2023, 12:26 PM
