Sony Bravia kdl-42w705b sound and backlight but no picture
  • Seanl84
    • Dec 2015
    • 11
    • Ireland
    As above guys, any common causes? Set turns on and backlight can be seen though screen stays black/blank.. T-con/main fault?
    Haven't actually got my hands on this one yet, hopefully collecting it tomorrow..
    Cheers, Sean
    Re: Sony Bravia kdl-42w705b sound and backlight but no picture
    You need to check the DCV between chassis GND and both ends of the SMD fuse on the T-CON board.
    • Seanl84
      • Dec 2015
      • 11
      • Ireland
      DCV between chassis GND and both sides of t-con fuse is 12v.. Any ideas?
      • Seanl84
        • Dec 2015
        • 11
        • Ireland
        Right, just connected this TV up to another set via the av out and low and behold there is a picture..
        So t-con or panel?
        Any way of testing the t-con further? It's getting 12v and the smd fuse is fine. I have another t-con ordered, but I wouldn't mind trying to repair this one if possible
        • opipva4a
          • Nov 2010
          Hi there,
          i'm on same boat. There is a backlight, but screen remains blank. When power on just hear sound from tuner about 1 sec and then stops.
          No any red error codes from diode, except powered it up without (disconnected TCON cable) to get 5 red blinks.
          Already tested T-CON and getting 12v both sides of the fuse. So same situation - Main BAXL board or TCON? Any ideas?
          Thanks in advance
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            I had one of these shorted MLCC on the Tcon not easy to find.
            • sansiro2
              • May 2016
              • 18
              Hi guys, did anyone manage to work out the fix for this? Could the LDVS cable cause this?
              • chrle
                • Sep 2013
                • 158
                • slovakia
                old post but did you fix this tv? I have same problem.
                I replaced another T-con and still nothing,I think that panel is bad.
                • KYBOSH
                  Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                  by KYBOSH
                  Previous owner said TV just went blank one day.
                  They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                  Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                  The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                  There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                  I just downloaded the Sony KD-75X7800F Service Manual and...
                  11-19-2024, 10:12 AM
                • alegatorul
                  sony bravia kdl-43w756c, no power, no sound
                  by alegatorul
                  the charger brick has 19,2-19,3 vcc
                  changed the inverter board same result.
                  where should i start?
                  cheers
                  11-15-2025, 10:00 AM
                • iglitare
                  Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                  by iglitare
                  i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                  Backlight seems to work, Sound (Setup menu after reset) works.
                  If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                  Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                  With my small knowledge i would think at least the cables are good.
                  Can this happen because of a bad tcon board?
                  Or is it always a bad/shorted...
                  09-04-2025, 07:13 AM
                • CyberPhoenix
                  Issue with picture quality of Sony bravia TV
                  by CyberPhoenix
                  Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                  01-22-2024, 02:08 AM
                • DKWS89
                  Sony XBR 49x900E - Sound and backlight on but no picture
                  by DKWS89
                  Hey Guys,
                  So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                  All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                  12-14-2023, 04:30 PM
