Sharp LC-70le550u back light flashes
+ More Options
Posts
  • nwcs
    • Dec 2015
    • 311
    • usa
    I have this sharp lc-70le550u that originally when turned on the back lights would lite up with no picture but had audio then would fade to black. Now the back light just flashes every few seconds and when they flash the 12v to the t-con from the power supply would drop to 0v then back up to 12v. If I disconnect the 12v to the t-con the led's stay lit. Sears had been out to the customers house and replaced the t-con and the main board with no fix. I am guessing that the power supply may be the problem. All other voltages seem to be good. Seems I have seen this problem before but can not find the fix. Does anyone have a thought?
  • budwich
    • Jul 2015
    • 3097
    Re: Sharp LC-70le550u back light flashes
    disconnect one of the tcon cables (either side) and see what happens. You should get at least half a picture (depending on the side). Go from there once you get a stable screen hopefully.
    • nwcs
      • Dec 2015
      • 311
      • usa
      A little bit more info I do get 1.5v from pin 13 AC_Det and 5v from pin 15. No other voltages since it died.
      • nwcs
        • Dec 2015
        • 311
        • usa
        Somehow my last post did not get in. I did re seat the t-con cables to the panel and now the led's stay lit but still no picture. So I was checking voltages on the main board and when I got to pin 9 the set died. Now I only get pin 13 and pin 15 voltages on power supply. All else nothing. I am guessing I must have shorted two pins and killed the main board.
        • budwich
          • Jul 2015
          • 3097
          OK... but I don't want you to reseat the cable... I want to disconnect it and power it up. "things" should happen there after. IF nothing happens picture wise, then try the other cable on the other side of the tcon.... same test. report the results.
          • nwcs
            • Dec 2015
            • 311
            • usa
            Well as luck would have it I got in a lc-60le550u with different problem so I was able to do a little more trouble shooting with a know good t-con and main board. Back to original problem TV turns on backlight lights and no picture on screen. So unless power supply is the issue I think I have a bad panel. I had also replaced all of the cables with same problem.
            Last edited by nwcs; 12-22-2015, 05:11 PM. Reason: forgot to answer post prior to this one.
            • budwich
              • Jul 2015
              • 3097
              But you need to do a test with the tcon cable disconnect (ONE). Input a signal and look for a picture. Then if nothing, do the other cable, same test. You should be getting something. Finally, if nothing, then with tcon all CONNECTED, disconnect the CORNER cable... this a small cable interconnecting the bottom edge boards to the side edge boards. What happens? If nothing, try the other corner cable on the other side.
              bad panel??? doubt it..... but maybe ...SAVEABLE panel, probably... :-)
              Of course, from your other post... "shorting" isn't good but I doubt you took out the main board, more likely your power board may have an issue... anyways. Again do the tests that I suggested and report the results.
              • nwcs
                • Dec 2015
                • 311
                • usa
                I will try all of that once I get it back up on the bench. Thanks for the help, I really appreciate it. I do not want to call it a bad panel unless it is.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  As far as I know I'm pretty confident that the 60 inch T CON will not work in the 70 inch panel even though they look identical the suffix at the end of the tcon is different as out t cons are suffixed ZH. I believe the 60 has a suffix of ze Anyhow I'm still thinking that you may have a bad side driver Make sure your T CON is putting out the acceptable proper voltages. First verify that you have 12 volts going into the tcon then if you look at previous posts you will find that you can check voltage is off each one of those small round coils on the tcon. This will verify that the T CON is putting out proper voltages to drive the panel
                  • nwcs
                    • Dec 2015
                    • 311
                    • usa
                    deleted
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      So no 5v and no flashing inverted v?
                      • nwcs
                        • Dec 2015
                        • 311
                        • usa
                        Correct. I do have the 5v though. I thought I did not but it is there.
                        • budwich
                          • Jul 2015
                          • 3097
                          are we confused yet? :-) I am, first 70, then 60, then no voltage, then voltage... :-)
                          As suggested, try disconnecting one of the corner cables (of the panel), assuming you have voltages (confirm all the voltages on the printings of the power board), power up and see if you get a picture. If not, try the other corner cable.
                          Hopefully, the set will come up.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Then your power supply is most likely okay
                            • nwcs
                              • Dec 2015
                              • 311
                              • usa
                              The problem is I am doing way too many tv repairs 4 or 5 at a time and sometimes miss something. Anyway I did like you and freakaftr8 said and no picture. The TV was powering up with backlight at one time but now the only voltage I have is 5V. I even changed the battery in my meter to make sure. I removed one tcon cable at a time still no voltages or backlight of course.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Okay let's start from the beginning. There are two white flat ribnon cables going from the tcon board to the panel. I want you to disconnect one side then power it up. Do you have a picture showing on 1/2 of the screen? If not then plug that one in and disconnect the other side and power up. Do you have a picture on that side of the screen?
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  Ok just read that. You have no flashing inverted V representing an error code underneath the sharp symbol?
                                  • nwcs
                                    • Dec 2015
                                    • 311
                                    • usa
                                    did that and no there is no picture.
                                    • nwcs
                                      • Dec 2015
                                      • 311
                                      • usa
                                      no flashing v at all.
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        Does the "v" light up at all? You need to check ALL the voltages that are labeled on the power card.... especially those associated with the backlight powering. Do a diode check of the diodes and in and power from the transformers.
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • esqmooo
                                          HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
                                          by esqmooo
                                          I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
                                          03-07-2025, 05:55 AM
                                        • PNI E.
                                          tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                          by PNI E.
                                          hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                          02-20-2025, 08:36 AM
                                        • CraigR
                                          Hp x360 15-u499nr power light flashes continuously.
                                          by CraigR
                                          I have an Hp x360 15-u499nr laptop with a continuous white blinking power light. The laptop does turn on. The light flashes with just the battery and if I disconnect the battery and just use the power cord it still flashes and with both connected it still does. I have updated the bios and tried a hard reset with battery unplugged and power cord unplugged and holding down the power button for 60 seconds. I can't think of what else to try.
                                          09-16-2024, 06:12 PM
                                        • russpall
                                          LG 39ln540v - red light flashes twice, no power to LED driver?
                                          by russpall
                                          Hi there,
                                          I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                          The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                          08-27-2024, 01:07 PM
