I picked up a Sanyo DP52449 and it has a darkest blue screen not real dark but it seems maybe a little darker than normal. Also real choppy noise from the speakers. Have not done anything at all with it. Just wondering if the panel was bad would it still light up blue?
Sanyo DP52449
Tags: None
Re: Sanyo DP52449
Well now after I really got into it, It actually looks like a a really light washed out look. The bright dots on the screen is just a reflection and nothing to do with he screen.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Sanyo DP52449
That is what I was leaning towards. I thank you for your reply. I have not really got into it. Would you mind telling me how to check what you said. Can I check it with a regular volt meter? Also may I ask if there is anything I can do to rule out the actual screen itself before I start throwing money into it?Comment
Re: Sanyo DP52449
https://www.badcaps.net/forum/attach...5&d=1398298480
This PDF is from Tom here on Badcaps.Comment
Re: Sanyo DP52449
Got around to checking this TV today and could not figure out how to test the T Conn board. The TV lights up with like a light blue screen, It has great sound. Screen never did anything different though. So it is either the T CONN board or the board that sends signal to the screen. Could it be that board even though it puts out sound? Please reply soon.Comment
Re: Sanyo DP52449
i have this same exact problem. backlight comes on, chopped noise sound coming from speakers (that is, until it quit now it doesnt do it anymore).
i have checked all correct voltages coming from power board to main board so far.
i have uploaded the service manual i found.
this looks to be a nice tv and i'd like to get it working to use. picked it up when some ppl were moving.
also, since the speakers were outputting chopped noise and the speakers come directly from the main board, wouldnt that indicate the problem is on the main board and not any other? number on the tuner sticker is N7KE.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Sanyo DP52449
Have you checked the voltages as given on page 5 of the manual?Willing to help but I'm no expert.Comment
Re: Sanyo DP52449
i checked the voltages as shown and they are correct with the tv on. except that i couldnt find ic1680 or ic1670 (it has a * on schematic and is not populated on board) and ic6750 is on the 120hz board and is under a heatsink.Comment
Re: Sanyo DP52449
Here is a pic of the board. How can I test the board. If anyone has one of these that is guaranteed to be good and the price is right I will be interested. Please reply.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: Sanyo DP52449
Have you checked the fuse on the Tcon board to see if it has a dc voltage on both sides?
Edit
I see that you have replaced the Tcon but it would be worth checking the voltage to it.Last edited by dick_barton; 06-01-2016, 01:25 PM.Willing to help but I'm no expert.Comment
Re: Sanyo DP52449
Can you please tell me how to check that fuse. Can you check it with a regular voltmeter? How could I check to see if the panel was bad? You can get audio.Comment
Re: Sanyo DP52449
With the set on and out of standby you can check it by testing the voltage at both sides of the fuse with your voltmeter set to DC. Black meter lead on the chassis and red meter lead to each side of the fuse in turn. The fuse should be marked something like "F1"Willing to help but I'm no expert.Comment
Re: Sanyo DP52449
Have a read through this thread. It may help you.
https://www.badcaps.net/forum/showth...hlight=DP52449Willing to help but I'm no expert.Comment
Re: Sanyo DP52449
so i replaced the main board and 120hz board, no change. t-con board (checked f1 resistance .04ohm) or a bad cable?Comment
Re: Sanyo DP52449
Good for you! I ordered another Tconn board from Ebay and installed it and no luck. Maybe I got a bad board, Who knows! Can someone look at my board and tell me where to check it? I dont see a fuse on it anywhere.Attached Filesif you find these attachements useful please consider making a small donation to the site
by cntiHi.
BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
burned, measured 10M ohm.
QM801 [real PSU:...-
by cj_rehaHey all
I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
Channel: General Capacitor Questions & Issues
by edugimenoHi there!
My friend wants me to help him repair his old-real-vintage strong-hammer machine. Well it's only 90% real as the force applied doesn't lift the weight itself but it is measured and it moves a motor that lifts the weight
I am attaching several pictures of the machine.
It basically has 2 sides, left side has- 2 x 220->12+24v transformers
- 2 relays (1 moves motor UP, other moves motor DOWN)
- IGF and breakers for safety
- Logic board. Receives 24AC and recitifies it into DC. Contains a uC (M80C85)
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by toddw65Hey All,
I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
Thanks,...5 Photos - Loading...
