toshiba 32av615db
  • finntricky
    • Jan 2014
    • 449
    • uk
    toshiba 32av615db
    bad screen or T-CON ? see here https://www.youtube.com/watch?v=Ai2iB-bkxHs
  • finntricky
    • Jan 2014
    • 449
    • uk
    Re: toshiba 32av615db
    no worrys guy, just had it in bits, and screen tabs are faulty,,
    • Daren87
      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
      by Daren87
      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
      08-13-2023, 03:25 PM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
      09-06-2024, 05:27 AM
    • alltvrepairs
      Lg TCon test pins for screen test
      by alltvrepairs
      i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
      Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
      Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
      Appreciate your help....
      06-13-2025, 06:33 AM
    • sigmeyer
      Toshiba 50UL4B63DG faulty screen?
      by sigmeyer
      I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
      08-30-2025, 08:13 AM
