Sharp LC-60TQ15U Main Board Replacement
+ More Options
Posts
  • mdneilson
    • Feb 2014
    I have a TV that has no image or sound. It gives a blink code of 1 short, 3 long. The service manual says: Initial communication from the main CPU is not
    received. (Request for the monitor model No. is not received.) → Communication line failure or main CPU start-up failure.
    1) Is there any troubleshooting I can do to possibly replace a single component or check the cables before ordering a new main board? (visually, the components look fine)
    2) Does anyone know where I can find the files to update the software of a used board to fit my model (there are 6 other models that use the same board)?
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
  • Asraf Atb
    Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
    by Asraf Atb
    Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
    Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
    I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
    01-27-2025, 05:02 PM
