Vizio P50HDM Plasma TV wont stay powered on
  • MajesticMike
    • May 2012
    • 31
    • US
    I have a Vizio P50HDM Plasma TV that will not stay powered on. It tries to power on but turns back off in 2 to 3 seconds. You can hear a power relay click on then click off. The power status LED goes from amber to green, then its clicks off and goes to amber green amber green amber green flashing 9 times and then stays amber.
    I've tried to isolate the problem by unplugging the Y-sustain board from the power board – resulted in no change.
    I've tried unplugging just the x-sustain board from the Y-sustain board (since that's how it's hooked up) – resulted in no change.
    I don't see any obvious visual signs of bad caps.
    I did find one bad fuse on the Y-Sustain board, I replaced but it blew again. See pictures for location
    I'm looking for other ideas on what I can test to isolate the problem.
    I'm guessing there's probably a problem with the power board? What do you think?
    I'm handy with using multi-meters and soldering.
    I'd be happy to provide any additional information or pictures if needed.
    Thank you in advanced for any advice.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5036
    • New Zealand
    Re: Vizio P50HDM Plasma TV wont stay powered on
    If you have a fuse that keeps blowing, focus your search there, the cause of the blown fuse is very likely the same reason why it shuts off.
    Sounds like something is shorted or otherwise bad on that Y-Sustain board.
    -David VanHorn
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Probably shorted Ipm on the Ysus under the heatsink. Check for Vs short to groundn the Ipm.
      • Hannibal_Hector
        Samsung UN39EH5003FXZA won't stay powered off
        by Hannibal_Hector
        Purchased a broken Samsung UN39EH5003FXZA (Version CD01) to have fun fixing. When I first acquired it, I did not connect any video signals and only plugged it into the wall. The unit booted and showed the “no signal” window and I could navigate all menus and change sources. I unplugged it, connected my over-the-air antenna to the coax, powered it on, got the unit to scan the HDTV channels, and I think then the TV self-shutdown with the melody. When I powered back up (melody), it would show the channel selected on the OSD and after a couple of seconds, it self-shutdown...
        03-02-2021, 07:57 PM
      • Undertaker1
        Vizio M60-C3 won’t stay on
        by Undertaker1
        I have a vizio M60-C3 went to turn it on and as usual the logo pops up like normal then shuts off keeps doing it over and over. I would like to try and fix it myself if anyone has any suggestions thank​...
        12-19-2023, 09:32 PM
      • SS454
        vizio e650i-a2 backlight flashes then turns off
        by SS454
        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
        panel: au optronics T650HVN05.4
        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
        https://www.shopjimmy.com/vizio-56-0...-power-supply/
        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
        08-20-2020, 03:57 PM
      • mrtek
        Vizio M65-C1
        by mrtek
        Hi.
        picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
        When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
        This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
        07-14-2025, 07:28 PM
