Technika 40-e271
  • sordids999
    • May 2013
    • 2158
    Technika 40-e271
    Hello
    bought this tv today but for some strange reason its stuck on Aging Timer and i cant seem to turn it off !
    tried unplugging the tv etc but it still goes back to this menu
    im guessing someones been messing with factory settings ?
    thanks
  • comptek
    • Aug 2013
    • 606
    Re: Technika 40-e271
    what boards are in it Sordids999
    • sordids999
      • May 2013
      • 2158
      i have not took it apart yet but going on ebay its looks like its the following :
      Main Board - TP.MSD309.BP86
      power supply -MEGMEET MP118TFL-U REV.1.2
      • sordids999
        • May 2013
        • 2158
        Right all back to normall now it seems the remote would not work so managed to use the tv controls to turn this off
        im going to change the eeprom as well i think this model is prone for this fault,after all the person told me it wouldnt switch on before they started messing with the settings
        • comptek
          • Aug 2013
          • 606
          well done mate
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Wouldn't surprise me if it messes up again, the firmware on these is shite. Be sure to test if for a good while.
            • DeanWy
              WD Sentinel DS5100 (NAS) boot issues
              by DeanWy
              I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
              It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
              There...
              07-30-2024, 04:13 AM
            • Storyteller12
              Need help picking 12v timer!!
              by Storyteller12
              I need a 12v timer that cuts on when 12v applied (when door is opened) and cuts off after 2 minutes even if he door stays open with the 12v trigger. And resets when door is closed.
              The ones I see tend to start the timer when powered down. (Momentary switch)
              Thanks in advance
              09-05-2022, 07:24 AM
            • unimatrix93
              Technika T32HD-278-17 (VESTEL)
              by unimatrix93
              Hello everyone!
              My crappy Technika TV has a flashing red light symptom. Black screen, Voltages looks good.
              Does anyone have the EEPROM bin file for this model?
              Technika T32HD
              MB: Vestel 17MB140
              Panel: VES315WNDA
              Thank you!
              06-16-2022, 04:11 AM
            • repair-it
              TOSHIBA DLP 52HM95 How to reset timer module on bulb
              by repair-it
              I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
              Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
              10-11-2023, 07:18 PM
            • modd1uk
              Dell 5420 - First timer, messed it up, need help please.
              by modd1uk
              Hi guys
              Its my own fault, I'm just hoping somebody can help and the laptop isn't bricked.
              The BIOS chip is a 25rh256cxiq, I read it using neoprogrammer 2.2.0.10 but like a complete idiot didn't search the chip, it was set to the wrong chip, I read the BIOS, unlocked it, flashed the unlocked file and now the laptop is dead, won't even try to power on, only after I'd flashed it I realised the wrong chip was selected.
              How stuffed am I? Is there a way to flash a generic Dell Latitude 5420 BIOS so I'm not stuck with a dead paper weight?
              I have another...
              03-22-2025, 03:24 PM
