Emerson LF320EM4
  • jeffecor
    • Sep 2014
    • 78
    • kent
    Emerson LF320EM4
    So I picked this TV up in a deal of 5 broken working TVs.<--aka recycling place for 60 dollars for all.
    The problem with this TV it would turn on as soon as i plugged it in with black-lights, but no picture.
    After playing around I order the main board thinking maybe the eeprom issue. Well got the board yesterday same issue after digger around some more I found a fuse on the panel was bad. The turning on issue was someone had the ribbon cable to the power button upside down causing the TV to turn on.
    I start looking for shorts on that board turns out that the surface mount cap was short causing the fuse to blow. By the way i know My solder job is not that great but works..
    I guessed the size of cap off anther board I had for boards and powers up now.
    Still learning from this website and glad I can pickup a new hobby!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Emerson LF320EM4
    Nice one
    • rounin
      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
      by rounin
      🛠 Original Issue
      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
      04-19-2025, 01:18 AM
    • ugamazing
      by ugamazing
      12-17-2024, 07:05 PM
    • elmark
      HP 15-cw1002ua strange keyboard issue
      by elmark
      HP Pavilion 15-CW1002UA
      S/N 5CD0251CBC
      P/N 7KE54EA
      Hello guys!
      I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
      It powers on OK and has no other issues except the following:
      • CAPS LOCK does not work at all
      • Fn button toggles Flight Mode
      • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
      • (with SHIFT pressed: 't%' and 'y^' respectively)
      I initially thought it was a keyboard malfunction (internal short, etc.),
      but when I press and hold...
      06-27-2025, 01:10 AM
    • Simone Vergani
      Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
      by Simone Vergani
      I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
      To assist with troubleshooting, I'm attaching two power circuit schematics:
      • Power
      03-05-2025, 02:25 PM
    • wizard13
      Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
      by wizard13
      I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
      I have checked the forum and the available documentation but could not find a solution specific to my issue.
      • Brand & Model: Dynabook Satellite Pro C50D-B-100
      • Part Number (P/N): PYU13E-00C00PFR
      • Serial Number (S/N): 22028896H
      • System Configuration (SC): A1PYU13E1127
      • Motherboard Model: IP3_ACN16_MB_V21_20211222A
      • Power Input: DC 19V –
      02-28-2025, 02:43 AM
