LG 60PA6500 Plasma No Sound
  • Chevy2
    • Apr 2012
    • 73
    Have a LG 60PA6500 that did work at one time with a dim picture that pointed to the z sustain board being bad (see picture of burn marks). I bought one off of eBay, but after putting it in, i stopped getting a picture. Putting the old board back in doesn't change anything. Could the new board have been defective and broke the y sustain? I checked all the fuses on the power supply and they are good, plus I get 5 volts into the y and z board. Any help or what to check next is appreciated.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG 60PA6500 Plasma No Sound
    Wow a burn mark on the ground lug. That's interesting. Does the tv still power up. You should be able to disconnect the z sustain board and take it completely out of the equation and still get a very dim picture if you do not something else is going on and we need to look further into voltage is coming off the power supply to start
    • Chevy2
      • Apr 2012
      • 73
      Need to edit the thread title if I can that it does have sound but no picture. I did get a picture before I put the eBay board in there. Now regardless of the z board, I don't get a picture only sound. Any guidance on which voltages to measure and where is appreciated.
      • freakaftr8
        • Oct 2012
        • 3743
        Ok to test voltages what I would do is disconnect your Z sustain board for now we don't know if the new one you got is good or bad. You have a voltmeter? If you do the first thing you need to do is set it to DC mode and put the black lead somewhere on the chassis ground and the red lead and stick it into the connector on the power supply output that says vs. Power up the TV are you getting voltage there?
        • Chevy2
          • Apr 2012
          • 73
          I can check Vs when I get home, but I was also getting 5v when I checked last night if that helps any.
          • Chevy2
            • Apr 2012
            • 73
            Vs is 211 and Va is 56. Sounds like it's within the 205 and 55 on the sticker.
            • Chevy2
              • Apr 2012
              • 73
              Y boards voltages were all over the place with buffers unplugged so bought a new one on eBay to see what happens.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Also check for cold solder joints on the sustain boards.
                • Chevy2
                  • Apr 2012
                  • 73
                  I had a picture until the Z board from eBay fried something. I'm assuming at this point that it's the y board.
                  • Chevy2
                    • Apr 2012
                    • 73
                    Mods please delete this thread. I'm going to start a new one with the correct title and all the issues after the eBay board ruined the TV.
                    • KYBOSH
                      Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                      by KYBOSH
                      Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                      No picture but you hear the TV static (white noise) playing loud and clear.
                      The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                      But it seems they didn't get too far and just left it.
                      When I first took a look I was amazed at how pristine the inside looked.
                      Its as if the TV had been in a time capsule.
                      Caps looked like they were just pulled off the self.
                      Copper coils had no sign of corrosion on...
                      02-01-2023, 11:10 PM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • Ierwin
                      by Ierwin
                      05-13-2025, 03:31 PM
                    • jchang
                      Samsung UN70NU6900F no picture and no sound
                      by jchang
                      Hi all
                      I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                      Symptom:
                      No picture no sound.
                      When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                      No sound at all.
                      What I tried:
                      1. I tried unplugging the left or right ribbon...
                      01-09-2023, 06:28 PM
