Sharp AQUOS 70" LCD model LC-70LE550U
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Sharp AQUOS 70" LCD model LC-70LE550U
    Peel both away so that flex cable is free from both the panel and the board.
    • budwich
      • Jul 2015
      • 3097
      Originally posted by freakaftr8
      That's your problem. Unfortunately you have got no other choice but to remove that board with those IC's on them.
      Just an interesting thought that I have not tried with anybody else's TV nor myself yet. Why don't you try removing just that IC off of the screen and the board leaving the other IC's still attached to the board and the screen. Then plug in the white cable to that side board again and see if you have a good picture. Trying to see what would happen with just one remove instead of all 5 on the side. Regardless that IC must be removed anyway
      Hey Freakaftr8...
      Have you ever looked at the underside of the driver "chip" on the tab cable?
      Is it just a "simple" pad connection going in and going out or are there several pads / connections... is it possible that maybe just scraping off the chip will solve the issue without pulling the flex cables from the panel?
      • freakaftr8
        • Oct 2012
        • 3743
        No. I thought that early and my TV repair life its have cables get warped by the driver IC overheatin. plus the IC's are fused to the ribbons the process of hot bonding and has to be performed with a very expensive machine that is not available to us. You would have to replace the ribbons with the IC'S already embedded into them.
        Youtube search for tab bonding repair then you'll see the machine used. It's a pretty elaborate process
        • budwich
          • Jul 2015
          • 3097
          I don't mean repair, I mean just removing the chip itself if that's the point of failure and leave the rest alone. Yes, this won't return the set to "new" but it may stop having to mess with 4-5 cables at the panel side which if someone is "unlucky" could mean "death" to the panel.
          • freakaftr8
            • Oct 2012
            • 3743
            This is true but trying to pop that chip out of that ribbon cable is more of a challenge usually ends up destroying the cable and causing other faults
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              #46
              You can do it with a solder iron will link to the video later.
              • budwich
                • Jul 2015
                • 3097
                I don't have access to the boards that I removed, maybe you still have yours kicking around... may the "soldering iron" test on one of those "dead guys" might be an interesting thing... of course if you have nothing else to do... :-)
                • Olympus620
                  • Nov 2015
                  • 21
                  Ok I threw caution to the wind and removed the 2 boards. The first image is with the bottom only ribbon cable removed as we were discussing. The upper part of the screen remained distorted.
                  Second picture is with the second ribbon cable removed.
                  At that point I could see a pattern and just removed the remaining ribbon cables and these two images are the end result.
                  I think we have a winner folks. Thanks for all your help Bud and freak
                  I am curious because the ribbon cables seemed not to be complicated. If the ribbon cables could be sourced with the drivers installed, with low temperature solder they may not be that difficult to replace. A steady hand(s) would be a must.
                  • budwich
                    • Jul 2015
                    • 3097
                    congrats
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      Yes congratulations on the repair I had a hunch that the remaining of the screen would still be dark due to the fact that I believe these cables or these ribbons run in series to some extent. Until somebody comes up with a solid solution of being able to successfully replace a ribbon IC and tab bond, this is our only hope to salvage a otherwise deemed useless panel
                      • budwich
                        • Jul 2015
                        • 3097
                        The Sharp's sets look easier to save than others. I have been "broadcasting" the potential for a save on few other forums in an effort to keep more out of e-cycles... but maybe this is cutting down the "opportunities" for non-owners to becomes owners on the cheap... :-)
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Lol. Fitting. Found this on my local craigslist.
                          • hmendez86
                            • Jun 2015
                            • 344
                            • united states
                            #53
                            Ey freak8 I have a lc-80le757u it has a line in the middle of tv horizontal but these drivers are with no boards it is like a regular lcd tv there bit small. The line comes from the right side, the line stops like at the middle just above that. It won't get to the left side .it has 4 drivers. I did disconnect the 2 right t-con cables and it dI'd disapeared but it got darker screen. I don't know how these drivers work ????
                            • budwich
                              • Jul 2015
                              • 3097
                              post some pictures of each side of the back of the panel. there are tab driver cables somewhere.
                              • hmendez86
                                • Jun 2015
                                • 344
                                • united states
                                #55
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  tough to see due to lighting conditions but maybe the second one shows the brown flex cables if I "understand" the picture. you may have to remove the bezel on one side (hopefully the bad side... where the horizontal line originates from) and get a closer look at the panel edge where the cables are attached.
                                  • hmendez86
                                    • Jun 2015
                                    • 344
                                    • united states
                                    #57
                                    I'll post more pics tomorrow in day ligth. I need to remove the trim were the driver tab goes.
                                    • hmendez86
                                      • Jun 2015
                                      • 344
                                      • united states
                                      #58
                                      • Curt2128
                                        • May 2016
                                        Does this same issue apply to the 3 short and 1 long blinks? I have a sharp lc-70tq15u where I believe I have a bad panel. I removed the two ribbons from the T-con board and now I have the backlight on both sides of the screen however the left side of the screen is blank and that has the ribbons removed from Tcon board. whats my best course of action to get this tv to come to life again? I noticed earlier in the thread it says remove the small connector on the Tcon board however I believe the TQ,SQ,UQ are slightly different. Any help would be appreciated.
                                        • Ice711
                                          • Mar 2017
                                          • Us
                                          #60
                                          Freak your awesome!! I know this thread is 2 years old, but still very helpful! Found the TV on a FB group for free. Got it home followed the directions in the forum, and bammn!! It works like a charm! Thanks again for your knowledge
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • Rozp
                                            70LE660U dark cloud or black screen with sound.
                                            by Rozp
                                            Hello Everyone,
                                            This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                                            I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                                            08-29-2023, 05:25 PM
                                          • klassic
                                            Sharp Aquos LC-60LE635E three blinks
                                            by klassic
                                            Hi community,
                                            I will describe my problem with a TV in those short following terms to be the most precise :
                                            What i have :
                                            power board DPS-162KP-1
                                            main logic board QPWBXF733WJN2
                                            symptoms :
                                            white led light logo at startup,
                                            after 2 minutes, blinking 3 times a row, repeating
                                            no backlight (and apparently no picture, checked panel with flashlight)
                                            no startup sound
                                            powerboard investigations :
                                            1-2 PNL : 0v
                                            3-4 GND
                                            5-6-7-8 UR : 13.15v
                                            9-10-11-12...
                                            10-24-2023, 01:39 PM
                                          • SmartSarah
                                            Sharp LC70LE747 Flickering - darkening gradually to the right side
                                            by SmartSarah
                                            Dear,
                                            I can not pinpoint the following problem on my Sharp TV LC70LE747E.
                                            While the left side of the screen is not affected at all the right side of the screen gradually fades to a kind of dark. I can best describe this darkness like a totally worn out CRT display or a gamma correction totally out of range. This darkness flickers like a flame, a dark one tough.
                                            Sometimes when I restart the TV it disappears for a while.
                                            The problem worsened over time the last few months.
                                            I've replaced the t-con module without success. The problem remains.
                                            05-23-2022, 01:00 PM
                                          • foxyUK
                                            Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                            by foxyUK
                                            Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                            The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                            There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                            10-22-2024, 10:27 AM
