Sharp AQUOS 70" LCD model LC-70LE550U
+ More Options
Posts
  • Olympus620
    • Nov 2015
    • 21
    Re: Sharp AQUOS 70" LCD model LC-70LE550U
    Originally posted by freakaftr8
    Then you have to remove that whole sise board from the panel like I have mentioned in my posting. There is a short on one of the tab driver IC's on that side board. Unfortunately that is the only option you have.
    Thank you so much. It sounds difficult!
    • Olympus620
      • Nov 2015
      • 21
      Are you meaning I need to remove and replace the right side board? That should get it back to like new if all else is good right? Any idea on where to find a replacement board?
      Thank you again!
      EDIT: I went back and read your post regarding this fix and I see now why it is permanent. This is unlike an LED panel where the strips are removable and can be replaced. Once removed they cannot be replaced. I see it now.
      I do still wonder how good of a picture I will have when this fix is complete? Is it anything like original?
      • freakaftr8
        • Oct 2012
        • 3743
        Yes about 8 people now have done that and the picture is just as good as before they were removed
        • ajshoe
          ajshoe
          • Dec 2012
          • 477
          • usa
          I have done this "surgery" and tv is in my house working perfectly. been 3 weeks. Only easy way to fix this problem. This is becoming a common issue as I've talked to some places that have these on 24-7. there are several on these tvs starting the early symptoms of small horizontal line starting on one side and goes halfway across screen.
          • freakaftr8
            • Oct 2012
            • 3743
            Actually this procedure is pretty straight forward on the bad side o the panel which is your right side all you have to do is remove three screws in the front and 3 screws on the side removing that black metal barrier bar that covers the side boards you have the pole the plastic shroud away just enough to get a screwdriver in there to remove those screws once you get that sidebar off you can remove the boards from the panel you'll see how the ribbons are attached to the panel. Just pull straight off the panel easily and carefully
            • Olympus620
              • Nov 2015
              • 21
              Freakaftr8 I want to thank you for helping to solve what is wrong with this tv(side drivers). I was hoping you could help me further to understand the technology and why the side boards cannot be replaced instead of just removed. I purchased this tv with the intent of reselling it after a repair but I am hesitant about reselling it with missing parts. I know I could inform the buyer and sell it with a large discount but I would like to get the most out of it. Is this un repairable because the side boards are not available or are the side boards designed so they can never be replaced/repaired? Thank you!
              • freakaftr8
                • Oct 2012
                • 3743
                They are designed to never be removed. They are what is called hot bar bonded to the panel . However the work load is being done by the other (good) side. There's no telling how long it will last this way. Haven't heard any fail yet (not saying it won't happen) . I wouldn't resell this tv unless the customer is notified about this and they are ok with it. This operation is not intended for the tv to last forever but it is adding life to and inevitably failed panel. Because the manufacturer did not intend for these boards to be removed for a specific reason. But they also didn't put much thought obviously into the failure points of these panels failing which seem to be more and more sporadic lately. Maybe it's just me and maybe I haven't paid attention or didn't realize what would happen when a sharp would give off a blank code for a failed panel in the past because we thought they were deemed unrepairable until we got together and came up with this solution which seems to work. My vizio has been running nonstop for 3 months almost with no problems. Others I think at least 8 or 10 other people on this forum that caught on and performed the same operation with their panels are still working. Like I said I do not endorse this is a permanent fix forever the panel is obviously stressed with one board instead of 2 but like I said before it adds life to a TV that would be deemed parts
                • budwich
                  • Jul 2015
                  • 3097
                  I don't think the boards are the problem, its the flex cable between the boards and the panel. At one end, the cables are soldered on and at the other "hot bonded". Of course, this could be repaired if you have the machinery and the replacement cables. But like most things in technology these days, those components are either an expensive initial investments and/or limited in availability (there are service places that are able to do it for a price).
                  I don't think you can sell a "saved" set unless the details of the "save" are disclosed and the price was suitably discounted.... likely less than $500 depending on "market forces".
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Forgot to ask do you have a perfectly running TV now? If so post pics
                    • Olympus620
                      • Nov 2015
                      • 21
                      No, I haven't committed yet to removing the boards. If I do this it's going into my living room which poses problems with space. Just looking for a way around it if there is one. I am in no rush at the moment with the TV being in the shed out back. I will update with detailed pictures if that route is taken. I have also been searching craigslist hoping for another broken compatible Sharp model. I wish I knew the model numbers of the VIZIO's using this identical display.
                      Thank you!
                      • Olympus620
                        • Nov 2015
                        • 21
                        Good info Budwich, Thank you! I had thought it was a burned out driver component on the side boards that needed to be replaced and reflowed back in place. As one option I was thinking since my sister in law works at an electronics manufacturing facility in Florida and she has bonding and flow equipment everywhere I could just send her the entire tv but in reality that is out of the question.
                        • budwich
                          • Jul 2015
                          • 3097
                          The boards themselves look pretty "non-descript", the driver is "embedded" in the actual flex cable.... which makes it even more difficult to "source". As for the service, I think I have seen a few "ads"... most will do the work BUT this is usually reserved for sets / TV that in the "high end" ($$$$) so the cost becomes almost a non-issue at those levels.
                          • Olympus620
                            • Nov 2015
                            • 21
                            Adding another image I should have added earlier. This was taken with just the right side corner(viewed from back) white ribbon cable removed. The horizontal band was not there yesterday when I was looking at the menu. As a side note the first driver ic is directly in line with the horizontal lines. I don't know if that means anything or not. FYI, I am still deciding whether or not I will be pulling the driver boards off.
                            • budwich
                              • Jul 2015
                              • 3097
                              IF you carefully look at the back side of that tab driver cable, you will likely see a "distressed" chip sitting there. On my sharp, the one driver chip actually melted into the plastic frame of the panel.
                              • Olympus620
                                • Nov 2015
                                • 21
                                It is slightly darker then the other chips. Not only that it will burn my fingers if I touch it. The other 3 chips on that side are cold to the touch.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  ok... now you likely found your problem... replace that chip and you will have a perfect tv ... :-)
                                  • Olympus620
                                    • Nov 2015
                                    • 21
                                    haha That might be a bit much for my skills.
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      That's your problem. Unfortunately you have got no other choice but to remove that board with those IC's on them.
                                      Just an interesting thought that I have not tried with anybody else's TV nor myself yet. Why don't you try removing just that IC off of the screen and the board leaving the other IC's still attached to the board and the screen. Then plug in the white cable to that side board again and see if you have a good picture. Trying to see what would happen with just one remove instead of all 5 on the side. Regardless that IC must be removed anyway
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        me too (interested) as that's what I wanted to do with mine but "some" indicated that all on the "troubled side" had to be removed.... :-)
                                        • Olympus620
                                          • Nov 2015
                                          • 21
                                          Sounds good, I have not looked to see how the flexible ribbon cable(with driver) attaches to the display so I am unsure where I should "peel" away the ribbon cable. Do I peel the flex cable away at the green board or below the driver nearer to the display? In this picture I am asking above or below the driver?
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • Rozp
                                            70LE660U dark cloud or black screen with sound.
                                            by Rozp
                                            Hello Everyone,
                                            This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                                            I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                                            08-29-2023, 05:25 PM
                                          • klassic
                                            Sharp Aquos LC-60LE635E three blinks
                                            by klassic
                                            Hi community,
                                            I will describe my problem with a TV in those short following terms to be the most precise :
                                            What i have :
                                            power board DPS-162KP-1
                                            main logic board QPWBXF733WJN2
                                            symptoms :
                                            white led light logo at startup,
                                            after 2 minutes, blinking 3 times a row, repeating
                                            no backlight (and apparently no picture, checked panel with flashlight)
                                            no startup sound
                                            powerboard investigations :
                                            1-2 PNL : 0v
                                            3-4 GND
                                            5-6-7-8 UR : 13.15v
                                            9-10-11-12...
                                            10-24-2023, 01:39 PM
                                          • SmartSarah
                                            Sharp LC70LE747 Flickering - darkening gradually to the right side
                                            by SmartSarah
                                            Dear,
                                            I can not pinpoint the following problem on my Sharp TV LC70LE747E.
                                            While the left side of the screen is not affected at all the right side of the screen gradually fades to a kind of dark. I can best describe this darkness like a totally worn out CRT display or a gamma correction totally out of range. This darkness flickers like a flame, a dark one tough.
                                            Sometimes when I restart the TV it disappears for a while.
                                            The problem worsened over time the last few months.
                                            I've replaced the t-con module without success. The problem remains.
                                            05-23-2022, 01:00 PM
                                          • foxyUK
                                            Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
                                            by foxyUK
                                            Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
                                            The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
                                            There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
                                            10-22-2024, 10:27 AM
