Sony KDL-46BX450 No Power
  • arod
    • Jan 2015
    • 22
    I received a Sony KDL-46BX450 from my grandparents who had a technician come to their house to diagnose their tv and fail to repair it. My grandparents had a warranty on this and were able to get a new television out of this deal, thus me inheriting the TV. The issue that I have is the standby LED blinks 6 times repeatedly once the TV is plugged in (no video or audio). I have attached the service manual for this TV to this post.
    The repair guy thought it was the power board and ordered a new power board for the television, but it failed to fix the issue (same problem). After receiving the tv and reading the service manual myself, it seems like it could be the inverter board which has gone bad. There is no visible damage to the board or anything suspicious when looking at it. I connected my multimeter to a couple of the lines, but I am unsure what would be considered normal. The unregulated 24 volt line that goes to the inverter is initially around 24 volts when initially plugged in, but drops to 0 (or close to 0) very quickly after the TV has been plugged in. My theory is that if the inverter board was bad, then the main board would immediately shutdown that circuit. However, without a more detailed description from the service manual, I am just guessing here.
    Normally, I would take the risk and just purchase a used inverter but they cannot be sourced unless I go through aliexpress and it is quite expensive with a long leadtime for delivery. Does anyone have any suggestions for further testing to isolate the issue with this television? I noticed that shopjimmy has a repair service for the inverter board and perhaps I might be able to do similar diagnostics as them to fix it myself. Any help is appreciated...
    BTW, the backlight inverter p/n is LJ97-03319A.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Sony KDL-46BX450 No Power
    Unplug the TV wait 30 seconds hold down the power button while you plug in the TV still holding the power button. Does the back lights come on do you see a picture before it shuts down with a 6 blink error again
    • arod
      • Jan 2015
      • 22
      The backlight never turned on when trying this
      • freakaftr8
        • Oct 2012
        • 3743
        Ok when you plug the TV in as you are still holding the power button as soon as you plug the TV and wait three seconds release the power button. This is done on the TV not the remote. Do you have an initial click a pause and then the six flashes
        • arod
          • Jan 2015
          • 22
          As soon as the television is plugged in, the standby LED begins flashing (no pause). I tried to mimic your procedure several times and there was no clicking when releasing the power button.
          • arod
            • Jan 2015
            • 22
            Are there any other suggestions for helping me to isolate the inverter board? The fact that the board never lights the backlight suggest to me that the inverter board is most likely the issue.
            • budwich
              • Jul 2015
              • 3097
              Have possibly tried "starting up" the set with the inverter board unplugged to see if you get a different code or possibly no code, depending on what happens.
              Further: you could try monitor the "err" lead, to see if there is any change.... could be tough but since you are good at the "24v" stuff, hopefully the other one is equally accessable. I would think it should go to some form of "high" for an "error condition".
              Lastly, of course, you checked all the fuses on the inverter board... :-)
              • arod
                • Jan 2015
                • 22
                I received the same error code (6 blinks) with the inverter unplugged. I checked the fuses first thing when I suspected the inverter. They are all good. I will try to monitor the err lead shortly.
                • budwich
                  • Jul 2015
                  • 3097
                  "while you are there", you should also check the "ena" to see if the system is trying to turn on the BL. Possibly, the error counts are passed a threshold and it doesn't even bother... just "erroring" instead.
                  • budwich
                    • Jul 2015
                    • 3097
                    I would try "redoing" the "reset procedure". I have seen reference to power the tv on... wait a bit to ensure it has "done something".
                    Point the Sony remote control at the TV and press and hold the "Up" arrow button.
                    Push the "Power" button on the TV while holding down onto the "Up" button. Release the "Up" button when the TV turns off, then turns back on. Hopefully it will clear any errors and light up... maybe
                    • arod
                      • Jan 2015
                      • 22
                      OK, when I plugged in the tv to attempt your reset procedure, the backlight came on (for 1 second before shutting off)! No idea what has changed other than a couple of reseats of the inverter board. However, now the buttons on the side of the television do not appear to have any effect. The standby LED is also a solid green now. There are no error codes.
                      On subsequent power offs (via the remote), the television will display the SONY logo for a second before the backlight turns off. The TV is still powered as the standby LED remains solid green during the entire time. It seems like this is most definitely the inverter board. Any last thoughts before I bite the bullet and order a new inverter board?
                        That inverter board is known for having bad inverter transformer:
                        https://www.badcaps.net/forum/search...archid=5567121
                        • budwich
                          • Jul 2015
                          • 3097
                          OK... so now at least you got something to change. So not withstanding the experienced advice given by budm (of which I have little), the trouble shooting steps outline in the SM appears to point to the panel.... maybe although other steps possibly indicate the inverter board. I would try a few more of the trouble shooting steps to see if anything else shows up to point direction.
                          Since it appears now that you can "move" the sets responses in a certain direction with some "keying / buttons", I would go back and pull the connections to the inverter again... what happens, do the error codes reappear? Further, there are other tests such as pulling the lvds cable to see that response. Combination of these "pulls" may help your decision.
                          Further, maybe the "flashlight test" will help to see if there is a display but no backlight. In addition, when they (the SM) are indicating a "panel problem", they might mean that for instance the backlights are not readily replaceable hence the panel problem / replacement.
                          Lastly, when the backlights momentarily came on, did you notice any "uneveness" in the lighting, that might point to a backlight issue in some form?
                          • arod
                            • Jan 2015
                            • 22
                            Just an update, but I purchased a new inverter board from buyqual.com in China. This fixed the issue. TV works normal now with the new board installed.
                              Thanks foe the follow-up on the repair.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Nice job!
                                • caseyjay_48
                                  Sony KDL-46BX450 Inverter Troubleshoot Logic
                                  by caseyjay_48
                                  I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                  I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                  09-23-2022, 08:08 PM
                                • Carlos#2003%
                                  Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                  by Carlos#2003%
                                  Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                  02-15-2024, 07:52 PM
                                • dkneyle
                                  Sony KDL-46HX850 Can't upgrade/update firmware
                                  by dkneyle
                                  Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                  Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                  09-25-2024, 10:44 PM
                                  Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                  This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-06-2024, 05:27 AM
                                • x_orange90_x
                                  Vizio E55-E1 bad backlights or bad inverter?
                                  by x_orange90_x
                                  I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                  I don't know how exactly to test the inverter itself. Is it...
                                  01-29-2025, 09:24 PM
