Sony kdl-50w656a
  • andrews7523
    • Apr 2015
    • 117
    • lancashire
    Sony kdl-50w656a
    I have a SONY KDL-50W656A what i bought thinking might need a new tcon board as the tv lit up without picture but later realised this set didn't have at con board. I found a donor which was smashed so started off replacing the main board which then made the set start flashing red. I tried changing the tuner and power board but now it only flashes red it won't even turn on anymore HELP!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Sony kdl-50w656a
    Did the smashed one have the same Lcd panel ? You cant just swap boards out as the software is tied to the panel.
    • andrews7523
      • Apr 2015
      • 117
      • lancashire
      im not sure as it was bought on ebay
      • sordids999
        • May 2013
        • 2161
        • uk
        Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • delpiero3
          Sony Vaio SVS MBX-261 board failure
          by delpiero3
          Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
          Nevertheless, let's say, i don't come as a total beginner.
          I have this old laptop, which suit perfectly my needs, with the...
          10-29-2024, 06:16 AM
          Another project idea for a battery bought from Battery Hookup with a good BMS board
          https://batteryhookup.com/products/n...-2900mah-cells
          One note these battery packs are below 10 volts and the BMS protection board has locked them off from having any voltage on the BMS output wires I have tested three of them so far and voltage is around 8 volts it not an issue because it testing about 9.2 amp hours
          The price of this offer has gone up sense I bought these two boxes
          I bought two boxes of these batteries but there is a catch to the these battery packs
          The BMS protection board does work but it...
          07-31-2022, 04:07 AM
        • huj3r
          Sony KDL-40Z4500 LCD with stripes and 9 blinks (possible BGC board or harness problem
          by huj3r
          Hi there!
          I have a Sony Bravia KDL-40Z4500 which shows a colored vertical stripes pattern when turning on, with a central black shadow that slowly dissipates within the first 10 seconds.
          Photo of the situation after the black shadow dissipates:
          After this behavior the red LED will blink 9 times, then pause for a bit, and blink again 9 times, in a loop.
          I checked the manual (available here) and this corresponds to "HFR error", quoting from the manual:
          > This indicates HFR Communication error. [ HFR Communication...
          08-15-2023, 10:55 AM
