T-con Samsung identifying problem
Re: T-con Samsung identifying problem
Got this from the service manual:
M0215 BN07-00511A LCD-PANEL;T315XW02 VL,8bit,32inch,16.7M, 1 S.A
Spec on service manual shows:
Specifications
Item Description
LCD Panel TFT-LCD panel, RGB vertical stripe, normaly black, 32-Inch viewable,
0.51075(H) x 0.51075(W) x 3 mm pixel pitch
Scanning Frequency Horizontal : 30 kHz ~ 80 kHz (Automatic)
Vertical : 56 Hz ~ 75 Hz (Automatic)
Display Colors 16.7 million colors
Maximum resolution Horizontal : 1366 Pixels
Vertical : 768 Pixels
Input Signal Analog 0.7 Vp-p ± 5% positive at 75Ω , internally terminated
Input Sync Signal H/V Separate, TTL, P. or N.
Maximum Pixel Clock rate 80MHz
Active Display
Horizontal/Vertical
27.47 x 15.44 inches (697.68(H) x 392.26(V)mm)
AC power voltage & Frequency AC 110V ~ 240V, 50/60 Hz
Power Consumption <180 W ( < 1W, stand by )Comment
found this document that seems to be the spec relating to T315XW02
https://cdn.badcaps-static.com/pdfs/...ed0b2359bf.pdfComment
I would imagine the panel itself is defective,stressing the T-con,which then,in turn,fried the smd on the psu..see if the voltage rises at the t-con with the ribbon cables disconnected.
In view the replacement t-con only lasted 2 mins,i would say without certainty the panel has met it's maker....but i digress..Comment
The LTA32AP06 panels are notorious for failures....not sure though if your set uses one of those...Comment
There is no no difference in voltage when panel cable removed.I would imagine the panel itself is defective,stressing the T-con,which then,in turn,fried the smd on the psu..see if the voltage rises at the t-con with the ribbon cables disconnected.
AFAICT, the OP's TV uses the following PSU (BN44-00221A):
https://flattvparts.co.uk/images/sam...-%20REV1.0.jpg
The ratings printed on the PCB are:
12V 1.1A
Vamp 0.6A
ST-BY 0.6A
24V 5.1A
5.3V 2.0A
How much current would need to be drawn from a 12V/1.1A supply in order for the voltage to drop by 3V? If it's not the panel that is responsible, then surely something on the T-Con must be hot to the touch.Comment
The panel was fine before the bad caps problem on the power board.I would imagine the panel itself is defective,stressing the T-con,which then,in turn,fried the smd on the psu..see if the voltage rises at the t-con with the ribbon cables disconnected.
See my thread:
https://www.badcaps.net/forum/showthread.php?t=48472
The problem that effected the t-con was a short on pnp after I redid the solders on it. The glue around it had become conductive due to the heat when soldering and shorted the regulator. Would it not be extremely unlucky for the panel to suddenly have a problem given this and that fact it was OK for two minutes until the second hand t-con went faulty and there is proof that the second hand t-con is faulty due to voltage tests ?Comment
and found file attached.
Do not know if it is correct as the number of pins outlines seem 2 pins short as I count 32 on the board. Maybe some are not used?
service manual to big to attached. Cut and paste below:
5. Exploded View & Part List
5-2-1. LE32A45*C** Parts List
Location No. Code No. Description & Specifi cation Q'ty S.A/S.N.A Remark
T0003 BN96-06784E ASSY COVER P-FRONT;32L456,EO(iDTV),ABS+P 1 S.A
T0175 BN96-06818C ASSY SPEAKER P;8ohm,CORAL,L450,10W,550/3 1 S.A
M0115 BN61-02947A BRACKET-STAND LINK;JASMINE 32”,SECC,T1.6 1 S.A
M0254 BN61-03699A HOLDER-SIDE AV;32L450,EO,HIPS,V0,-,-,-,B 1 S.N.AComment
This panel might be the correct version:
*** Just notice the Service manual later on list a different panel number again: M0215 BN07-00538A LCD-PANEL;LTF320AB01,8bit,32inch,16.7M,1 1 S.A in the exploded list that contradicts the original.Attached FilesLast edited by wilson_campbell; 11-08-2015, 10:25 AM.Comment
Yes just striped the control board of the back and there is a sticker underneath. It is:
LTF320AB01
0904
P8AE 8M9A0S060K A03 S64 (AP+)
This must be the panel ID.
Sorry for all the wrong info given everyone
I was wondering why the first panel had a supply voltage of 5V instead of 12V. Now that you've cleared that up, perhaps someone could rescue me from my ignorance and tell me what the AVDD supply is used for. :-)Comment
Looks like noone is interrested anymore
Fig 34, page 33 of the following datasheet (for ICD1) appears to have an application circuit that is similar to your own.
TPS65167A, Texas Instruments, Compact LCD Bias Supply for TFT-LCD TV Panels:
https://cdn.badcaps-static.com/pdfs/...6c316493a3.pdf
There should be a voltage of around 15V at the AVDD test point at the cathode of SD1.
I can see VOFF and VSS test points above L2 on your board.
ICD1 also has VGL (-8V) and VGH (+24V) outputs (according to the datasheet).
QD1 is a 2SA1718 PNP transistor for the Vcore supply (+1.2V).
2SA1718, PNP, -100V, -5A, Darlington:
I can't make sense of the part marking on ICD2.
There are also VON and VOFF test points at the bottom left corner of the T-Con PCB.
icd2 is 443/ on it. It was a very hard to see.Last edited by wilson_campbell; 11-10-2015, 10:53 AM.Comment
I'm very interested, but I don't know enough to help you. If I were troubleshooting your T-con PCB, I would identify all the other chips and attempt to understand how the board and panel work. Can you tell us the markings on the remaining ICs?
AISI, even when the input to the board is only 9V, ICD1 should still be able to boost the AVDD supply to its design value, probably 15V. However, it is only achieving 9.9V. Therefore something is wrong in this area. It may also be that the incoming 12V supply has high ripple which only shows up when the supply is loaded. Perhaps you should check the filter capacitor for this rail on the PSU. This high ripple could also explain why the AVDD boost converter is not functioning correctly. You would need an oscilloscope to see this.
Another thing you could do would be to determine where the AVDD supply goes. To this end I would set my DMM on diode/continuity test mode, touch one probe to the AVDD test point, and then buzz each of the ICs with the other probe.Comment
Hi, Thanks for respondingI'm very interested, but I don't know enough to help you. If I were troubleshooting your T-con PCB, I would identify all the other chips and attempt to understand how the board and panel work. Can you tell us the markings on the remaining ICs?
Do not have an oscilloscope to test, my be able to get one next week from work.
The two boards have now changed their voltages!
The original board has now dropped to 4.6 at in test point.
The second hand board has now dropped to 5.45. It is also now making a ticking sound.
To try and eliminate the power issue I tried taking a power adaptor with variable power setting: Removed the fuse in the T-Con. Set the adaptor to DC 12v. Earthed it to the frame and connected the positive to the "in" end of the fuse connection. It give these results:
Second hand unit just keep fluctuating voltage and ticking.
Old unit held at about 11v with panel connector off but dropped again to 4.6v when connected back up.
Do not know if this would eliminate the need for the oscilloscope and its meaning
Will id SMD's ASAP. I would upload a hi res image of the board so all the IDs can be seen but everytime I try to upload it it fails even though it meets the size and resolution guidelines.Comment
Try this to resize your pictures to match board requirements:
http://picresize.com/Comment
That sounds to me like the panel is drawing too much current, it can be shorted MLCC, or the driver ICs. Did you check the current draw of the T-CON? Per LCD panel spec, it is typical at 1.2A.Hi, Thanks for responding
Is the ticking sound coming form those two round inductors?Last edited by budm; 11-12-2015, 05:31 PM.Never stop learning
by THXFXHi I need help with a Samsung un43nu7100 BN94-13191C/BN41-02635A with boot loop problem even with tcon jumper.
I've already try tape method and same happen, if I disconnect both flex from mainboard to panel tv boots normal even I hear Samsung sound.
When I solder jumper to make t-con work with or without panel or panel cables connected it still reboot or power cycling.
What I noticed is that there's no voltage in VHG, HAVDD, PANEL_3.3V, AVDD_17V or 12v near dc-dc chip.
I check capacitors and diodes and didn't find any short IN MAINBOARD.
Measured all power supply... -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by howardc64Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable... -
by alro7779Hello, everyone!
A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,... -
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
- Loading...
