I have a Samsung PN50 circa 2009 that I picked up. hard starting was the reason it was mothballed. I removed smps and went over(reflowed) all solder joints of items on heatsinks and all major power diodes as I have done this on another PN series plasma with success. Upon startup , I get the jingle then relay clicks then a high pitched squeal with fine vertical lines as in the picture. It will continue to shut down and try to restart on it's own four, five, even six times. Eventually, it will start and deliver awesome picture and sound. Vs is good as is Ve, I cannot find test pad for Va, Vsc is not good. Found test pad on Y main and measured -50 to -53 volts, (even when running with good picture) should be -196 according to label on pdp. Once it starts, it will run for as long as I want to run it. Turn it off and as long as I restart it within 60 to 90 seconds, starts right back up..waited 5 minutes, back to the squeal with the lines. Is Vsc generated on the smps?
Sammy PN50
Re: Sammy PN50
Ahh well, let me state the following:
Psu Vs rails wont cause lines out on the Pdp.
Failed Ymain or Xmain wont cause lines out on the Pdp
What could cause this is either the mainboard or control board which is located to the left of the mainboard.Last edited by ReeceyBurger123; 10-31-2015, 02:29 PM.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Re: Sammy PN50
You could try heating the Mainboard with a hair drier to see if helps the issue looks like a Mainboard issue to me.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Re: Sammy PN50
Ahh nice oneDid you replace all the Smd caps ?
Re: Sammy PN50
Turns out this is a known issue...Audio chip on front and one 8 leg IC and smd cap on back of board is causing it. I can ship it off for repair for $40 including shipping....I do not have a hot air station so it looks like I will be sending it off.Comment
Re: Sammy PN50
It very well is that Ic regulates 3.3v for the Cpu when that messes up it causes alot of issues they become heat sensitive when they fail.. Was just about to say order that and all should be goodPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
This specification for the ASUS PN50-BR078ZD can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the PN50-BR078ZD boardview and PN50-BR078ZD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS PN50-BR078ZD...09-12-2024, 03:36 PM
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
by RubenlilyHello,
First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
I'm no expert but I've done the tape... -
by dkneyleThis relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS... - Loading...
