Hitachi 32hxc01u dead mainboard
  • comptek
    • Aug 2013
    • 606
    Hi all hope someone has one
    i have an Hitachi 32HXC01U boards are vestel rubbish the fault is no led at all all voltages are correct and has been tested with another mainboard 17MB82-2
    so im kinda hopeing someone has a 17mb82-2 23133910 board for sale or trade
    i dont really want to use EMO's to dear £36 and had duff stuff off them before
    many thanks
    Gary
    [/URL][/IMG]
    [/URL][/IMG]
    [/URL][/IMG]
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Hitachi 32hxc01u dead mainboard
    Ahh more Vestel shit lol. Have you checked the MLCC's for S/C Gary common fault on these which will cause no standby failure ?
    • comptek
      • Aug 2013
      • 606
      Hi mate what are they? sorry im still quite new
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Hi mate, no worries here is what one looks like:
        • comptek
          • Aug 2013
          • 606
          oh i thought they were called caps lolol
          i will have a test and report back thanks mate
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            No worries to test, put one of your probes on to ground (I use the Vga socket) and see if that cap is shorted to ground. Only on side of the cap should show shorted to ground if both do you have an issue some where.
            • comptek
              • Aug 2013
              • 606
              Hi Reecey i have tested most of them on diode mode i assume is correct and theres one nearest to the main input socket that appears to be O/C could this be the fault or am i testing them wrong?
              its just above what looks like pins 1&2 below two silver pads in pic showing board
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                O/C normally these will only fail S/C did you check it using the method I said buddy ?
                • comptek
                  • Aug 2013
                  • 606
                  have now lol
                  no reading either end of it :/
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Hmm and its labled as a cap is it ?
                    • comptek
                      • Aug 2013
                      • 606
                      im not sure but i have found a black coloured one just below the CI socket at the top has the same reading both side and s/c across gonna swap it out located near q49 placing which is empty
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Thats not a cap, thats a resistor buddy so probably will be low enough to fool you meter as it being shorted.
                        The next step would be to hook the board up and start taking some voltage readings across the board.
                        • comptek
                          • Aug 2013
                          • 606
                          thanks Reecey ok i will do that tommorow
                          i can see me getting that board from Emo's lol
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Haha no worries pain to trouble shoot, im currently repairing a 17mb35-4. So far I have checked all the 6.3v MLCCs out of circuit (over 15) replaced the Hdmi Ic (Lots of pins to solder) and still it refuses to work lol and im about to toss it out the window haha. Make sure you match the board exact as they are tied to the panel number.
                            • comptek
                              • Aug 2013
                              • 606
                              hope you get it sorted Buddy .....
                              i might even have one here i will have a look in the morning
                              well i normally like to fiddle first then order one lol
                              they are never the same, bits missing, bits added so many different screens and boards for the same model of tv, what a load of shite they are!
                              i have noticed lately bush and alba have changed to sieki boards which are just as bad lolol
                              im aware of the number on the label i screwed up the first time i ordered a board years ago !
                              thanks for the info so far
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Haha cheers I put that one aside for the min. I hate these boards that tie software to the panels its just a pain but Vestel use so many panels though so see why. Alba, Bush and Seki use Umc chassis's they are on par with Vestel tbh just as shit. Let us know what happens buddy
                                • comptek
                                  • Aug 2013
                                  • 606
                                  Hi Reecey im not sure what happened but while i replaced and checked that resistor last night which made no difference i thought i would heat up various components with my reflow station and i then left until today...... plugged it in to go through voltages again and the led started flashing and the screen lit up i first thought i picked up the wrong board but no...... its now working and has been on all day, i just dont understand it as the previous owner said it was on and she unplugged it to do the hoovering plugged it back in and it was dead ???
                                  so i thought it was something taken out to a power surge or something, but anyhow its working thanks for your guidence
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Hmm possibly needs a reflow then or a device is becoming heat sensitive. Haha strange let us know if it messes up again buddy
                                    • comptek
                                      • Aug 2013
                                      • 606
                                      will do mate all going well so far
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Fair enough buddy
                                        • jamesp
                                          Acer Aspire A315-55 Dead mainboard
                                          by jamesp
                                          Hello, can someone please help me. i have a dead laptop mainboard, aspire a315-55 with board model DA0ZAWMB8G0 rev. G
                                          upon checking of voltages at s5, 19v is present Vin, 5v and 3v is present at PL6001 and PL6000 respectively, but no signal from MAINON And s5_ON to be able to produce +3v_s5 to give power to vcc of BIOS CHIP U2. MAINON and S5_ON is coming from ec chip U37 it8987e/cx.
                                          do i need to reflash the EC? any advice? thanks...
                                          09-30-2024, 08:24 AM
                                        • 3mz3t
                                          ThinkPad T14 Gen1 Intel, dead mainboard
                                          by 3mz3t
                                          NM-C931 mainboard, does not start, no light, no nothing. Draws 20.56 V / 0.14 A from a wall charger.
                                          Under thermal camera, the only thing that show is the ThinkEngine chip (BD4179MWV / UTE1B) heating up (also quite hot to the touch), there's 19.75 V on the VREGIN20 (pin 45).
                                          Is the BD4179 dead? WDYT?
                                          Thank you....
                                          08-05-2024, 04:59 AM
                                        • PNI E.
                                          firmware hitachi 50hk6000 mainboard 17mb130s
                                          by PNI E.
                                          hi guys, can you help me to find a firmware for my hitachi 50hk6000. the tv turns on but no screen, im sure it s a firmware problem because i bought a new main board from ebay but they gave me an other version of the mainbord mine finish in s the board they gav me finish in p, and have 3 hdmi, but the tv with that board turns on but says dont signal and doesnt respond to the remote control. so someon can give me the firmaware for 50hk6000 main board 17mb130s so i can flash the eprom thansk guys
                                          02-14-2025, 02:06 PM
                                        • Mirenia
                                          Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                          by Mirenia
                                          I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                          I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                                          In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                                          The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                                          03-30-2025, 06:47 AM
                                        • double_DD
                                          How can I be sure that my EC chip is dead?
                                          by double_DD
                                          As the title suggests, how can I be sure that my EC chip is really dead?
                                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                          03-12-2025, 07:47 AM
