Sharp LC-70LE600U - LED lamp error
  • wldock
    • Oct 2015
    • 8
    So, I picked up a used 70" Sharp Aquos LC-70LE600U set that failed due to an LED lamp error. The front status LED flashes a slow on then off. The set will startup in service mode and the lower section of the right side of the display has a dark back-light section. I just cracked it open and will start taking some measurements when I get more time. So far the output fuses on the main board seem to be fine. My fear is that there is a bad LED edge strip...I really don't want to have to remove the display but it might come down to that.
    I will attached some pictures and the service manual. Any advice on things to look out for is welcome!
  • wldock
    • Oct 2015
    • 8
    Re: Sharp LC-70LE600U - LED lamp error
    So it turns out one of the three LED PWB strips is bad. Two of LED's are blown. What a tricky procedure to remove these. It looks like Sears Parts Direct has the strips in stock, I hope. Its going to be interesting getting this thing back together.
    • Eric D.
      Sharp LC-60LE810UN Lamp error
      by Eric D.
      Hello everyone!
      I just acquired a Sharp Aquos for free.
      When I plug it in, it will try to power on, but it fails.
      The "error code" is 1 long flash, then 1 short flash, which suggests it is a lamp error code, according to the manuals.
      I did a bit of research and did what I found could be the possible issues;
      I removed the back panel, checked for continuity on both fuses where the power cable connects, and I get somewhere around 0.05. That should be good.
      I also tested the leads going into the psu board from the wall connector; I get 120V.
      I disconnected...
      01-18-2025, 05:14 PM
    • Yanleb
      Sharp LC-60LE810UN Lamp Error
      by Yanleb
      I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
      I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
      Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
      I've tried all the key...
      08-24-2021, 11:48 PM
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      The TV does not turn on, the standby indicator is on. All voltages are present.
      Emms is dead. Not readable, not detected.
      Replaced emmc.
      But with another dump there is no launch
      Terminal log
      UART
      AC_ON
      RPMB key is not yet programmed
      HASH1_VERSION=0x00000000 64bit
      E-B
      FDE enabled
      layout pattern onebin by SAR7,0...
      06-01-2025, 02:11 AM
    • michalk3777@gmail.com
      Sharp Hisense - LC-65N7004U Error codes
      by michalk3777@gmail.com
      Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
      Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
      Regards,...
      12-15-2024, 09:20 PM
    • sushilachuthan
      APC UPS error P13
      by sushilachuthan
      one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
      the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
      The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
      We replaced the SCR with new device,, but the device is not power on as expected.
      Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
      09-26-2025, 09:00 AM
