Bush LED24127FHDDVDW White DVD Combo - Plays Black and White DVDs
  • MWJN
    • Oct 2015
    • 7
    • United Kingdom
    Hi All
    Wondering if you can offer any advice on this please?
    TV plays in colour when watching Freeview
    When playing a DVD the DVD will play in Black and White
    Do I need to replace the DVD Player or is there something wrong on the main board?
    Many thanks for your advice
    Max
    Re: Bush LED24127FHDDVDW White DVD Combo - Plays Black and White DVDs
    Around the edges of colour objects do you see fuzzy dots that seem to "scroll" like this?
    https://upload.wikimedia.org/wikiped...00px-Crawl.jpg
    • MWJN
      • Oct 2015
      • 7
      • United Kingdom
      Hi Tom 66
      Yes but also the Picture is completely Black and White
      Whatever DVD is played
      All the DVD's are Region 2
      I will get a Photo of when the TV is playing a DVD in Black and White and when the TV is in Colour
      • MWJN
        • Oct 2015
        • 7
        • United Kingdom
        Hi Tom
        Photos of the DVD loader
        Also the TV on Sky/TV Input
        Also the TV when using the DVD
        Also the TV Model Number
        Thanks for any help
        Max
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Hmm Vestel trash I see, the particular Dvd rom used in that tv is prone for the Epprom Ic on it failing and casuing the player to act goofy. Whats the full model of the Dvd player please ?
          • MWJN
            • Oct 2015
            • 7
            • United Kingdom
            Hi ReeceyBurger123
            Thanks, hopefully this is the correct info
            Is it worth buying just a replacement DVD Loader?
            Cheers
            Lightcomm Technology Co LTD
            HCN DVD Loader DL-10 Model Model 30072389
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Hello no worries glad to help
              I have found a replacement drive item number is in the photo, however I don't think its worth that tbh unless you are planning on selling the tv and would benefit (profit wise) from it having a working drive. These are just so unreliable and wont last any longer than the original. I have seen too many fail with similar issues.
              Its up to let us know what you decide to do. Cheers
              • MWJN
                • Oct 2015
                • 7
                • United Kingdom
                Hi ReeceyBurger123
                Many thanks for the quick reply
                Totally understand the TV is rubbish
                I need to replace the Drive as it is for my Son's Bedroom and they watch DVD's
                So i will take a punt on it and hopefully it will last longer than the last one
                The last one has lasted nearly 3 years, so if I get that amount of use from it would be great
                Thanks again much appreciated on your advice
                Max
                  If the DVD "player" portion has a separate menu -- they usually act as independent parts -- try accessing the setup menu and changing the output mode. It might be set to NTSC instead of PAL.
                  • MWJN
                    • Oct 2015
                    • 7
                    • United Kingdom
                    Hi Tom
                    I did have a look last night but could not gain access to the Advanced DVD Menu, the DVD Menu is simple and does not allow change for NTSC or PAL Formats
                    I will change the DVD Loader, if this does not work, then the TV will just have to be used as a TV and I will purchase a seperate DVD Player
                    Thanks again
                    Max
                      To be honest I would use a separate DVD player anyway.
                      The local "Co-Op" has a Sony DVD/Bluray combo for £27. Not too bad. (Probably not made by Sony, though; likely a rebadge.)
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Not even that Tom Tesco are selling cheap Teac players for £18 !!
                          • 31185
                          and the internal players are shit with no "features"
                          • sgcampion
                            Asus rog strix scar 17 G733QR display Issue(flicker, black/white))
                            by sgcampion
                            My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
                            In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....
                            10-24-2023, 09:39 AM
                          • hcinne
                            Dell G15 ryzen edition black screen 2 amber 1 white
                            by hcinne
                            I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                            07-23-2024, 07:56 AM
                          • Raulnn
                            TD Systems K50DLG12US half black and half white screen
                            by Raulnn
                            good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                            By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                            01-20-2024, 04:49 PM
                          • Ihandyrepair
                            sony 55X850D black screen no front white or red led light.
                            by Ihandyrepair
                            Hi guys
                            strange one
                            I have a dead Sony 55X850D
                            when plug in, black screen, no front white or red LED, no back light no screen
                            Voltages I get
                            3.3v LD/power and main board
                            reg 12V
                            reg 19V
                            3.3v on power on pin
                            no Tcon on
                            no tcon 12v
                            no BL_on
                            I do get BL_ERR 2.0v
                            I tried to bypass it by ground it but still get same symptom
                            I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                            or is possible the chip next to...
                            08-07-2024, 04:58 AM
                          • zoontz
                            SHARP LC-70UD27U black and white lines
                            by zoontz
                            Wondering if anyone has addressed an issue with the SHARP 70” LC-70UD27U having thin black and white lines running from left to right horizontally on the screen. I snagged this TV set from a neighbor since I have been successful in repairing numerous other TVs. I assume this probably happens to other TV sets and may have been addressed in another thread. If so please point me in the right direction.
                            What I have tried so far.
                            I have tested all HDMI inputs with the same results.
                            I have checked for firmware updates.
                            I have reset to factory settings.
                            I have removed...
                            07-09-2024, 05:50 PM
