Samsung LE40D580 dead no power after "pop" sound
    Picked up this Samsung 40" (CCFL backlit) from 2011 for not too much, it is dead no power. Previous owner claims it made a load pop then stopped working.
    The STR-W6052S is blown, main standby/run controller. Seems like it does not have much thermal paste on it!
    Anyone else seen this?
    The component is £3 so I'll just replace it outright.
    It uses BN44-00440A power board.
    Re: Samsung LE40D580 dead no power after "pop" sound
    Fixed the set after replacing the STW-W6052S, everything good there now set powers up with crystal clear picture.
    However PFC bus voltage only 330V - I suspect the PFC IC is bad so I will need to replace that. It may have been damaged by the original failure.
    • jose6326
      • May 2013
      • 707
      hey tom66 can you post pics of what you replaced for future reference
      thanks
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • Mgiffune
        by Mgiffune
        06-09-2024, 10:28 AM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • kevin_allein
        Samsung QE 75 Q 7 FGMTZG Power Supply dead
        by kevin_allein
        Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
        In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
        Does anyone have schematics for that board ?
        Any good tip, what could be the issue ?
        02-27-2025, 12:15 PM
