Hi could somebody kindly offer some advise please I have this lg 42PQ3000 and upto trying to start the tv all it does is click quite rapidly for 30-40 seconds then won't do anything at all the red light on the front flashes until clicking stops. Anyway reading through some of the other posts regarding similar problems I have tested the pins with the board out of the tv (not with it plugged in yet) and the readings are as follows. Top 17v is reading 14.28 second is 12v and reading 6.3 next two are 5v and both reading 5.38 third is 5v and reading 6.08 not sure if any of this helps or I'm doing something wrong. I repair kitchen appliances for a living so do have some electrical knowledge just not a lot with TV's. Thank you for reading and for any help given in advance.
Lg 42pq3000 just clicks
Re: Lg 42pq3000 just clicks
Have you unplugged the Ysus and Zsus connectors ? Also pictures please.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Ok cheersPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Its the diode next to that transformer check it for S/C.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Put your meter in diode mode and measure across the diode.
You should get OL one direction and a reading other direction when you reverse your leads.
If it just beeps and no reading then it may be shorted. But you'd have to remove it from circuit to be positive Incase something is in parallel to the diode making it test short.Comment
With a constant clicking one of the first things I'd check if all caps look good is cracked solder joints.
Unfortunalty your picture isn't clear enough, check for anything that looks like this:
I'd reflow the joints around anything that moves more than most.
Coils, transformers, anything attached to a heatsink.Comment
I can't see any bad solder but on checking other diodes I found one that won't give a steady reading then goes to ol then reads again swaps wires to other side doesn't give a reading at all is this something to check pleaseComment
by SuperAmanI did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
by GRANDGGHi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
by Fuzzy FixHowdy all I have a 90uF Capacitor 200/275 VRMS and measured the ESR . Reading says 00.3 Ohms and about 1/2 a second later 00,0 and says low ESR (Really No Kidding).
I have checked it on the multimeter and reading is 94.7uF well within soec as ir has a 25% tolerance on it.
Can anyone advise me is this capacitor likely to fail in the near future or still good to use.1 Photo-
Channel: General Capacitor Questions & Issues
by redbaron1007I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
S9 13.7V
Pwr Ry 0V
AC Det 9.1V
Mgnd 0V GND
The two pins on the transformer for the operation...7 Photos-
09-12-2024, 03:04 PM -
by kalilinux25Hi my board is HUSK MB 11309-248.4TU05.021
The board is plugg and consuming 13 milliamp
measuring the 3v coil no reading and the 5v coil no reading
Ive measure the pins in PU4103 ( RT8223M)
1- NO READING
2- NO READING
3- 4.4V
4-NO READING
5- NO RADING
6- NO RADING
7-3.3V
8- 5V
9-19V
10- NO RADING
11-3.3V
12- 3V
13-
14
15
16-4.4V
17-3.3V
18- NO READ
19-5V
20- NO READING
21-2V
22-2V
23-NO READING
24- 5V
... - Loading...
